Results 1 to 2 of 2
    Apr 2014
    Is there a need to cover valve hole with tape when sealing rims with tape for tubeles
    I just finished sealing rims (Kinlin XR31t) with tape andcut out a fairly large opening in tape around valve stem hole so valve stem O-ringcould contact rim directly. I put in anounce or so of Stanís sealant pumped them up to 40 and they seem to be holdingpressure o.k. (went down to 38 psi after 24 hours).
    After, I read that you are not supposed to cut a hole out ofthe tape, but rather just poke a little hole in it.
    Does it matter ? Isthere a difference if o-ring sits against rim or tape ? Any other issues ?
    'brifter' is a lame word.
    I heat up a spoke and melt the hole. Poking or cutting can result in a tear and then problems w/ sealing. The o-ring goes on the outside under the lockring, not the inside.
    ETA:
    Is there a need to cover valve hole with tape when sealing rims with tape for tubeles-tubeless-conversion-9-stem-nut.jpg
    I work for some bike racers
    and a bunch of skateboards
  1. Valve extension sealing
    By BeesMilk in forum Wheels and Tires
    Last Post: 10-03-2017, 05:57 AM
  2. Are valve cover caps necessary?
    By rockridge in forum Beginner's Corner
    Last Post: 06-30-2013, 02:58 AM
  3. Long Valve OR valve extender?
    By AaronMaechand in forum Wheels and Tires
    Last Post: 05-11-2010, 08:51 AM
  4. Valve Extenders or Long Valve Tubes ?
    By Macilvennon in forum Wheels and Tires
    Last Post: 10-10-2009, 07:36 AM
  5. Ultegra Left Crank Hole Cover?
    By DirtTurtle in forum Components, Wrenching
    Last Post: 01-06-2008, 01:18 AM
