Results 1 to 25 of 30
    What the what???
    Jul 2009
    Thru-axle standards
    I know the rear axle is 12X142.
    I am assuming my front axle, pictured here:
    is 12mm also? If so, am I limited to only 12mm hubs when it comes time to look at a new set of wheels?
    12x142 are pretty popular as a rear wheel standard, but front wheels seem to run more 15mm hubs... at least the ones I've been looking at.
    Nothing in all the world is more dangerous than sincere ignorance and conscientious stupidity. - MLK
    Seeing more 12mm front now on cross and road. UCI helped dictate the new standard. 15 mm is common on mtbs' and now we have boost. Can't wait until next year
    and to answer your question, yes you need a hub that will be able to adapt to 12mm.
    Boyd Cycling owner
    Reputation: coachboyd's Avatar
    Jan 2008
    In my infinite wisdom that is usually reserved for such things as knowing which pair of knee warmers to wear for a ride, I have been talking to a lot of people about thru axle "standards"
    Here is where I predict it's going to land
    Road/gravel/cx - 12X100mm front - 12X142 rear
    MTB (XC/All mountain/Enduro) - 15X110 front - 12X148 rear (Boost spacing)
    Most hubs that have a 15mm thru axle have come up with solutions to run a 12mm thru axle. Chances are very high that there are some caps that will work to convert your hubs to 12X100 front
    www.boydcycling.com Handcrafted Revolution
    Dec 2011
    There are lots of front hubs available to fit 12mm axles and some that aren't. Shimano seems to be one where you buy what you buy and you can't change it and they don't offer 12 anyhow. That's unusual, most are much much more adaptable than that.
    The P1.5 bit refers to your thru-axle's thread pitch, which will be specific to your fork. So you can't just throw any old "12mm thru-axle" in there and expect it to work. The axles themselves are specifically threaded to work with different forks and frames.
    Boyd is probably right on his "where are 'standards' headed?" estimate. Backward compatibility will continue to be necessary as frames and forks with other "standards" will linger for a long time. For example I have disc cross, road, and XC bikes. Not a single axle among them conforms to that envisioned future standards set.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by November Dave View Post
    Bingo. The only thing quasi "standard" is the axle diameter....everything else is a crapshoot. As with bottom brackets, thank OEMs who wanted to be unique snowflakes.
    All About Thru Axles - Fairwheel Bikes Blog
    Reputation: Lombard's Avatar
    May 2014
    What about the Shimano HB-RS770 and FH-RS770? Aren't they 12mm thru-axle road hubs?
    -- Warren Buffett
    Nov 2014
    Quote Originally Posted by coachboyd View Post
    I'll double up with your prediction and we'll all have baggies full of various endcaps.
    OP, there's also sleeves available online to enable converting 15mm hubs to 12 if you can't find endcaps.
    Dec 2011
    Not at all familiar with them. They must be pretty down range.
    Why don't they make the CX75 in other than QR? Why don't they make anything in drillings other than 32 and 36 and the occasional 28? Why aren't their axles more easily adaptable? Why can't XT hubs be compatible with road 11 speed?
    Some hyperbole there but not a lot. We'd love to do some Shimano builds but they make it awfully hard. Plus there's the whole you can often buy them from wiggle (and now even Excel) or wherever for what we and others who'd like to build with them can buy them for through distribution.
    Not spending too much of my life thinking about that one but I have been trying to figure out how to do more with their hubs and it's just obstacles at every turn, both for builders and consumers.
    May 2014
    Hmmm. It does seem that while Shimano makes some great products, marketing has never been their strong point. They seem to be slow to jump on new technology. I have to wonder if they would rather have others work the kinks out first before they bite. After all, reliability is Shimano's strongest quality. Being the latest and greatest hasn't.
    I don't know why, but according to my bike shop, Shimano has lowered the retail prices that can be charged, but they haven't lowered their wholesale prices. This is really putting a squeeze on shops. It's almost as if Shimano is encouraging more internet sales and throwing brick and mortar shops under the bus.
    -- Warren Buffett
    What the what???
    Jul 2009
    Complicating matters is the fact that the specs for the bike list:
    Fork: Gravel Disc, Carbon Leg, 1.5" Tapered Alloy Steerer Tube, w/ 15mm Thru-axle
    Front Hub: 24h Alloy HighLow Flange, Sealed Cartridge, CNC Disc Mount, 15mm Thru-axle
    Rear Hub: 24h Alloy Sealed Cartridge, CNC Disc Mount, 142x12mm Thru-axle
    So, until I pulled the axle and looked at it, I had assumed I needed a 15mm front hub.
    Boyd Cycling owner
    Jan 2008
    Quote Originally Posted by harryman View Post
    You can't just use a sleeve to convert a 15mm thru axle opening to 12mm.
    The spec for the end cap is
    15mm ID and 21mm OD
    12mm ID and 19mm OD
    If you just made the 15mm into a 12mm hole, your end cap wouldn't fit into the fork correctly.
    May 2014
    You can just use a sleeve to convert a 15mm thru axle opening to 12mm.
    15mm ID and 21mm OD
    12mm ID and 19mm OD
    This makes sense. Sort of like the small mouse can fit through the big hole, but the big mouse won't fit through the small hole.
    So if I wanted to build a wheelset with a 15mm front hub for a 12mm front axle bike, all I would need is a sleeve?
    -- Warren Buffett
    Boyd Cycling owner
    Jan 2008
    Bad phone! Bad phone!
    I meant to type can't, but it turned out can.
    You can't use a sleeve to convert between 15mm and 12mm because the OD has to match the given thru axle size.
    May 2014
    OK, thanks for the clarification.
    Not to seem ignorant, but what does OD mean?
    -- Warren Buffett
    Boyd Cycling owner
    Jan 2008
    Outside diameter
    May 2014
    Outside diameter
    Oh OK, ID=Inside Diameter, OD=Outside Diameter. Got it, thanks!
    -- Warren Buffett
    What the what???
    Jul 2009
    So, with a 12mm axle I should look specifically for a 12mm hub? No end caps. No reducers.
    Dec 2011
    Quote Originally Posted by Opus51569 View Post
    No, not necessarily. Most hubs convert pretty effectively, and so far as I'm aware there is no hub that's compellingly optimized to 12mm versus 15mm or QR. You just want 12mm to be inclusive within the hub's use set, there is no known benefit to having a hub where 12mm is exclusive to the hub's use set.
    Having the wrong specs on the bike like that is just mean.
    CX'er
    Reputation: bikerector's Avatar
    Oct 2012
    I guess some hubs that aren't convertible wouldn't be adaptable simply with a sleeve but many disc hubs come with a bag of endcaps because of the large amount of axle spacing standards. Some that I know are convertible are Velocity, Hope, DT Swiss, etc. You swap out end caps for these to use with different axle standards and I would assume they'll quickly have end caps for 12mm, if they already don't. I think all of the hubs I've purchased in the last 3 or 4 years have 3 sets of end caps for the front: QR, 15mm, 20mm. Shimano CX-75 is the one exception. I believe most of the disc hubs have been marketed at the mtb/cx crowd so I'm not sure how this will translate over to road as most of the convertible hubs take a little bit of a weight penalty compared to a dedicated axle size, lightweight model.
    What the what???
    Jul 2009
    Agreed. They list a different spoke count as well. The wheels are listed as 24 (front and rear) but are actually 28 (front and rear). That discrepancy I was actually glad about, though, since I'm a Clyde. I would have been happier with 32 or 36 spokes actually.
    I get that specs can change during a production cycle, but with technology you'd think it would be a fairly simple matter to update the posted/published spec lists as well. Oh well.
    I see wrong bike specs listed all the time. Now its no build until I see frame, or I just order every axle adapter made when I order hubs.
    Reputation: le duke's Avatar
    Oct 2014
    Get a DT Swiss 240 Fifteen CL.
    Buy new end caps. Install. The end.
    Sent from my XT1585 using Tapatalk
    "You cannot qualify war in harsher terms than I will. War is cruelty, and you cannot refine it; and those who brought war into our country deserve all the curses and maledictions a people can pour out." -WTS
    Oct 2011
    And just to add another challenge/opportunity is Specialized using a narrower thru axle hub on their new Roubaix.
    Jan 2005
    Quote Originally Posted by stevoo View Post
    Spec's website lists all Roubaix bikes as 12x142 rear 12x100 front?
    Oct 2014
    This is confusing. Is this a statement or a question? If it's a question, how is this a challenge/opportunity?
  1. Hub Servicing Standards?
    By StefanG in forum Wheels and Tires
    Last Post: 07-01-2010, 05:48 PM
  2. Yes, I know the Euro's have different standards for fashion
    By Creakyknees in forum Pro Cycling - Tour de France
    Last Post: 12-29-2009, 05:02 AM
  3. setting up rollers -- front roller axle vs front hub axle
    By teleguy57 in forum Racing, Training, Nutrition, Triathlons
    Last Post: 01-03-2009, 06:39 PM
  4. double standards
    By gregario in forum Politics Only
    Last Post: 09-10-2008, 03:12 PM
  5. more on forum standards
    By Fixed in forum Politics Only
    Last Post: 11-28-2005, 02:28 PM
