Results 1 to 7 of 7
    Apr 2007
    Sidewall puncture
    Okay, just want to be sure, but is this tire repairable? Time for a new tire? Get a new tire and put on the front, and move my current front tire to the rear.
    Feb 2003
    To answer your questions in order: No, Yes, and Up to You.....I have done it but generally not recommended if there is much mileage on the front tire.
    You are very lucky that nail didn't jam in your rear brake and cause more damage than just to the tire.
    Sep 2011
    it's trash, throwaway, IMO.
    Now if it was just one side, and the whole was a bit smaller, then I'd maybe consider patching, as I've patch a torn sidewall before with an inner boot that's superglued to to the tire, and it lasted another 700-800 hundred miles before I ditched
    'brifter' is a lame word.
    New tire, and yes, move the front to the rear if it's in decent shape and put the new tire on the front.
    I work for some bike racers
    and a bunch of skateboards
    Nov 2002
    Quote Originally Posted by Deering View Post
Name:	Tire Puncture.jpg
    I saw a worse flat than that where the nail went through the rim.
    Apr 2007
    Thanks folks, a new tire is ordered. Thanks for the confirmation that the old one is trashed.
    Reputation: Lombard's Avatar
    May 2014
    ^This.^
    You can always get a new tire. You can't get a new body if it blows out and causes a crash and injury.
  1. Repair a tubular sidewall tear/puncture?
    By deviousalex in forum Wheels and Tires
    Last Post: 12-13-2013, 02:36 PM
  2. Do 23c Puncture Resistant tires with reflective sidewall exist?
    By PaulRivers in forum Wheels and Tires
    Last Post: 07-18-2008, 09:51 PM
  3. Which is safer on puncture: tube or clincher ?
    By henry in forum Wheels and Tires
    Last Post: 05-05-2005, 12:47 PM
  4. Tires offering the best puncture resistance
    By elay in forum Components, Wrenching
    Last Post: 11-28-2004, 08:28 PM
  5. Puncture resistance clincher with compliant bead???
    By mellowman in forum Components, Wrenching
    Last Post: 05-18-2004, 07:36 PM
