Results 1 to 25 of 28
    Apr 2011
    tire sealant for Tubulars
    Anyone here using any type of sealant in their tubulars?
    I have Vittoria Corsa Evo CX's, no removable core so I'm wondering if theres a sealant to use or should I not bother?
    The wheels are Bora One's if that matters, or anyone asks
    eBay is finally cleaning up its act.
    Report fake Pinarello products/decals on eBay
    just click: report item
    Reputation: kevhogaz's Avatar
    Jul 2007
    I've seen people on other forums using Stan's with pretty good results.
    As a recent convert to tubulars, I'll be watching this thread to see if any body else has some ideas.
    Reputation: Pwnt's Avatar
    Aug 2006
    I use Stan's. But also keep in mind I am a new tubular user so my opinion does carry alot of weight. I have only exprienced one flat on tubular and it was a totally blow out. No amount of sealant in the world coulda fix it. Which has effected my complete trust in tubulars. I only ride them in crits now. To afraid of being stranded in the middle of no where.
    Ghetto.
    Jul 2007
    Quote Originally Posted by Pwnt View Post
    I plan on carrying a folded, glued tire, just in case.
    Reputation: jwp3476's Avatar
    Jun 2010
    I have used Tufo sealant and Vittoria Pit Stop for thorn punctures. The downside of using sealant is that it clogs up the valve core after a while. I had to remove the core to clean it so I could pump up the tire.
    Reputation: foofighter's Avatar
    Dec 2008
    there's been a lot of threads/post to this subject and i've searched high and low to find stuff and a lot of the experienced guys have used surgical/aquarium tubing with an oral syringe with Stan's to push the fluid past the valve with success. Others have gone the direct method with an actual needle syringe and injected it into the tubie and then pumped it up and let the stans do it's magic.
    Other creative things have been to take apart a hand pump remove piston from chamber, fill w/ stans, put the piston back in and put the pump on presta and pump into the tubie.
    YMMV, i am going to do the surgical tubing and oral syringe to inject into my inner tube on my clincher to test. My Conti Sprinters have a removable core so that's not going to be a problem to add stans to that tubie
    @Pwnt: your situation even if you had clinchers wouldnt it have resulted in the same situation? being completely stranded? if you cut a tire on a tubie you pretty much cut the tire on a clincher as well rendering both useless. I plan on folding a pre-glue spare wrapping it and strapping to underside of saddle on rides.
    Ride More Talk Less
    - Caletti Cycles Custom Steel
    - 11 Nashbar Steel CX
    Terminal Pholocity
    Apr 2011
    yes I've looked high and low too but I want the easiest solution without doing the syringe thing or buying other tubs with removable cores.
    Im really looking for a solution like the Vittoria pit stop but with better overall flat qualities, possibly as a preventative flat option. Something like Tufo's extreme with a Vittoria Pit Stop presta applicator.
    If such thing even exists
    Smiling Wolf Puppy
    Reputation: Big Bad Wolf's Avatar
    Jun 2007
    Is it normal that tubulars slowly lose air over a couple of weeks ?
    In case of a flat I have vittorias pit stop with me. You can use it on a regular valves
    Jun 2010
    My Conti Sprinter tubulars loose 2-3 pounds per day. The tubulars with latex tubes will loose even more.
    You can use the Vittoria Pit Stop with any valve since you don't take the valve out. However, after you have used the pit stop it may become more difficult to pump up the tire since it may clog the back of the valve core.
    Smiling Wolf Puppy
    Jun 2007
    Thanks I was a bit worried.
    In reference to the Pit Stop. Would you use it as a precaution or only in case of flat? I also use it on my clinchers and it does get you home provided you get all the goo in ;)
    Reputation: AvantDale's Avatar
    Dec 2008
    I guess you can use the Pit Stop as a preventative. Its looks to be just foam, I'm not sure how long it would remain liquid. Seems like it would harden fairly fast.
    I had to use my Pit Stop a few weeks back. It got me the 20 miles I needed to get home. The tire was flat the next morning. Make sure you bring CO2 or a pump along with the Pit Stop. The sealant will only fill the tube to about 30psi. The rest of the air, you will have to use a pump.
    I run Vittoria Corse CX tubulars and the latex tubes will bleed out 15-20 psi over night.
    I've got an 80 mile ride this weekend...not sure whether to put my clinchers back on or just carry two cans of Pit Stop.
    Oh yeah...make sure you let all the remaining air out of the tire and put the valve stem at the 12 o'clock postion before injecting the Pit Stop. If you don't...you may end up with more foam on your hands than inside the tube.
    Smiling Wolf Puppy
    Jun 2007
    Thanks for the info
    Yes I know , I always have a full-size pump with me.
    Oct 2005
    If I put in Stans as a preventative measure, it says it only lasts for a few months. What do you do after a few months?
    I just finished a 6500km bike ride across Canada. I raised over $100 000 for kids with cancer. Read all about it: http://www.cyclingforcancer.ca
    Dec 2008
    add more...
    Ride More Talk Less
    Terminal Pholocity
    Apr 2010
    I find when I get flats (rarely), I usually get rather significant holes, the type the lighter-weight stuff won't seal too well, especially at the pressures I tend to run (120 psi). I've had good luck with the Tufo extreme sealant, though. Haven't tried Pit Stop & the other brands.
    I also ride Tufos pretty much exclusively. The removable cores make injecting the sealant a snap. The only drawback with Tufos (and some other tires) is that the inner-tube is bonded to the casing, which itself is one-piece, making it extremely difficult - nigh impossible - to repair the way we used to repair tubulars back when they were still called sew-ups.
    Hell is other posters
    Mar 2011
    Quote Originally Posted by Big Bad Wolf View Post
    If the tube is in latex yes. Same thing happen if you use a latex inner tube with a clincher.
    Sep 2002
    Quote Originally Posted by PsychoMike View Post
    No removable valve core but you can unscrew the entire valve stem from the tire. You would just have to add the sealant before mounting the tire.
    Oct 2005
    Quote Originally Posted by foofighter View Post
    add more...
    I assumed that the 'goo' would harden in the tires. Does it just evaporate?
    Reputation: Nielly's Avatar
    Sep 2009
    The vittoria cx's have a removable valve. The whole aluminum shaft that includes the valve is removable from the base so you can fit longer versions made for deep section rims. You should then be able to get the sealant into the tube using the shringe type dealy. I just carry pit stop and and extra tire in case that doesn't work
    Dec 2008
    You'd have to put the sealant in before gluing the tire on. Its just a nub that the valve stem screws onto. Once glued on...it'd be extremely difficult to put fluid in...especially if you have deep wheels.
    Dec 2008
    Quote Originally Posted by iherald View Post
    from my experience with stans w/ mtn bike tires, it leaves a whitish residue inside not necessarily gooey
    Ride More Talk Less
    Terminal Pholocity
    Apr 2010
    I just cut open an old Tufo the other day and that's exactly what I found (after having used the Tufo sealant): a thinnish residue the color & consistency of slightly gooey mozzarella.
    Dec 2008
    Had a full blown puncture in my tubular today, but the Stan's I injected a few days ago sealed the hole. I heard a hiss and saw sealant spraying out of the tire. I kept riding...and within a few seconds the Stan's started working. There was less and less fluid coming out to where the puncture was completely sealed. I lost about 20 psi before the hole sealed. I aired the tire back up to 115 and so far the air is still holding.
    Here is the cut,
    Dec 2008
    NICE that's what i'm talking about, how much did you add in there? i think i put close to 2oz in mine
    Ride More Talk Less
    Terminal Pholocity
    Jul 2007
    I agree!!! I was gonna use 2-3 oz. in mine, that pic makes a lot less worried about riding my tub's!!!
  1. Tubulars and Sealant ??
    By on yer left in forum Cyclocross
    Last Post: 08-07-2010, 04:38 PM
  2. Tubulars and Sealant ??
    Last Post: 08-03-2010, 03:43 AM
  3. Tubulars and sealant
    By Tecopa Red in forum Wheels and Tires
    Last Post: 04-07-2010, 06:19 AM
  4. Sealant for tubulars
    By Unoveloce in forum Cyclocross
    Last Post: 08-23-2007, 10:34 AM
  5. Vittoria Tubulars and Sealant
    By gregdogg62 in forum Cyclocross
    Last Post: 01-29-2007, 04:25 AM
Sea Otter Classic
Contest
