Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
  1. #26
    Nov 2014
    Another opportunity to pass on ever buying from the big S.
  2. #27
    Oct 2011
    Sorry for the confusing wording.
    My buddy just bought a new disc Roibaix and it has a special narrower rear hub spacing.
    If you want to buy/ build wheels you need to use their hub or one other mfr makes a hub right now.
    Just saying it is a bit different than others right now.
    Not good/bad/better or worse. Just different.
    Certainly more challenging to borrow wheels in 2017 then it has been in years past.
  3. #28
    What the what???
    Jul 2009
    Thru-axle standards
    I ended up going with prowheelbuilder. I've had pretty good results with them in the past:
    Front Wheel
    Front Hub: HOPE PRO 4 FRONT RED ISO 6 BOLT DISC HUB
    Drillings 32
    Axle Width Thru 12mm
    Front Lacing Pattern: Three Cross
    Front Nipple:SAPIM POLYAX 14MM 14 GAUGE BLACK BRASS NIPPLE
    Front Rim: H PLUS SON ARCHETYPE BLACK 700C FRONT RIM - Drillings 32
    Front Spoke: SAPIM LEADER J BEND BLACK 14G OR 2.0MM SPOKES
    Wheel Build Weight
    900.76
    Rear Wheel
    Rear Hub: HOPE PRO 4 REAR RED ISO 6 BOLT DISC HUB - Drillings 36
    Axle Width Thru 12x142mm
    Stainless Shimano/SRAM 8,9,10 or (ROAD 11spd)
    Rear Lacing Pattern: Four Cross
    Rear Nipple: SAPIM POLYAX 14MM 14 GAUGE BLACK BRASS NIPPLE
    Rear Rim: H PLUS SON ARCHETYPE BLACK 700C REAR RIM - Drillings 36
    Rear Spoke: SAPIM LEADER J BEND BLACK 14G OR 2.0MM SPOKES
    Wheel Build Weight
    1056.48
    Not light, but they should be plenty strong. This was way more angst than it should have been regarding discrepancies in specs and differing standards. I looked at a number of different hub options and some, like Bitex, just didn't have a 12mm option for the front.
    The Law of Headwinds states: If the ride out is easy... wait.
  4. #29
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by Opus51569 View Post
    Front Wheel
    Drillings 32
    Wheel Build Weight
    900.76
    Rear Wheel
    Wheel Build Weight
    1056.48
    Bitex hubs have basically everything (other than 36h drilling) as an option, including 12 mm thru. However you run into issues of what is in stock
    https://www.bikehubstore.com/product-p/bx106f.htm
    Either way though, you have some nice wheels coming.
  5. #30
    What the what???
    Jul 2009
    Ah, but there's another standard... 6-bolt or center lock...
  6. #31
    Nov 2011
    Hey guys, Iím looking at a few road bikes with disc brakes and some have a 12mm front axle while one has a 15mm front axle with Stans wheels, which apparently arenít even made in a 12 mm axle. Do you think the trend for the front axle is in the 12mm direction? Seems like the rear axle is settled on 12x142. Thanks
  7. #32
    I think most road and cx frames have settled on 12mm front axles, MTB usually run 15mm front with a few longer travel forks or inverted forks using 20 mm,
    Any decent front hub should be able to convert from 15 to 12 easily. Stans should have adapters to step his hubs down to 12
    MTB are migrating into boost spacing which is another standard, but the axle diameters seem to be staying the same
  1. Hub Servicing Standards?
    By StefanG in forum Wheels and Tires
    Last Post: 07-01-2010, 05:48 PM
  2. Yes, I know the Euro's have different standards for fashion
    By Creakyknees in forum Pro Cycling - Tour de France
    Last Post: 12-29-2009, 05:02 AM
  3. setting up rollers -- front roller axle vs front hub axle
    By teleguy57 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-03-2009, 06:39 PM
  4. double standards
    By gregario in forum Politics Only
    Last Post: 09-10-2008, 03:12 PM
  5. more on forum standards
    By Fixed in forum Politics Only
    Last Post: 11-28-2005, 02:28 PM
