Results 1 to 7 of 7
    Mar 2009
    Reynolds DV46 Free wheel
    My racing wheels are Reynolds DV46, with a campy free wheel. I probably have 400 miles on the set. Over the last few months, the free wheel has gotten much louder. When new, the free wheel was quieter than my trainer wheels, and now it is louder. Also, when coasting it buzzes in an alternating pattern--bzzzz--BZZZ-bzzzz--BZZZ, which is causes me to worry something is wrong.
    I haven't observed any performance difference in the wheels. They seem to coast as well as before. The local bike shop says every free wheel has its own sound, and this is perfectly normal.
    Yet, I'm unhappy with the wheels now, and my confidence in the race day performance of the wheels is failing.
    Has anyone encountered an issue like this? Would a new free wheel be a solution?
    Höchstgeschwindigkeit
    Reputation: mimason's Avatar
    Oct 2006
    A dab of grease is your friend.
    'brifter' is a lame word.
    your hubs don't have a 'freewheel'. they have a freehub. your cassette cogs slide onto that. they're held on by a lockring.
    your bike shop guy is correct, there are lots of different freehub/drive engagement systems and they make different noises.
    the noise is normal. there is nothing wrong w/ your hub. if you want to quiet it down, you can add some lubricant, but stay away from heavy grease or anything sticky as they will cause you to have problems.
    2012 Trek Cronus Ultimate w/ SRAM Red Black
    2010 Cervelo T1 sprint bike
    2011 Cervelo P2 pursuit bike
    FMF 24" cruiser
    Bianchi Pista road fixed gear
    1949 Columbia 26" cruiser w/ SRM & fenders...and rust
    '05 Suzuki DRZ400SM
    Jan 2011
    The alternating pattern sound is probably from the rear being unbalanced. Some will say it screws things up blah blah blah, but I've been able to hit 50 mph without issue.
    Reputation: jmess's Avatar
    Aug 2006
    Quote Originally Posted by mimason View Post
    If you have DT-240 hubs, clean and grease the star ratchet. For me it really quieted things down. DT recommends using their "special" grease, most LBS have it. I bought some online and did the clean and lube myself.
    Reputation: slowdave's Avatar
    Nov 2005
    Check out you tube dt swiss 240 hub maintanence, its easier than changing a tube.
    Not F Schleck. The last 24k is downhill, and he descends like a drunken cat. Quote: justinb
    Mar 2009
    Quote Originally Posted by slowdave View Post
    Thanks, guys. This is helpful
