Well, initial excitement has turned to disappointment .
I'm having problems with the tyres
Story so far. Wheels came without rim tape, they sent me some two days later.
It was the cloth type and was too wide, I couldn't get the bead to seat because the rim tape was too wide and it moved up this inside of the bead. It was even showing outside the tyre in places. I changed this for some narrower plastic type, this fitted the rim perfectly. However this also slides about when fitting the tyre and ends up covering the tyre bead in places.
I'm using these with tubes and I'm finding it impossible to get the rim tape to stay put.
I could glue it in, but I would rather not if I can avoid it.
Any help would be very much appreciated as I'm close to sending them back.
Do Stans make a special tape for these rims?
Iv''e just had a though, how about using a couple of layers of insulation tape???
Thanks for that, if all else fails I'll get some. It looks like there are two types. One to cover the spoke hole and something else that goes over that.
The spoke hole tape is only 9.5 mm wide which would be perfect. Is this sticky?
Yes I've seen that, but it's too wide, the plastic stuff I'm using is about 12mm wide and that's a tad wide.
I've just covered the rim tape with insulation tape for the moment. this seems to have solved the problem for now..
Another thing about these rims in the tyre bead. It really does give you a wider profile with the tyre. with any of my other rims I can just about get a 25 tyre on the back, with these rims it rubs. Even a 23 is close, very close.
Apart from the rim tape problem they seem like a decent set of wheels.
No problem changing the tyres, ( other than the rim tape) which is plus.
As mentioned previously, you need the 21mm yellow tape. It isn't too wide if it is properly installed. You can look at a video on their website to see the proper installation technique. Remember to pull the tape as you install it.
I have not come across anything else that works well on those rims, although I'm sure there are other rim tape options. Nylon rim strips do not fit tightly, and will move around. An adhesive rim tape such as Velox is too thick (I tried the 17mm wide tape, perhaps a narrower one will work).
Wow. A lot of really bad advice here. From pro wheelbuilders yet.
These are road rims. They are narrower than MTB rims.
They use 12mm Stan's tape.
I know. I have them. Anything wider will potentially interfere with the bead seating. The tape also needs to be sticky enough so that it does not move during tire installation.
The Stan's site is farked when it comes to running tubed tires. Put together by corgis.
It's deadly for a regular tire on these rims to have anything interfering on the bead bed. The whole rim is only 17mm inside. How the f is a 21 mm wide strip going to work? The 12mm tape perfectly covers the curved section without going over the shoulder and interfering with the bead.
The Stans website does say use 21mm tape, however I have ordered the Stans 12mm.
Like you say bikerjulio, its too risky having the tape anywhere near the tyre bead.
And in any case I'm using tubed tyres so all I need to do is cover the spoke holes..
If the tape stay put I'm sorted.
I managed to get the tyres on and I'll be having a short ride on them later.
I suspect a dyslexic corgi typing "21" when he meant to type "12".
The Stan's site has almost zero info on running tubed tires. But it just so happens that 12mm tape is the perfect fit.
I have now successfully been running - Stan's 12mm tape, Conti Supersonic tubes (50g) and PR3's for several months on my Stans Alpha wheels. A very light combo for a near-clyde btw that's holding up well.
I'm only an amateur in all this. I know that regular road rims use 17-18mm tape. Anything wider is going to interfere with the bead socket and IMHO be an accident waiting to happen. So 21mm tape on a conventional road rim sounds like a bad idea to me.
In my first trys with Stan's Alphas and their unusual shape, I used 17mm velox tape and it was impossible to get the bead on the PR's to seat properly. The tire would just blow off the rim because some tape would always be in the bead area. 12mm tape just fits in the semi-circular rim bed without poking up into the bead socket area.
I think Stan's could improve their site wrt advice on road and tubed applications of their products.
One layer of yellow tape is 0.15mm thick. One layer of Velox is 0.55mm thick. A tubeless tire bead is thicker than a standard clincher bead (I've worked with the Hutchinson Intense and Fusions). The rim was designed for that bead to fit with two layers of tape (still only .3mm thick and less than Velox). A standard clincher bead and one layer (one one layer is required if you use tubes) shouldn't have any interference problems.
I don't have experience with too many different combinations of tires and rim strips. I can give a call to Stan's on Monday to clarify.
If someone want to send me a roll of 21mm Stan's tape for free, I'll be happy to try it with my tube/tire combo. And if it works OK I'll take it all back. Meanwhile I'm left thinking that since 12mm works fine, why use anything else?
So I finished up another set of Alphas. To be sure, I did the following. I matched one side of the tape to the edge of the spoke bed. I ran the tape around continuing this. Then once I pushed the tape in place, I too a razor and cut the opposite side of the tape to the other edge of the spoke bed to it doesn't creep up the side. This way the tape goes edge to edge. It was a simple step to add to the process. I still feel more comfortable doing this than using 12mm tape. Tape shifts all the time and I've seen more people have flat tires due to that they from punctures. Best part is it usually takes people 2 or 3 flats in a row before they inspect the rim.
Hi Ergott, when you're calling you could mention that there would be a lot less confusion on the tape issue if their site had a section on road rims running tubed tires. And perhaps warning against Velox type tape on a ZTR Alpha 340, even though they sell it!
See also here that the 12mm tape is "universal" Tape
I searched the site again and came up with nothing. It's basically written around MTB and tubeless.
Well! the tape arrived today, can't fault that for service, ordered Friday evening del, Monday morning.
Anyway the tapes fitted and it works fine. It does say to use two layers due to the higher pressure used in tubed tyres. Which makes me think that 12mm tape is for tubed tyres.
Thank for your input and I'm one happy bunny. I'll be even happier next week when I'm Mallorca with the bike. I can't wait, the weather in the UK's been crap lately.
Because of the bigger tire volume it acts like a 25mm and you should use correspondingly lower pressures. I'm only using one layer of 12mm tape, carefully applied, and 90/100 psi in the tires.
I'm in the 190-200# range myself and all has been fine so far. One of these days I'll have to take a tire off & check how the tape looks.
if using tubes one layer of tape might work for a while if holes are nicely chamfered( sharp edges removed) but why risk it? its @ 5-6 grams per layer!
12mm works well for using tubes, 21mm is best option for alpha rim using tubeless Hutchinson tires, you cant pull hard enough when installing this tape (just make sure the end is well stuck or you can hit yourself in face (trust me :blush2: the harder you pull, it stretches,ever so slightly and lays into the bead channel and the bead hook
almost looks like it was heat shrunk on the rim when done correctly.
i only use one layer for mtb tubeless but this is at about 20-22 psi.
.... if using alpha rim and going tubeless (have to use tubeless tire) use two layers of 21mm tape, pull hard!! then it helps to install tube and inflate tire over night this will make tape better conform to rim cavity. then dont forget to use lots of soapy water to lube tire bead and prevent damage to soft rubber. :thumbsup:
One layer of tape on road rims will blow out. I know I had it happen as I was sitting having a beer on the river in the sun. Sealant blew straight out the spoke holes and it was a total mess.
I have spoken to Stan's in the past and they said it was okay to have some of the tape ride up the side of the rim.
We are talking about 0.15mm of tape here. Like I mentioned above you could always align the tape to one side of the rim and trim the other side so that you have tape from edge to edge in there. Then you will have much less chance of the tape shifting over time and causing the tube to blow through one of the spoke holes.
Enjoy Mallorca, spent 7 days there - did 1000kms, was one of the best weeks ever on my bike.
Had a few problems with the Alpha 340s. a few punctures which let the tyre unhook from the bead and then destroys the tyre, and twice the tubes poping out between and tyre bead and the rim hook.
Well, back from the Mallorca trip, 10 days of glorious sunshine and temps in the 25/30 deg.
560 miles gave the Stans Alpha's a really good work out. Anyone who has cycled in Mallorca will know the some of the cycle routes are pretty crap and the wheels have taken a fair pounding, So far they are really good. They remained true and performed well. The mountains were fantastic, I didn't fly up with the new wheels, but they didn't hinder me either.
I like them, they are like a lightweight version of Mavic's CXP33
And as far as them making your tire a little wider, could you tell?
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
