Results 1 to 3 of 3
    Jan 2016
    Time to run a tougher tire?
    Hey all,
    I have ridden mountain bikes for a while and have recently started riding a lot more road. Working in a bike shop I have had the chance to experiment with a lot of tires and am surprised by the amount of cuts I have gotten so far.
    I recently put on a GP4000 SII at the recommendation of a coworker and haven't had any punctures yet, but after 30 miles I noticed a lot of damage to the tread. There were several cuts, none of which went through the casing. Previously I was running Vittoria Corsa G+ tires, which had multiple cuts through the casing after 200 miles.
    Should I switch to something tougher? Is it normal to have that much damage so quickly?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Not normal...are you riding through fields of glass shards?
    Even a rear should get 1000 miles easy on normal pavement
    Those tires are actually really tough as far as cutting the rubber goes.
    I don't know that to tell you if you can't make it 30 miles. Either you're unrealistic about what a 'cut' that actually matters is or you need to find new roads. Sorry, don't know what else to make of it. A new tire won't help much because you're already using one with tough rubber.
  1. my century is tougher than your century
    By Creakyknees in forum The Lounge
    Last Post: 01-30-2008, 09:01 PM
  2. Democrats tougher in war on terror
    By rufus in forum Politics Only
    Last Post: 02-28-2007, 07:18 AM
  3. Can 28h wheels be made tougher?
    By rossb in forum Wheels and Tires
    Last Post: 01-15-2007, 07:11 PM
  4. Does Cycling Make You Mentally Tougher
    By tellico climber in forum General Cycling Discussion
    Last Post: 11-14-2006, 08:49 AM
  5. Run-Bike-Run-Bike-Run
    By breadrunner in forum General Cycling Discussion
    Last Post: 04-30-2004, 02:03 PM
