Have a chance to pick up a very lightly used set for $500 - list on Specialized site is $800. Thinking of replacing the stock Mavic CXP22 wheels that came on my 2011 Secteur Comp. I ride mostly in rolling hills of Central NJ. Nothing tremendous from a climb standpoint, but hills are a part of the typical ride. I'm 170lbs and don't mash ultra-hard - if at all. Just thinking taking 800-1000g or so off the bike might be a good idea as a first upgrade. Plan on using 25c tires on these. Appreciate any thoughts folks might have.
•Front hub: carbon center tube with alloy flanges
•Q/R: 106g/set
•Roval titanium quick releases
•Equipped with Shimano 9/10 speed-compatible cassette body
•Rear hub: CNC-machined alloy body, high quality Swiss-made internals, ratchet and cassette body, and sealed cartridge bearings
•Wheelset: 1495g
•E5 alloy, low-profile, seamless welded and machined rim (21mm W x 24mm H)
•DT Aerospeed 1.8mm bladed spokes
•20/24 spokes: radial front pattern, DoubleDrive rear pattern
•Q/R: 106g/set
•Wheelset: 1495g
