Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
Thread: Tire Advice
  1. #26
    Jan 2015
    How would the shop know what the exact spec is? Meaning where the drilling was to be done on the fork so they could check it?
  2. #27
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by gasman777 View Post
    If they don't know how to figure it out, they shouldn't be in the business.
    They could call their Specialized rep and ask. They could send the fork to Specialized for inspection. They could look up the specs from any of the companies that make brakes. It's published info.
    Sram Frame Fit Specifications
    Page 78
  3. #28
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    I actually brought it to a LBS and the we placed the 105 brake on the bike and it had very little clearance. Needless to say I didn't buy them
    One of my Roubaix is the SWorks SL4. Ultegra Di2 and Ultegra brakes. Conti 4KSii 28 on 17c rims (measure around 32mm either way) fit under the brakes but barely fit under the fork crown.
    With bicycles in particular, you need to separate between what's merely true and what's important.
  4. #29
    Mar 2010
    Quote Originally Posted by dcgriz View Post
    I wouldn't ride that bike.
  5. #30
    Nov 2013
    I vote for 4000s ii 25mm front and rear with Latex tubes.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  6. #31
    grizzly moderator
    Feb 2011
    Quote Originally Posted by dracula View Post
    I wouldn't let you anyway
  7. #32
    Oct 2013
    U have covers for your water bottles, OMG.
    BANNED
  8. #33
    grizzly moderator
    Feb 2011
    Trying to keep the horse poop out of my mouth. Amish country.
    ......plus they make the bottles aero......at least 3 watts worth, per bottle 😁
  9. #34
    pmf
    pmf is offline
    Quote Originally Posted by zephxiii View Post
    That would be my advice sans the latex tubes. Conti tires run large anyway. Their 23 is about the same as a Michelin 25. Unless you weigh 300 lbs, you don't need Conti 28 tires. Frankly, I don't get the preoccupation here with large, flat tires. I ride 23's and they've worked just fine for decades.
    Latex tubes are a PITA -- they go flat in a day -- and there's no difference in ride quality, at least that I can notice. I gave them a try years ago and was disappointed.
  10. #35
    More weight though ;)
  11. #36
    tlg
    tlg is offline
    May 2011
    Quote Originally Posted by pmf View Post
    No they don't. They need to be topped off more frequently, but they don't go flat in a day.
  12. #37
    Oct 2014
    ......plus they make the bottles aero......at least 3 watts worth, per bottle 
    Best post ever!
  13. #38
    pmf
    pmf is offline
    Yeah, that's relatively speaking, but you need to top them off every day. A lot of extra pumping for no real benefit IMO.
  14. #39
    Nov 2013
    I top my tires off before every ride anyways so I'm not sure what the difference is going to latex.
    To refrase, with tubeless and butyl tubes, I check tires and top off before every ride anyways.
  15. #40
    Reputation: Lombard's Avatar
    May 2014
    Builds upper body strength.
    -- Warren Buffett
  1. Tire advice please!!
    By trekgirl in forum Wheels and Tires
    Last Post: 03-01-2009, 07:18 PM
  2. Tire advice
    By Biker Tom in forum Wheels and Tires
    Last Post: 09-10-2008, 09:34 AM
  3. Tire advice
    By smw in forum Wheels and Tires
    Last Post: 03-30-2006, 03:55 PM
  4. mud tire advice?
    By morganfletcher in forum Cyclocross
    Last Post: 12-02-2005, 05:18 PM
  5. Need tire advice!
    By mtbykr in forum General Cycling Discussion
    Last Post: 06-25-2004, 12:09 AM
