Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
  1. #26
    pmf
    pmf is offline
    Quote Originally Posted by hebecb View Post
    You guys are awesome thanks!
    Based on your thoughts (here and elsewhere), I'm going with HED Belgium + WI CLD (in blue!) with 32H front and back.
    You might not need 32f/32r. The folks who built my wheels (psimet) recommended 24f/28r and I weigh 200 lbs. I asked about 32/32 and the owner said it won't be any stronger of a wheel. I've been riding one pair for a few years now and they're perfectly true.
  2. #27
    Aug 2016
    Good choices Hebecb!
    Now, which spokes and nipples are you going to get?
    Well you guys scared me off the annodized alloys otherwise I probably would have gone with blue alloy nips but now i'm thinking silver (perhaps DT double butted) spokes and black brass... for some reason the silver spokes feel right for my Ti (sandblasted) frame.
  3. #28
    Reputation: Lombard's Avatar
    May 2014
    Brass nips and double butted spokes - more good choices!
    -- Warren Buffett
  4. #29
    May 2014
    Quote Originally Posted by pmf View Post
    24/28 is fine for rim brake wheels. For disc, I would advise 32/32.
    -- Warren Buffett
  5. #30
    Aug 2016
    I've had good advice ;-)
  6. #31
    pmf
    pmf is offline
    Why is that? Just curious.
    I don't get this disc brake thing, but to each his own.
  7. #32
    Aug 2016
    Exactly. Although I've had some folks suggest lower even for disc brakes, i'm concerned about the extra stresses of disc brakes so...
    These are gonna be all-around wheels for a while. I do a number of supported double centuries and other rides where I might be willing to try a lighter wheelset (and this way I may be able to demo some before pulling the trigger).
  8. #33
    Aug 2016
    According to my research, disc brakes put more stress on the spokes near the hub.
    As for why.... while I don't do much rain riding (NorCal it's compressed into a few months) I do have a lot of long twisty descents. The improved reliability of braking pressure as well as no longer having to worry about rim heat-ups is what drew me towards disc brakes.
    I'm not a "weight weenie" so that's not as much of a concern (though for the really long hilly rides it's a bummer) and I have another way to shed 2-3 pounds if I need to ;-)
  9. #34
    May 2014
    Hebecb answered this pretty well.
    -- Warren Buffett
  10. #35
    I dont disagree about more stress, but I have yet to see a wheel where someone said a spoke broke when I was grabbing the brake. Not to say it hasn't happened. I'm sure tandeems and tourings bikes could give issue. But I have yet to see a it with normal bikes with disc.
  11. #36
    Aug 2016
    Quote Originally Posted by Enoch562 View Post
    Perhaps but.... I run 32 front and back now with my rim brakes. They are strong and true. I've decided not to go lower upon moving to the new brake system
  12. #37
    May 2014
    But how many disc brake wheels exist that have less than 28 spokes? Note that new Cannondale Synapse rim brake bikes used to come with 16/20 spoke wheels. Their disc brake versions come with at least 28/28 spoke wheels.
    -- Warren Buffett
  13. #38
    Dec 2011
    I'd never use what OEM wheel sets are doing as a proxy for what anyone should do. They are designed with two things in mind - to be useful on every size of bike in that model's range for every weight of rider who might ride one, and aesthetics.
    Disc brake rear wheels are somewhat stronger than rim brake wheels, spoke for spoke. Flange spacing is 5mm wider on disc wheels (assuming 135mm OLD spacing), and that 5mm makes a ton of difference.
    Disc brake front wheels are somewhat weaker than rim brake wheels, spoke for spoke. Flange spacing is narrower (still 100mm OLD, but you need to fit a rotor in there) and the wheel is dished. Front wheels are pretty freaking strong anyway.
    24/28 disc wheels can have a ton of applicability, as can other combos. I've raced two cross seasons on 24/24 without having to do anything to the wheels, except that now I have to replace a rear rim because I ride a cross bike like a bull in a china shop and the rear rim is dented like crazy.
  14. #39
    24/28 seems to be the most common build I run into. I'm sure Nove Dave has a plethora of them out there. Most of the Zipps I see are 24/24. Its the whole I need more spokes for a disc road bike thing I dont agree with. I'm all for more spokes, but it just doesn't seem to be a issue.
  15. #40
    Aug 2016
    FWIW, I reached out to "November Dave" earlier in the process and he had suggested 24/28 for me (185lbs). In the end I went the conservative route (and LBS route too.... sorry Dave ) and stuck with the same spoke count I have now (guess I said that above already).
    I will, most likely, pick up an additional set of wheels at a later date and try lower spoke counts on those (and use them for local or supported rides). Hopefully I live to tell the tale of how they stack up
  16. #41
    Jun 2017
    I'm no expert.....but. if you are a big guy (I am). Your spending a good chunk of money on a set of wheels. With hubs you are hoping to be riding for many years. At least in my case. I would tend to be conservative. Because once you make the decision, you kind of stuck, for lack of a better term. I'm looking to have a nice set of wheels built for my new bike. But everybody's priorities are different. I'm leaning towards Chris King if I can afford them on the hubs, if not, will probably go with DT.
  17. #42
    May 2014
    Quote Originally Posted by Tallboy1959 View Post
    Exactly. Or to put it another way, what are you going to gain by having 4 or either 8 fewer spokes? 30-60g less weight is not going to make you go noticeably faster.
    If I were you, I would take a serious look at White Industries hubs. Unlike Chris King, DT and just about all other boutique hubs, White Industries have a Ti freehub body rather than aluminum. If you are a strong or heavy rider, an aluminum freehub is prone to gouging by the cassette.
    -- Warren Buffett
  18. #43
    Jun 2017
    Thank you very much.....that, I didn't know.
  19. #44
    Aug 2016
    This is exactly why I went with WI hubs.
  20. #45
    Reputation: 4slomo's Avatar
    Feb 2008
    When the freehub gets gouged, you/mechanic files down the grooves. At some point you replace the freehub. It's very simple. Do use a cassette with a spider freehub mount, not the cheaper cassettes with the cogs just pinned together.
    Hey everybody, ride my wheels! They ride good, real good.
    I'm a wheel builder. SRLPE Wheel Works. Send me a PM.
  21. #46
    May 2014
    Quote Originally Posted by 4slomo View Post
    Wouldn't it be even simpler to just not use the hub that causes this problem in the first place?
    -- Warren Buffett
  1. Replies: 9
    Last Post: 11-05-2015, 07:47 AM
  2. Replies: 10
    Last Post: 01-17-2014, 03:09 PM
  3. Clyde Having Trouble w/ DTSwiss RR585 Build
    By jonshonda in forum Wheels and Tires
    Last Post: 08-13-2012, 08:02 PM
  4. White DTswiss Aerolites?
    By Cheers! in forum Wheels and Tires
    Last Post: 10-29-2008, 08:38 PM
  5. DtSwiss RR1.1 rims
    By smokva in forum Wheels and Tires
    Last Post: 03-15-2005, 11:57 PM
