Results 1 to 25 of 25
    Nov 2002
    Rolling Resistance: Clincher vs Tubeless vs Tubular
    I have ridden tubulars and clinchers. I am currently using Mavic Ksyrium ES clinchers with Conti 4000S and Edge 45 tubulars with Conti 4000S. I am considering a set of Campy Shamals with Hutchinson Atom tubeless.
    You can read about anything on the internet. Some say clinchers roll easier than tubulars, others say the opposite. It's pretty hard to make a comparison. Here are a couple of opinoins:
    This is a test of all three tire types:
    http://www.conti-online.com/generato...gp4000s_en.pdf
    In it it says that modern folding clinchers are way ahead of tubulars, and the data in the tables shows that the Conti 4000S Clincher and Hutchinson Fusion 2 Tubeless are lower rolling rolling resistance than any of the tubulars. I dunno, maybe that difference is like the difference in wind resistance between being on the flats or on the hoods. Whatever it is, there is still a difference that catches my curiousity. It's interesting, though, that even though this is from the Campy site, they didn't sugar coat their 4000S tubular's higher rolling resistance.
    Then there's this review of the Shamal tubeless wheel:
    http://www.testrider.com/fly.aspx?la...0&preroll=true
    Again, I dunno, maybe the component companies bought these guys to say good stuff. It doesn't seem like it though. But if they are right, and tubeless are lower rolling resistance than clincher, wouldn't that make them the lowest rolling resistance?
    I plan to run the Atoms without sealant, and carry a tube and inflator. So considering rotational inertia, they should be about like a clincher and tube. Or a tubular with Tufo rim tape. The big difference will be adding 300gm over my carbon tubular rims, argh! I regularly do climbs that are 7-15%. And I will be losing some aero advantage, but does that matter at 20mph? I dunno 3X (I guess I don't know much). But...I will feel a lot better about being able to fix a flat. My son and I have had tubular punctures that wouldn't seal with PitStop or Stans, and needed to call in a ride home from the momma... that would bed a serious issue on a mountain ride where there isn't cellular service.
    And, if the tubeless roll smoother, that will be an added advantage. I guess I will see how it all works out when I put them on.
    Apr 2003
    Quote Originally Posted by gibbons
    It's pretty hard to make a comparison. ...
    Not really. http://biketechreview.com/tires/roll...75-roller-data
    Nov 2002
    Quote Originally Posted by asgelle
    Yeah, it is, especially when resistance ranking data on this site contradicts data from the site posted by Conti.
    Cpk
    Cpk is offline
    Reputation: Cpk's Avatar
    Aug 2009
    I will be interested on how the Shamal's work out for you
    Apr 2003
    So look at the quality of the protocol and data and decide what are the most reasonable results.
    Nov 2002
    Nothing much listed for the tests linked on the Conti site. It says they were done on the Conti equipment, I would hope that their equipment and procedures are reasonably sophisticated! Even if not, I am not looking at the emperical data, I am looking at positions in the list, which are transposed. It's not very confidence inspiring.
    Nov 2002
    Quote Originally Posted by Cpk
    I can't tell if that's sarcastic or not, since there are so many opinions here! Is there something about Shamals I should know?
    My 160lb son (same lb as me) has a set of the gold clincher-only version and loves them.
    Sep 2009
    Sounds like you're obsessing over differences that have no meaningfull real world relevance.
    Nov 2002
    Quote Originally Posted by Hank Stamper
    I know, I know, but I like to obsess. I remember putting Conti Gatorskins on my wife's bike for the supposed extra pucture protection. I later had to borrow her wheels, and the extra rolling resistance of the tires made if feel like I was riding in sand. Having been enlightened, I decided that lower rolling resistance (if there really was any) was more important than pucture resistance for her. I yanked them and put on 4000's. I do think I can feel a difference, but how minute, I don't know!
    Feb 2006
    What you were probably noticing with the Gatorskins was poor ride quality, which is not the same as rolling resistance.
    For the same casing, tubulars and clinchers have about the same Crr if the tubular is very well glued... else the clinchers are better. The tubeless tires currently available have pretty high Crr, which makes them slower than comparable clinchers with latex tubes.
    The tubeless tire have no benefit at all unless you plan to use sealant in them... in that case the sealant will work better than it will in a tube.
    Nov 2002
    Quote Originally Posted by rruff
    I am not bashing your opinion, just pointing out that there are a lot of opinions out there! What you said is completely contrary to what the testrider.com (linked above) review said. And making that comparison, I am not saying that they are the experts, either. We need a government agency set up to do the testing
    Feb 2006
    That's why it's better to go by facts rather than opinion.
    1) Rolling resistance must be tested in the lab or very precisely in the field. You won't feel it unless the difference is huge.
    2) The available tubeless tires have been tested to have higher rolling resistance than a lot of clincher tires with tubes.
    3) Tubes do not slide against the tire casing... if they did, we'd have tires full of rubber powder.
    4) Latex tubes are highly resistant to pinch flatting and add essentially nothing to the hysteresis losses... ie you can get a tire and latex tube that is faster than current tubeless and you can run low pressure if you wish.
    Apr 2003
    Don't you find it strange that the OP refers to the information presented by Al Morrison as opinion?
    Reputation: jwp3476's Avatar
    Jun 2010
    "Crr values are typical for very smooth surfaces - Crr on typical road surfaces may be 50 to 100 % higher
    Tire Pressure = 120 psig unless otherwise noted"
    Hmmm.... What is the Crr value for the chip-seal that most of us have to ride on?
    My issue with this "study?" is that all tires were tested on a smooth surface with 120 psi. I have to use at least 125 psi to avoid pinch flats with clinchers but only need 85-90 psi for tubulars. How does that fit into the model? Also, at 85-90 psi the ride is much better.
    Feb 2006
    I guess the OP like a lot of people, has a hard time judging what to believe. The bike industry is rife with bogus claims. The testrider site is obviously a sales tool... they made a much better ad than Campy or Hutchinson could. That's where the money is... selling expensive "new" stuff.
    $1700 aluminum-rimmed clinchers that weigh 1400g? Why did my 1267g wheelset (with better components I think) cost half as much?
    Apr 2003
    Quote Originally Posted by jwp3476
    Unless you're trying to model performance, the precise Crr value isn't as important as the value relative to other tires under consideration and this won't change with pressure or road surface as long as tires are compared under equal conditions. And since it just got posted again, here's a plot showing how relative position doesn't depend on surface. http://forum.slowtwitch.com/cgi-bin/...engine#2922083
    Feb 2006
    Really, you ride tubulars... or do you mean clinchers without tubes? Also you should show a little humility regarding things that you don't know anything about. It isn't a "study"... it's a series of tests that were performed tediously and exactingly over several years and hundreds of hours. And Al has graciously shared the results free of charge or any benefit to himself whatsoever.
    On a smooth surface the resistance always goes down at higher pressure. The tests are always performed at 120 psi so that tires can be compared to each other. A tire that has more resistance at 120psi compared to another, will also have more resistance at 90psi. On a real road the ideal pressure (for speed) tends to be in the 90-120 psi range, because there is a break point where vibration losses offset the hysteresis losses. You may prefer an even lower pressure for comfort. And you can use latex tubes if you wish to avoid pinch flats.
    Cpark
    Reputation: cpark's Avatar
    Oct 2004
    I have raced with tub/clin since early 80's, and I couldn't tell the difference except the weight difference when I hold it and the slight comfy ride.
    'brifter' is a lame word.
    no benefit at all? how bout being able to run lower pressure and not worry about pinch flats and get better traction? you don't HAVE to run sealant, but i do and i think most road tubeless users do.
    I work for some bike racers
    and a bunch of skateboards
    Cpk
    Cpk is offline
    Aug 2009
    no sarcasm, I was looking at them and the dura 1380's among others
    Feb 2006
    Quote Originally Posted by cxwrench
    Latex tubes... I slammed into a pothole hard enough to dent both rims, but the tubes were fine. I've never had a pinch flat with latex.
    eRacer
    Reputation: jmlapoint's Avatar
    Sep 2008
    Yes!.....no!
    John Lapoint / San Diego
    God is Great, Beer is Good, and People are Crazy!
    Dec 2009
    I was debating whether to try latex tubes (Michelin) but I read they often fail around the valve stem if the rim strip or rim hole has any edges on it at all. I also remember trying some many years ago and they blew out with a long slit in them, but I imagine they have improved and don't do that anymore.
    Feb 2006
    "Blowing out with a long slit" probably means you pinched the tube under the bead. It isn't hard to avoid if you have a good installation technique. As for failing around the valve hole, that seems very unlikely with a fat rubber patch around it... never has happened to me anyway.
    Cpk
    Cpk is offline
    Aug 2009
    Quote Originally Posted by jnbrown
    I was debating whether to try latex tubes (Michelin).
    Just put some on Monday with a new set of Prorace3's. To me that combination is head and shoulders better then the Conti Gp4000s's butyl tubes that they replaced. ymmv
