Results 1 to 9 of 9
    Jul 2013
    Spoke J-bends not sharp enough????
    Iím building a set of wheels, and Iím finding that the spoke J-bends are not sharp enough! The spokes wonít sit flush. What in the blue hell is going on??????? I swear to god, looking at the J-bends, the angle appears to be less than 90-degrees on all of the spokes I ordered.
    Are there special J-bend angles too????
    These are DT Swiss aero spokes.
    Dec 2006
    Spokes are malleable enough so that they will form to fit the hub when under tension.
    By the time you finish building the wheel, they should be fine. If you find otherwise, post a photo so we can see what you're seeing.
    A wheelist
    Reputation: Mike T.'s Avatar
    This is normal. The spokes on the outside of the hub, during the building phase, need their bend adjusting so you get a more straight line to the rim. I mention this on my wheelbuilding site. When lacing the outer spoke to the rim, bend the spoke down with the thumb as it passes over the hub flange. When the spokes have a small amount of tension on them I tap the bends flatter with a rubber tipped hammer. On my site you can see a photo of the result of this. It shows the two bends of inner and outer spokes after they have been set (in a fully tensioned and properly built wheel) and removed. The is why, if you rebuild a wheel using the old spokes, the spokes should be re-used in their original orientation.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilders with motivation, information and resources.
    Dec 2011
    Precisely this^
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Mike T. View Post
    ^This^
    This is also explained in Roger Musson's awesome e-book which you should get if you haven't already. $12 with free updates for life. Best investment you will ever make:
    https://www.wheelpro.co.uk/wheelbuilding/book.php
    ďStatistics are like bikinis. What they reveal is suggestive, but what they conceal is vital.Ē -- Aaron Levenstein
    A wheelist
    ^This^
    ^^^ That. What I should add to my post above is this - the curvy bend of the heads-in spoke should be pushed flat or tapped flat rather than leave it to spoke tension pulling it flat. If we don't remove this curve by taking the spoke past its plastic yield point, the curve is still there in the metal's memory and it will always want to be reverting to its original state, thus fighting the wheel-build. It should be our goal to "optimize" the spoke's relationship with the wheel in every way we can, depending on the time we can spend on a wheel - which in the case of us home hobby wheelbuilders is relatively unlimited.
    A wheelist
    Quote Originally Posted by November Dave View Post
    Precisely this^
    Thanks for your affirmation Dave. From you, this means lots.
    Russian Troll Farmer
    Sep 2016
    Oh, boy....the joys of building your first wheel......
    "L'enfer, c'est les autres"
    Wheel Builder
    Reputation: cfoster's Avatar
    Dec 2007
    Quote Originally Posted by Waspinator View Post
    Is it the spokes of the hub? Some hub flanges are "too" thick, preventing most J Bend spokes from angling naturally. Or some hubs, (Dura-Ace), have spoke holes that are drilled super tight, so you really have to pull the spoke around and in line by hand, or however, while lacing the wheel, (but definitely before it's built). And in the worst case scenario, some hubs have tight hole drillings, and the holes are not chamfered.
    What hubs did you say you were using?
  1. Handlebars with straight bends in the drops?
    By GiddyHitch in forum Components, Wrenching
    Last Post: 08-13-2013, 05:20 AM
  2. Easton EC90 Aero Bends in Alloy?
    By Marcos_E in forum Components, Wrenching
    Last Post: 01-24-2010, 02:23 AM
  3. Can someone post pics of all three bends of Deda Newton/215
    By Mr. Jones in forum Components, Wrenching
    Last Post: 05-04-2007, 03:08 AM
  4. behind the nut bends with John 5
    By gutfiddle in forum The Lounge
    Last Post: 01-10-2007, 10:05 PM
  5. Stage 17 *Floyd* - he bends but he doesn't break!
    By botto in forum Pro Cycling - Tour de France
    Last Post: 07-20-2006, 10:59 AM
