Results 1 to 12 of 12
    Oct 2009
    Spoke nipple breaking off at the head.
    I had this happen to me for the first time last Saturday as I was climbing up a steep section of a hill, I had just got up off the saddle and was torquing hard of the pedals, this is a wheel that I had built with 4200 miles on it, it was a nds spoke nipple that broke, My question is this very common, being it was on the nds, an it was a Sapim alum nipple, I use brass on the driveside.
    Cleavage Of The Tetons
    Feb 2005
    Yes, it is quite common. Comes with the territory when you build with aluminum nipples.
    That said, I have wheels I built with aluminum nipples that are still going strong after 20 years...
    Oct 2009
    Quote Originally Posted by rideit View Post
    Well ok, it was a first for me, with over 11 years of riding an 38000 plus miles of riding, seeing it was a 32 spoke wheel, I just tighten the nearest spokes beside it and loosen the ds pair a little, was 35 miles from my truck, an over a hour from home. So could have been a big headache.
    changingleaf
    Aug 2009
    To avoid this it's important to make sure the spoke is long enough to thread into the head of the nipple so that the nipple head is not in pure tension.
    Oct 2009
    Quote Originally Posted by changingleaf View Post
    I think it was, that was one of the points Musson stress in his e-book that I used to build the wheel with, but it has been a while since i check it might have been off a little.
    Short spoke is Usually the case when you see it rip the head off
    I've had it happen three times.
    Two of them (one front one rear same wheelset) the wheelbuilder claimed he got some defective nipples and it was happening to a lot of his customers. No idea if that's true. I can't recall if they were threaded into the head all the way or not.
    The third time I attribute to riding in the winter where roads get a lot of salt so corrosion but that's just a guess. This one definitely was threaded all the way in.
    Feb 2003
    I live in coastal West FL, near the Gulf of Mexico. Some of my rides take me out to the barrier islands nearby so my wheels are exposed to salt all the time. The only time I have ever had a nipple break was on pre-built wheels with AL nipples. In 2007, I started buying custom built wheels and specified Brass nipples and since have begun building my own wheels, using only brass nipples. No failures in 11 years. I’ve rebuilt Zipps, both mine and for friends where the AL nipples literally disintegrated as I took them apart to rebuild with Brass. I wouldn’t use anything but Brass if your wheels are exposed to salt on the roads or, in my case, the air and puddles, etc on the islands.
    a real member's member
    Jul 2016
    i saw a broken nipple for the first time recently when i was truing an old tubular front wheel. i noticed some green-colored corrosion, which probably caused it to break.
    Oct 2013
    I'm confused, is the head down at the wheel hub or at the nipple? I don't see any way a nipple could make the head pop, except that if it corrodes the tension drops causing head failure.
    BANNED
    Oct 2009
    It was the nipple head, the spoke was totally intact
    Feb 2006
    This drawing shows why a nipple with a short spoke can break. (from this page on wheel building.)
  1. breaking the law,, breaking the law..
    By anteyeradio in forum Commuting, Touring and Ride Reports
    Last Post: 07-23-2008, 04:22 AM
  2. Shamal Spoke Nipple Type
    By bmcilvenna in forum Components, Wrenching
    Last Post: 07-14-2008, 06:51 AM
  3. Spoke breakage at nipple
    By PaulCL in forum Wheels and Tires
    Last Post: 06-15-2005, 05:00 PM
  4. Spoke alignment with nipple
    By B2 in forum Wheels and Tires
    Last Post: 06-13-2005, 07:08 AM
  5. MAVIC CXP33 + Ultegra F & R Hubs + Nipple Sz?? + Spoke Length ??
    By r_u_armstrong in forum Components, Wrenching
    Last Post: 08-09-2004, 07:12 PM
