Results 1 to 22 of 22
    Reputation: BigBadConrad's Avatar
    Aug 2010
    road tubeless - what to carry on bike?
    I bought a set of Ultegra 6700 tubeless wheels a few months ago and have been running Conti GP4000s with tubes. Tore a sidewall in a crash and have to replace a tire so am considering going tubeless and trying the Hutchinson Fusion 3 with caffelatex (what my LBS recommended). I live in the desert so understand I will need to clean out the 'rubber bands' every couple/few months and add new caffelatex. I may have my LBS do the initial setup while I watch.
    What do you tubeless guys carry with you on the bike? The Hutchinson Fast'air aeresol can? The Repair'air kit? A spare tube? All of the above? Honestly, this is what is keeping me from making the switch. Just not confident about getting myself home in the event of a flat that doesn't self-seal and not sure what to pack. The roads I ride are mostly smooth and have little to medium debris. With the Contis, I have only flatted 3-4 times a year (not counting the crash!).
    Thanks,
    BBC
    "Today's mighty oak is just yesterday's nut that held its ground." - Anonymous
    classiquesklassieker
    Reputation: orange_julius's Avatar
    Jan 2003
    Quote Originally Posted by BigBadConrad View Post
    What do you tubeless guys carry with you on the bike? The Hutchinson Fast'air aeresol can? The Repair'air kit? A spare tube and regular presta valves? All of the above? Honestly, this is what is keeping me from making the switch. Just not confident about getting myself home in the event of a flat that doesn't self-seal and not sure what to pack. The roads I ride are mostly smooth and have little to medium debris. With the Contis, I have only flatted 3-4 times a year (not counting the crash!).
    Thanks,
    BBC
    If the sealant in your tire doesn't seal the leak, then a Fast'air isn't likely to fare much better. I just carry spare tube and pump, and good tire levers. I've had to fix a flat several times, each time I just stick a tube in.
    Mar 2012
    Haven't had a flat yet. Would run stan's and not caffelatex as a lot of people have had it just bubble and not seal. In my kit I have a tiny multi-tool, park levers, spare tube, lezyne co2 chuck and one co2 cartridge. I also think there might be a small patch kit incase someone else on the road needs it. I'm never far from help/shops since it's very urban area near the beach.
    Trigger Warning
    Reputation: Local Hero's Avatar
    Jul 2010
    I use as little sealant as possible when setting up (1/2 the hutchinson recommended dose). I carry a spare tube, C02 and lever to fix flats. Nothing fancy.
    I suggest you put the tire on the wheel. It will be good for you to know the difficulty of getting that bead over the rim. Then you'll know what to expect on the side of the road. Of course it's much easier to fill the tire with an air compressor. So even if you get the tire on, the shop should air it up.
    Sep 2008
    Quote Originally Posted by NWS Alpine View Post
    I switched from Stan's to Caffelatex a couple of months ago, and that has definitely not been my experience. I've already had three incidences where Caffelatex sealed effectively with minimal air loss. Additionally Caffelatex is supposed to be less corrosive than Stan's and can be injected through normal, non core removable valves. In my book, it's a winner!
    To answer the original question, I carry two tubes and a patch kit just in case things really got bad. Additionally, I've had a very positive experience with Maxxis Padrones tubeless tires.
    Jun 2010
    Carry the same stuff you would for a tubed tire
    Pump, co2 cartridge, tire irons, spare tube, patch kit, and boot
    If you flat treat your tire just like it had a tube in it,
    If you have sealant in the tire, remove the tire vertically, and let it sit in the bottom of the tire
    You will also have to remove the valve from the rim
    Stan's seals small holes faster, it is essentially a bunch of little particles suspended in a solution
    Caffee latex seals holes more permanently, dries out to a rubber consistency
    I personally have mixed them
    Sep 2008
    Quote Originally Posted by purdyd View Post
    Carry the same stuff you would for a tubed tire.
    ^This!
    Aug 2010
    How difficult is that? Do you need needlenose pliers or anything like that? By the way, does the thin rubber ring toward the center/bottom of this photo go below the rim?
    Attached Thumbnails Attached Thumbnails road tubeless - what to carry on bike?-img_0068.jpg
    Sep 2008
    How difficult is that? Do you need needlenose pliers or anything like that? By the way, does the thin rubber ring in the center of this photo go above or below the rim?
    The difficulty depends on how tight you put it on to start with. As for your 2nd question, the order is: tubeless valve --> rim --> O-ring --> tightening nut. For the rear tire it is: tubeless valve --> rim --> shim --> O-ring --> tightening nut. See here: http://techdocs.shimano.com/media/te...9830748435.pdf
    Sep 2007
    Same for me. If the Stans doesn't seal it I chuck a tube in and patch the tyre at home.
    Jun 2010
    The valve screw only needs to hand tight, no needle nose requires
    If you use one of the latex sealants and let all of it dry out, it can be a bit difficult
    If you use sealant, get Stan's valves with the removable valve and the syringe for inserting sealant
    Jun 2012
    I carried that aerosol can stuff and it didn't work well at all. I just carries a patch kit and would seal any puncture on the inside. Filled the tire and went. That's it and I never had a problem or needed more.
    Jun 2011
    Is there such thing as ghetto/gorilla tape Tubeless for road bike rims like you can do with MTB rims? Just curious.
    pmt
    pmt is offline
    Aug 2009
    Like others said, mostly the same stuff. Glueless patches, acetone, small cloth, tire levers, and CO2 will fix most of what the sealant won't catch.
    For a bad cut, dollar bill boot and a tube.
    Sep 2008
    Carry the exact same thing you would carry with a tubed setup.
    downhill quickly
    May 2007
    Did this get answered for you? That is the shimano presta for Front wheel. The rubber ring goes above the rim below the nut. You'll notice the Shimano Rear wheel presta has an additional canting piece that is used for rear wheel offset rim (note, rubber ring goes above this part). FWIW, I replaced the Shimano stock parts with Stans removable valve cores (easier for sealant...but as earlier mentioned...I run about 1/2 oz Caflx per wheel...just enough to help bead set up at altitude here in CO) while still using the Shimano rubber rings for F/B wheel as well as the Rear wheel canting parts. Note, those rubber rings help to prevent a "lock down" so you can remove with your fingers. Note: I ride Wh da 7900 c24 TL
    *Edit...Yes, with another look, post 9 answered you well.
    Sep 2007
    I suggest doing a test. let all the air out of the tubeless tire, then see if you can pump air into it with your hand pump. If you can then all you really need is the same equipment that you would carry for a stardard tire/tube setup and you wouldn't necessarily need to carry CO2, unless you wanbt to.
    I suspect that since you bought specific tubeless rims you might be able to. If you can't then you need to carry CO2 inflater (along with all the other stuff that people have mentioned) so you can get the air into the tire fast enough to seal the bead.
    Jun 2010
    Quote Originally Posted by martinrjensen View Post
    I think I must get more flats than most people, or maybe I ride more but
    My experience would be the Stan's are the easiest to seal
    The shimanos, not so much
    If you are going to do the test, try removing and remounting the tire
    Personally, I would not rely on being able to reseal a tubeless tire in the field with just a frame mount pump or co2
    Always carry a tube, a boot, patch kit, and depending on the wheel and your hand strength, plastic tire irons
    I think having co2 is a good idea, and always carry a pump of some sort
    They same thing you carry with a tubed setup
    I frequently have used my tube to help some one else out, more so than myself
    pmt
    pmt is offline
    Aug 2009
    Personally, I would not rely on being able to reseal a tubeless tire in the field with (snip) co2
    I've done it a bunch of times; it's easy.
    Jun 2005
    put a shop air compressor & a bucket of soapy water in a burley bike trailer & hook it to your bike.
    Shop air is the only thing that would lock the bead correctly on the tubeless wheels I had.
    On the upside, think how fit you'll get hauling that up hills. You'll also be a hero to anyone you come across with a roadside flat
    Nov 2010
    Get hands on with it.
    Do the install yourself or your LBS can do it but then ask to unseat the tire and seat it yourself. Some tire/rim combos will be super tight and you need to know what you have. I ride Fulcrum Racing Zeros (2-way) and with Hutchinson Intensive's and I will snap anything other than a Pedros yellow tire lever trying to get the tire seated. Knowing that, I ride with two Pedros yellow tire levers, spare tube, and pump.
    Reputation: ddimick's Avatar
    Aug 2011
    Quote Originally Posted by pmt View Post
    Ditto. I usually use CO2 even in the garage, because I'm lazy. Works great.
