Results 1 to 23 of 23
    Apr 2002
    wheelbuilder
    Reputation: ergott's Avatar
    Feb 2006
    Biggest issue would be insuring that it's calibrated. For my tensiometer I have a calibration setup so I have true readings for the spokes I use.
    It's basically a copy of the DT. Other things to look for would be quality of the pivots and spring. If there's play in the mechanism it can throw off readings too.
    It's a bit of a crap shoot.
    Apr 2002
    Quote Originally Posted by ergott View Post
    Please elaborate. How could I determine how accurate the calibration is? Since the item is sitting in China, I have no idea about its quality. For my one wheel a decade that I build, there is no utility in my buying a DT branded tensionometer. Since the decade is up, I will soon be building a wheel. This tool and its cheap price intrigues me.
    Cheap tool from China... what could possibly go wrong?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    The Park Tool tensionmeter is only $3 more...and is actually reputasble:
    Park Tool TM-1 Spoke Tension Meter | Jenson USA
    Reputation: Lombard's Avatar
    May 2014
    You will not find "jet engine" precision at this price point, period. In general, tensiometers are good for checking relative tensions in order to get equal tensions throughout the wheel.
    The best thing to do is buy a tensiometer from your shop that is the same as the one they use. Then have them check the calibration relative to theirs. Note any discrepancies and factor that in when you build your wheels.
    wheelbuilder
    Feb 2006
    Quote Originally Posted by daniell View Post
    I wouldn't trust that they took the time to calibrate it at that pricepoint, especially if they include a precision digital or analog gauge. In order for a tensiometer to work, the readings have to be checked against a known spoke at a specific tension. I have a jig set up that I can set a spoke at a known tension using a digital scale. Then I take readings with my tensiometer to see the results. If these measures aren't taken the tool isn't worth anything other than relative tension from spoke to spoke. You can just pluck the spokes and listen to them and achieve the same thing for free.
    wheelbuilder
    Feb 2006
    That's assuming the shop keeps their tensiometer calibrated. I'd guess most don't.
    Ergott. That is so funny we have almost 100% identical spoke tension calibration rigs/tools. I'm even using the same scale.
    I don't think using one that's been tossed around a shop for who knows how long by who knows who as the Gold Standard is a good idea. And you wouldn't have a way of knowing which one was right so not sure what noting discrepancies would do for you.
    May 2014
    It would give you a ballpark idea, nothing more. I would not trust sending it back to Park Tool to get it recalibrated as a gold standard either. As I stated before, nothing about any of these meters has "jet engine precision". It's a freaken spring for crying out loud!
    How would you know which ball park is the right one? And why would you pick the one with the unknown history over fresh from the factory as the ball pack to use.
    May 2014
    Well unless there is a large discrepancy, one could assume (I know that's a dangerous word) that they are both reasonably accurate for our purpose. When I compared mine to my shop's, mine read one graduation lower than theirs. You could also use a known wheel as a reference as well.
    My question now becomes - how would YOU go about proving accuracy of a non-precision device like this? Do you know or are you just being contradictory?
    Russian Troll Farmer
    Sep 2016
    Well, it's cheap, but looking at the pics, it seems you need to use a drop indicator with it. That would make it "not worth it" for me.
    "L'enfer, c'est les autres"
    As Ergott specified.
    Jun 2013
    I've always thought about building a machine to check calibration something along the lines of what you have. Question. How do you know the digital scale is accurate/calibrated.
    wheelbuilder
    Feb 2006
    Scales like these are accurate to a kg or two. It's more than accurate enough for the purpose.
    Oct 2013
    That appears to be a direct copy of the DT Swiss Tensiometer. Note it reads on mm, so you need a chart to convert to actual tension. But I see no mention of any chart provided.
    More on the subject and a picture of the DT Swiss unit here -
    https://www.wheelpro.co.uk/support/tensiometers/
    Agreed in general that unless your individual unit is supplied calibrated, you need to verify/check/calibrate it yourself. Measuring a couple of known good wheels that use generic / similar spokes to what you intend to build can also be a sanity check.
    These tools are good for indicating even tension on spokes, not getting the value to .01% precision. The readings are mostly quite repeatable, provided your technique is repeatable.
    I hung a certified 75lb weight on mine. It was pretty dang close.
    hfc
    hfc is online now
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    A very realistic option is to build the wheelset without using a tensiometer.
    May 2014
    Quote Originally Posted by hfc View Post
    That would work if you have a good ear and know what the pitch should be of properly tensioned spokes. I've tried this and it didn't work for me. Neither did a tuner attached to the stand.
    wheelbuilder
    Feb 2006
    There's more margin for error with higher spoke counts. You can follow Jobst's guidelines for tension in his book.
    Oct 2013
    I think most of us can use pitch to find "exceptions". Pluck all spokes, and find/mark the ones that sound different than the rest. And assume most know the difference between lower / higher frequency when plucked. I usually find a lower one next to or between two higher pitch ones.
    Also as before, if you have a few pairs of known good wheels, you can do a direct compare of spoke pitch with an unknown wheel set for a sanity check.
    Most of these tools rely on the linearity of a steel spring to take the readings. In general, steel does not "go bad" or change properties over time when kept in the elastic region, with small displacements.
    With large displacements fatigue can happen, but even then, the
    number of cycles is enormous.
    Can anyone who uses these tool calibrators share experiences with a tools change in calibration (using the same reference spoke) over time?
  1. Park Tensionometer
    By daniell in forum Components, Wrenching
    Last Post: 09-13-2006, 01:41 PM
  2. Park Tensionometer
    By daniell in forum General Cycling Discussion
    Last Post: 11-09-2004, 03:46 PM
