Page 1 of 3 123 LastLast
Results 1 to 25 of 56
    What the what???
    Jul 2009
    Solid rubber knowledge
    People have tried to invent and market solid rubber tires over the years, but none have been particularly successful. Saint Sheldon makes it sound like any attempt is doomed to fail and anyone who tries is a snake-oil salesman.
    I'm certainly no engineer, but this seems like a solvable problem. Is it a question of planned obsolescence - pneumatic tubes keep you coming back? Is it that no one has been able to balance comfort, durability, weight and price?
    I want my bike to feel like it's riding on air... but never have a flat... and I want my jetpack.
    The Law of Headwinds states: If the ride out is easy... wait.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Materials science needs to come a loooooong way to develop a solid material (that's as light as a gas) and exhibits similar properties. Perhaps once they figure out how to alter physics or find an alternative universe.
    Nov 2014
    Don't forget tunability. If you weigh 125 lbs or 225 lbs, would you run the same "pressure"?
    If you don't want flats and are willing to deal with the goo, tubeless is pretty dang good.
    Apr 2015
    A cartoon I saw in an engineering magazine 15 years ago:
    Frowning man says, "It's 2001! Where's my flying car??"
    changingleaf
    Aug 2009
    Not only is solid rubber significantly heavier it creates significantly more rolling resistance than an inflatable tire. Rolling resistance is due to the energy lost when a tire flexes. The energy that was put into flexing the tire does not get fully recovered when it regains its shape. This is multiplied many times by a solid rubber tire.
    See here:
    https://en.wikipedia.org/wiki/Rolling_resistance
    What the what???
    Jul 2009
    Quote Originally Posted by changingleaf View Post
    See here:
    I was being a little facetious using the term "rubber". I realize a solid tire would need to be a different material. I wonder if there isn't something more along the lines of a stiff gel that would hold it's basic shape (not too liquid), but be able to flex and spring back more than foam.
    I also get there will likely be a weight penalty, but I think most recreational riders wouldn't care too much about that. Rolling resistance, on the other hand, would be an issue.
    I don't know. Maybe it is "unobtainium" after all.
    tlg
    tlg is offline
    May 2011
    Quote Originally Posted by Opus51569 View Post
    Liquid doesn't compress/flex. It'd be 1000x worse than a foam rubber. And a LOT heavier.
    Like I said... once they figure out how to alter physics or find an alternative universe.
    Aug 2013
    Maybe aerogel - not solid gel per se (gelatin), but a porous gel.
    I was pondering this: an aerogel type of material in the tire that had enough strength/durability to act like a run flat tire and also allow for some pneumatic inflation to control/select overall tire hardness. E.g. tire with aerogel acts like a tire with 60 psi in it and user can add air to "pump" up the tire to desired equivalent pressure.
    Reputation: OldZaskar's Avatar
    Jul 2009
    Air is a really good material for the application - it's light, can be "rigid" and is tunable. Pretty cheap too.
    I think the magic should be applied to the tire and/or tube. A near weightless tube that was impervious to punctures would provide the best of all (or most) worlds.
    The perfect tube could end up being better than tubeless. Tubeless is really a pain in the ass attempt at overcoming tubes... because tubes can be heavy and will puncture
    Russian Troll Farmer
    Sep 2016
    Probably the only semi-viable replacement for pneumatic tires is based on a spring-toroid with a rubber tread (similar to the tires on the moon buggies). Light, flexible, but expensive and difficult to install. If it's worth a few thousand to you, I'm sure somebody makes them.....
    What the what???
    Jul 2009
    Price might be prohibitive, but weighed against the value of tubes... the time and energy of changing said tube (sometimes in the cold rain)... the occasional sidewall blowout... possible injury from a flat at speed... and the peace of mind of knowing you can ride flat free...
    Then it gets interesting. I'm not sure it's a thousand dollars worth of interesting...
    Mar 2013
    Quote Originally Posted by bobf View Post
    hehe, we will still be asking that 10-20 years from now.
    Wandering
    Jun 2014
    Quote Originally Posted by OldZaskar View Post
    Isn't that a latex tube?
    All the best,
    Ron
    Central-Western NJ, USA
    There's nothing in the middle of the road but yellow stripes and dead armadillos.
    --- James Allen Hightower
    a real member's member
    Jul 2016
    what's the big deal with getting a flat?
    i've only had one this year. and it feels rather good to be able to patch a tube on the side of the road and get back on my ride within ten minutes.
    What the what???
    Jul 2009
    Quote Originally Posted by blackfrancois View Post
    I'm gonna guess it wasn't dark, raining, and 38 degrees...
    If so, PM me your number and I'll call you to change my next flat.
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    Here you go:
    With bicycles in particular, you need to separate between what's merely true and what's important.
    Reputation: kjdhawkhill's Avatar
    Jan 2011
    Quote Originally Posted by dcgriz View Post
    Here you go:
    I bet that spins up real quickly. Those rims are basically as light as air.
    The internet is a little like a bar, a wonderful place where we can bullsh(t our past, but it also, is full of reasonably reliable sources of information to be used as ammo to call "bullish)t."
    Feb 2002
    Just for reference, people have been working on this issue for 150 years without anything you could call success.
    "I'm certainly no engineer, but this seems like a solvable problem." I am an engineer and I disagree. Unless of course you have a way to convert "business physics" into the real thing. If you do possess that ability, you can become fabulously wealthy by selling weightless and frictionless pulleys.
    Adventure Seeker
    Reputation: Peanya's Avatar
    Jun 2008
    I'm confident if the wheel is reinvented, it'll get applied to the auto industry before it transitions to bicycles. Look how many years it's been since auto tires have used inner tubes! Even today, tubeless is not mainstream, but is reaching moderate acceptance.
    Granted, something totally new could come to bikes first, but it sure as heck won't be by a tire company, but an accidental discovery.
    I'm really looking forward to going tubeless on my next rig.
    I have a single track mind
    Apr 2011
    Quote Originally Posted by Peanya View Post
    Yes, I remember seeing something like this in automobile magazine 25 years ago.
    Apr 2011
    My tricycle way back in my single digit age era had solid rubber tires. I don't remember how it felt riding but it sure was maintenance free.
    wim
    wim is offline
    Feb 2005
    Scroll down a bit to see a World War I era German contingency tire ("Notbereifung") made from steel springs. There were no new bicycle tires on the market at that time. Used ones fetched a small fortune.
    Fahrradbereifung - Wikiwand
    What the what???
    Jul 2009
    You seem to have mastered the ability to continually pee in everyone's Wheaties. Physics, not to mention biology, would suggest that's impossible too... but here you are anyway. So nothing's impossible.
    Jan 2011
    Quote Originally Posted by bvber View Post
    Mine had "air filled" rigid plastic tires. I remember hitting some nasty bumps. And I remember the catastrophic failure of the front after too many hard stops and starts.
    If only they'd been solid unobtainium, I'd still be riding it: RBR fit experts be durned.
    What the what???
    Jul 2009
    Quote Originally Posted by wim View Post
    I think they're on to something. We'll call it "The Tigger"!
  1. Automobile Knowledge
    By bigmig19 in forum The Lounge
    Last Post: 03-25-2009, 04:34 PM
  2. KHS CX-100 - Share the knowledge!
    By CarbonFiberFootprint in forum Cyclocross
    Last Post: 02-06-2009, 06:16 PM
  3. Solid Rubber for Big Riders????
    By snodog1 in forum Wheels and Tires
    Last Post: 05-30-2007, 11:18 AM
  4. Bible Knowledge
    By MikeBiker in forum The Lounge
    Last Post: 05-23-2007, 06:56 PM
  5. Wheel knowledge
    By FieldSandwhich in forum Components, Wrenching
    Last Post: 06-29-2004, 06:45 AM
