Results 1 to 8 of 8
    Sep 2011
    Schwalbe One Tubeless tire rolling resistance test
    interesting test on the "gold standard" of tubeless road tire.
    Schwalbe One Tubeless Rolling Resistance Review
    rolling resistance is good, but not as good as Schwalbe claims.
    And rolling resistance decreases the higher in PSI you go (and please no more saying "lower psi offers better rolling").
    Nov 2008
    That test is 3 years old. Tire has been superseded by the pro one. Can't buy ones tubeless any more.
    And yes, lower psi leads to better rolling. The ones have very stiff sidewalls and need to be run at low pressure for optimum rolling.
    Sep 2011
    oh! i need to update my info. I wonder how's the pro one compare then? Pro one rolls better at lower psi? Test data?
    Sep 2011
    Ok I did some looking found that on the same site that did the test of the original One, they also did a test on the Pro One, and here's their result on Pro One:
    Schwalbe Pro One Tubeless Rolling Resistance Review
    And it looks like that rolling resistance decreases with increasing pressure. So is there another test that shows rolling resistance decreases with decreasing pressure? To be specific, I'm talking about rolling resistance (something measurable) and not "rolling comfort" (something subjective). So when people say lower psi rolls better, what exactly are they measuring as "better"?
    The new Pro One comes in at 11.0W of resistance, versus the older One at 11.8W
    Interestingly, the article mentions that the Conti 4000S II with a butyl tube has a rolling resistance of 12.2W, but with a latex tube it's reduced to 10.6W, that's a massive decrease in my view.
    Nov 2008
    Every test will show rolling resistance decreasing with increasing pressure for every road tire. They're measuring the hysteresis properties of the rubber and casing.
    There's no standard test to incorporate the effects of real surfaces.
    There is evidence to show that there is a breakpoint at which resistance increases as pressure increases. There is some debate as to what pressure level this breakpoint will be found and its relationship to surface properties and wheel speed.
    Silica has some interesting observations on their blog.
    Sep 2011
    Quote Originally Posted by carlosflanders View Post
    Thank you for the info. AFAIK, all of these rolling tests use the metal drum with roughen surfaces to simulate "road condition". Whether this simulation is accurate, and to what degree, is up for debate.
    What I'm thinking now is to use a wide tire (25mm) but at around the same psi as I use on the 23mm tires (maybe 5-10 psi lower at max). Since the roads i'm riding on are almost always smooth, I don't want to lower the psi by 20+ and create a higher rolling resistance
    Feb 2002
    It's not clear how these "rough drum" tests translate into the actual suspension losses we experience when riding. With the wheel fixed in relation to the drum, there is no "bounce" of the wheel as it hits a rough surface, so drum tests only measure casing flex.
  1. Tire rolling resistance test (again)
    By aclinjury in forum Wheels and Tires
    Last Post: 03-15-2017, 04:39 AM
  2. Velonews publishes tire rolling resistance test results
    By Migen21 in forum Wheels and Tires
    Last Post: 10-31-2016, 12:22 PM
  3. Convert Schwalbe One (or any other) (non tubeless) to tubeless
    By ongbenghui in forum Wheels and Tires
    Last Post: 05-09-2016, 07:15 AM
  4. My rolling resistance test
    By Scott D in forum Cyclocross
    Last Post: 08-20-2011, 07:58 AM
  5. Rolling Resistance: Clincher vs Tubeless vs Tubular
    By gibbons in forum Wheels and Tires
    Last Post: 07-29-2010, 12:03 PM
