Results 1 to 4 of 4
    Apr 2013
    Tire hop (Fulcrum Racing 7 and Vittoria Rubino Pro)
    My Rocky Mountain Solo CR7 came with Fulcrum Racing 7 wheels and Vittoria Rubino Pro). When I initially put it together, I noticed that the wheels were true, but the front tire was not. I called support and they sent a replacement tire. When I mounted it, the same thing happened. There is one section on the front wheel where the tire appears to sit deeper! than elsewhere. When I mark this section, remove the tube and the tire, and inspect everything, I don't notice anything unusual. When I spin wheel without a tire, it is perfectly true - even on the inside where the tape is. However, when I put it back together, the same "hop" is present again, albeit at a different section of the wheel. I tried to only partially inflate the tire and wiggle it "into place", but this does not make a difference. It is almost like the tire is too small for the bead to sit in the right place all around the wheel, so it gets pulled in. When I ride it, the hop is so bad that I fear for my life at higher speeds. Has anybody had this problem? What should I do? Different brand tire? Different set of wheels? Thanks.
    Reputation: svard75's Avatar
    Jun 2011
    Quote Originally Posted by cdonner View Post
    I believe it's just that the tire bead isn't seated at that point. I had this issue and someone told me to over-inflate the tire, temporarily, to have the bead seat then deflate to your setting. You can also attempt to work the tire bead in by pressing up at that location as it's being inflated.
    Feb 2002
    You need to talc, soap, or otherwise make the tire bead slippery so that when you pump it to pressure the bead will snap into place. The tire is not seating properly in the rim.
    Apr 2013
    Overinflating did it!
    Thanks for this tip. I sort of figured this out myself, but I just had not inflated it enough. Once I kept pumping, the bead eventually snapped into place, as Kerry suggested, and the tire sits perfectly now.
  1. Michelin Lithion 2 vs Vittoria Rubino Pro 3 tire
    By RoadrunnerLXXI in forum General Cycling Discussion
    Last Post: 3 Weeks Ago, 12:03 AM
  2. Tire suggestions, similar to Vittoria Rubino Pro Slick
    By vivid in forum Wheels and Tires
    Last Post: 10-12-2012, 04:41 PM
  3. Michelin Lithion 2 vs Vittoria Rubino Pro 3 tire
    By RoadrunnerLXXI in forum Wheels and Tires
    Last Post: 06-04-2012, 04:20 PM
  4. Vittoria Rubino Pro 111 road tire
    By horvatht in forum Wheels and Tires
    Last Post: 05-18-2012, 06:49 AM
  5. Replies: 6
    Last Post: 07-05-2011, 07:28 PM
Sea Otter Classic
Contest
