Results 1 to 17 of 17
    tiny spoke wrench
    I would like a very small spoke wrench to carry in my jersey tulbag . Any body have any suggestions?
    Would love to find one of these.
    'brifter' is a lame word.
    A normal Park spoke wrench is too big?
    I work for some bike racers
    and a bunch of skateboards
    Boyd Cycling owner
    Reputation: coachboyd's Avatar
    Jan 2008
    Quote Originally Posted by Enoch562 View Post
    That looks like the spoke wrench they used to supply with the Cane Creek hubs (nipples inside the hub). 3T bought that design hub from them for their new line of wheels so you may be able to find something from 3T.
    www.boydcycling.com Handcrafted Revolution
    Sep 2011
    Re: tiny spoke wrench
    No kidding. They're tiny...
    A wheelist
    Reputation: Mike T.'s Avatar
    Make one.
    Get a piece of O1 carbon steel from a knifemaker or knifemakers' supply place. Cut and file to the shape you want. Sand it down & polish it. Give it a simple home heat treatment. Then you have a unique tool, just as you want it.
    Mike T's home wheelbuilding site - dedicated to providing Newby wheelbuilder's with motivation, information and resources.
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    tiny spoke wrench
    Get this and cut-off the length you want.
    http://www.bikebandit.com/msr-spoke-...FYKi4AodQiIA5Q
    With bicycles in particular, you need to separate between what's merely true and what's important.
    I found one of these while doing some trail work, so I ended up removing the 3 way spoke wrench from it. THe wrench is a little thinner on the drive than I want but it will work and it is flat.
    Pedros makes a healthier spoke wrench that has a chain break, but it is chunky little fellow.
    Feb 2002
    File a notch in the wide part of your house key. I've been using my "house key spoke wrench" with no problems for years.
    Banned forever.....or not
    Aug 2002
    I always try to keep things simple.
    Tire levers/spoke wrench/rubberband/ jersey pocket.
    Dogbert.
    I>U
    Reputation: looigi's Avatar
    Nov 2010
    Yeah. A Park 4-sided spoke wrench. Cut off the top half or two thirds of the loop if that's too big.
    ... 'cuz that's how I roll.
    Jun 2005
    Here's my emergency spoke wrench. It's made from 3/16" aluminium plate. That matches the length of nipple flats. I cut the slots (sloppily) with a .125" mill, but since it usually cuts a thou or so over it ends up really close to the most common .127" nipple size (Park black tool) and only needed a little touch up with a file. It weighs about 2 g.
    I'd make it closer to 30-35 mm if I were to do another one although it seems to have plenty of leverage. The added length would make it easier to hold. This was a quick prototype and it works so well that I haven't bothered to make a nice one.
    Sep 2008
    tiny spoke wrench
    Ericm979 - have you tested that tiny thing? Being made of aluminum, I'm envisioning an immediate split (failure) at the wrench on first turn.
    EDIT: on second glance it's beefier than I expected.
    Reputation: froze's Avatar
    Sep 2002
    There are tons of those small spoke wrenches on the market. Some mini tools come with them, if you don't like mini tools Park makes individual sized spoke wrenchs that works great. There are a lot of others too, just google
    Jun 2005
    Yea, I have. On the DS spokes too.
    Remember these are working on aluminium nipples (on most of my wheels anyhow). If the nipples are that tight then any wrench will round them off.
    I have a couple old Ritchey CPR-9 tools which have a spoke wrench slot in what is about 6mm thick alu plate of the main body. I've used that a bunch of times (I break wheels a lot) and on the one tool I use the most the slot is getting a little loose. But it was not as tight on the nipple as my wrenches to begin with. I made the wrench two sided in case one side does strip.
    The Park wrenches are huge in comparison (I should have included one in the pic). I don't know what they weigh but they're not light. And I don't need a shop quality tool I can use to build wheels while out on a ride, just something to retrue the wheel when I break a spoke.
    Oct 2011
    Spoke wrench in multi-tool
    Carry a multi-tool that has a spoke wrench built in.
    e.g. A number of Lezyne multi-tools have this combo chain breaker / spoke wrench:
    Reputation: JCavilia's Avatar
    Sep 2005
    Quote Originally Posted by ericm979 View Post
    "Not light" is a relative term, I guess. I just stuck a Park spoke wrench on my little digital espresso scale. 16.8 grams.
    Have you ever been to Electric Ladyland?
  1. Just got new wheels, should I get a spoke wrench....
    By Dcmkx2000 in forum Components, Wrenching
    Last Post: 05-19-2012, 04:43 PM
  2. Light spoke wrench?
    By Wheelspeed in forum Save Some Weight
    Last Post: 08-24-2010, 08:36 AM
  3. what spoke wrench to get
    By francoaa in forum Shimano
    Last Post: 07-13-2010, 07:14 AM
  4. Bontrager spoke wrench
    By pr0230 in forum General Cycling Discussion
    Last Post: 08-06-2004, 09:21 AM
