Page 4 of 4 FirstFirst ... 234
Results 76 to 93 of 93
  1. #76
    Reputation: velodog's Avatar
    Sep 2007
    And.... do you think the energy moving their arms somehow gets returned into the bike as forward motion?
    If so, could I shake may arms to make me go faster?
    Shake your arms all you want, I'm saying that the movement of their arms is a direct result of the bikes bouncing over the cobbles, suspension losses. A visual of the "resulting heat in the frame or the human" that DrSmile deems unlikely.
    Too old to ride plastic
  2. #77
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    I was agreeing with you, and adding to what you said. Energy transmitted vertically isn't returned.
  3. #78
    Sep 2007
    Sorry, I misunderstood, I just reread what you wrote, and see that now. Excuse me.
  4. #79
    Reputation: Lombard's Avatar
    May 2014
    You're kinda thinking correctly. But the tire need not leave the ground. If you and the bike deflect upwards 1mm, you don't leave the ground. But it takes significant energy to move 150+lbs up 1mm. Now repeat thousands to tens of thousands of times.
    ........and then think of all the tens of thousands of times that energy was wasted going up and down rather than propelling you forward.
  5. #80
    May 2014
    So you saying/thinking rumble strips don't slow down a bike? Go try it.
    Oh yeah, they slow you down alright - especially when hitting them at over 20mph. It stopped her on a dime and she was sent away in an ambulance.
  6. #81
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    There are literally gravity batteries that function on this fundamental physics principle. Energy spent moving an object upward against gravity is ALWAYS returned when it comes back down. A bouncing ball loses no energy in it's vertical motion, it loses it only through compression of the ball itself and through aerodynamic loss, plus loss by deformation of the surface it bounces upon.
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't %^&* like that since I was an altar boy" Hank Moody
  7. #82
    Sep 2007
    Quote Originally Posted by DrSmile View Post
    Granted, the energy is not lost, but it is lost to forward momentum.
  8. #83
    tlg
    tlg is offline
    May 2011
    Well you could build a gravity battery into your bike to recapture the vertical energy. Then use it to power a motor to transfer it to forward motion.
  9. #84
    Matnlely Dregaend
    Jul 2006
    If it converts horizontal energy to vertical energy then I would argue that it must be returned to forward momentum on it's downward return, why would it only work that way on it's way up?
  10. #85
    Matnlely Dregaend
    Jul 2006
    Let's patent a bounce battery. The BMX guys would love it.
  11. #86
    tlg
    tlg is offline
    May 2011
    Your argument would be unequivocally wrong.
    The horizontal force is transferred to vertical because of bumps. You'd need perfectly placed bumps to transfer it the other way.
  12. #87
    Oct 2013
    The problem is certainly an interesting one to think about, especially from a physics point of view. But remember we are not dealing with rigid, linear bodies in a zero loss environment.
    From a practical point of view, most would agree, even without trying it - normally riding over a parking lot full of wood 2 X 4s spaced every 2 feet at 10 mph would take a lot more power (watts) than maintaining 10 mph over the same "smooth" distance with no bumps. In a perfect situation with no losses, it would, "in theory" be the same.
    Now let's change the "mind" test slightly - say we space the 2 x 4's every 10 feet, and we do 2 tests
    1) one where cyclist rides normally over the 2 x 4s at 10 mph - measure power
    2) another where he bunny hops expertly over the 2 x 4s at 10 mph, missing them entirely - measure power.
    Again, most cyclists would correctly guess that doing 2) would take less power.
    So why?
  13. #88
    Sometimes common sense shouldn't be ignored. But hey if you want to build a case that rough roads are as fast as smooth roads then have at it.
  14. #89
    Nov 2013
    Quote Originally Posted by Z'mer View Post
    So why?
    Measure the power with what? Bike power meters aren't going to be able to measure the energy/power needed to lift the bike several inches off the ground to clear the 2x4s.
  15. #90
    Oct 2013
    Quote Originally Posted by cooskull View Post
    Yep, but for that sake of this test, assume that the power needed to lift the bike is somehow measured, and found to be very low in comparison to the power difference measured by a power meter in both test cases.
    I'm trying to point out that bunny hopping is very much like having a fine tuned suspension that would need to lift only a small weight (say the bike at 18 lbs) to clear bumps versus needing to lift the bike + rider weight (say 190 lbs) to clear them.
  16. #91
    Sep 2007
    Why not find a freshly resurfaced road with rumble strips cut into the shoulder and ride, say two miles, on a bike with a power meter, on the rumble strips for the whole two mile at a constant power. Then go back and ride the same two miles, in the same direction, at the same constant power, except this time riding on the fresh smooth surface beside the rumble strip and see which is traversed at the higher speed.
  17. #92
    Nov 2013
    I'd hate to be the guy riding 2 miles of rumble strip... at least if you ever wanted to have children in the future
    Anyways, don't forgot to pump up the 23c tires to 140 PSI for maximum efficiency
  18. #93
    May 2014
    Sometimes common sense isn't so common.
  1. Velonews publishes tire rolling resistance test results
    By Migen21 in forum Wheels and Tires
    Last Post: 10-31-2016, 12:22 PM
  2. Lighter tire or less rolling resistance?
    By bvber in forum Wheels and Tires
    Last Post: 05-08-2012, 09:31 PM
  3. My rolling resistance test
    By Scott D in forum Cyclocross
    Last Post: 08-20-2011, 07:58 AM
  4. tire rolling resistance
    By PoorCyclist in forum Wheels and Tires
    Last Post: 06-02-2011, 05:56 PM
  5. cross tire rolling resistance
    By MIN in PDX in forum Cyclocross
    Last Post: 07-08-2008, 12:05 PM
