Page 1 of 4 123 ... LastLast
Results 1 to 25 of 79
    bas
    bas is offline
    Jul 2004
    Tire Size? 23/25/28mm?
    What happened? I've been riding 23mm since like 2002, and 25mm was for heavier people, now new Trek Bikes come with 28mm ?
    What did I miss being out of touch for so long?
    (2003 Trek Madone 5.2)
    Jul 2017
    I'm in the same boat as you are, man. I got into riding in 2002 and quickly got pretty seriously into it, but had to stop around 2008. Just now getting back into it and so much has changed. Don't worry too much about it, though- my old bike still does plenty fine. It's funny to take a bike currently valued at around $500 on a hilly century and finish over 2 hours in front of a guy about my same age on a $12,000 Pinarello. Don't believe all the new marketing hype, though some things are worth a try. Everything in moderation!
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by TDFbound View Post
    It's very satisfying to take a bike currently valued at around $500 on a hilly century and finish over 2 hours in front of a guy about my same age on a $12,000 Pinarello.
    Fixed.
    I remember a couple of years ago, a delicious moment when I toasted a 30 something guy with $3,000 zip carbon wheels climbing this steep hill while I was on an entry level wheel set. He had a look on his face like "that old geezer passed me?!?!?!"
    You can't buy speed. It's all in the engine.
    -- Warren Buffett
    'brifter' is a lame word.
    Quote Originally Posted by bas View Post
    We finally started paying attention to physics and facts.
    I work for some bike racers
    and a bunch of skateboards
    Jul 2017
    Don't forget the flood of marketing hype surrounding wide tires and wheels. The bike I am about to buy comes stock with 23mm internal width rims and 30mm tires. I'm basically stuck with 28mm tires or bigger until I get a different wheelset. Can't pass judgment on it though as I haven't ridden it yet.
    May 2014
    Well let me put it this way. I have ridden 23mm, 25mm and 28mm tires. I notice no difference in speed or effort necessary on the bike. The only thing I notice is the 28mm tires ride the nicest/smoothest.
    Bike makers convinced the consumer for years that they would go faster on the skinniest tires and rims pumped up to the highest pressure they could stand. Many bikes were made such that not much else would fit. Then, as CX put it, people finally started paying attention to physics and facts. Wheels and tires got wider. But of course, those bikes with narrow stays can't accommodate them. So that means another bike purchase. How clever!
    But as with most trends, eventually we will reach a point of diminishing returns just like we did with skinny rims and tires. Wider rims and tires are nice. But how wide do we really need to go? I could feel the difference in stability when I went from 14mm to 15mm rims. I could feel the difference from 15 to 17. However, I felt no difference when I went from 17 to 18.
    -- Warren Buffett
    Jul 2017
    Yeah, in any industry there always seems to be a case of some marketer or designer saying "well if a little is good, more must be better, and the most must be the best!" which often produces some silly products for a short time while a happy middle ground is found.
    Trust me...wider (to the extent we're talking here) is better.
    Really.
    May 2014
    Spot on!
    -- Warren Buffett
    May 2014
    Really.
    Yes, agreed. The new gravel bike I just bought has 23mm rims (internal) and 36mm tires. Took a test ride which lasted awhile because I didn't want to stop riding it! I was sold!
    However, I have my doubts about going wider than this. Don't know what your opinion is of this, but I read an article recently (I think it was Slowtwitch) where they discussed rim sizes for gravel riding. They said they don't recommend rims wider than 21mm due to the increasing possibility of sidewall cuts.
    While it's generally accepted that a tire shaped like a lightbulb isn't the best situation, it's probably not a great idea to have a tire shaped like a bell either.
    I'd be interested to hear your take on this, CX.
    -- Warren Buffett
    Feb 2002
    The go-to reference on this is Bicycle Quarterly magazine. They have done a bunch of tests showing that what counts for speed is a very compliant casing (properly inflated) and NOT rock hard narrow tires. This is because high pressures result in a bouncing effect any time the tire contacts road surface imperfections and that energy is lost. A lower pressure tire is able to absorb that surface roughness and reduce those suspension losses. On perfectly smooth pavement (like a velodrome) high pressures make sense. On the road, wider tires at lower pressures mean more comfort, longer wear, better traction, and no loss in speed. Obviously there is a limit on "wider" but the general recommendation is that if you have to pump to over 100 psi/7 bar to prevent pinch flats then you need wider tires.
    May 2014
    I agree with you completely here. Though more to my point was that is doesn't seem prudent to be running ultra-wide rims on the ultra-skinny tires of yesteryear. For example, on my Synapse, I am now running 18mm rims and 28mm tires. If I wanted to run wider rims like the HED Belgium+, which is 21mm, I would need to drop back down to 25mm tires in order for the tires to fit between my chain stays.
    Old habits die hard. Most people I ride with still think more pressure will always make you faster. And I can assure you that is not the case with the condition of the roads in my area! As I have said before, there is a very good reason Mr. Dunlop invented the pneumatic tire and it's not so people could roll on rocks.
    -- Warren Buffett
    What's really funny, in a sad sort of way, is getting chased down and passed by someone in an imaginary race with me.
    I've passed very expensive bikes, cat 1 cyclists, and sports cars and been passed by grandmothers towing children, skate boarders and walmart mountain bikes. I wasn't racing any of them at the time so what does that mean? Nothing.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    I want to know what I'm doing wrong to NOT notice the difference in comfort between 23s and 28s. I will probably switch to 24s or 25s when I run through my current stock of tires but that will take up to a couple years...
    I rode a bike over vacation that was meant to be an endurance frame... came with 28s on it. I did some rides with my own wheelset which had 23s and then also ran the 28s and could honestly not tell the difference one bit on some pretty bumpy roads. And to boot, overall the bike was no more comfortable than my usual ride which is "race geometry" etc.... at the end of the day there's a lot of marketing going on...
    changingleaf
    Aug 2009
    If you don't notice anything right away, the difference in comfort will likely be noticed after many miles in the saddle on imperfect roads.
    Or, you have too much air pressure in the larger tires which will significantly reduce the benefits of the larger tires.
    May 2014
    Quote Originally Posted by jetdog9 View Post
    Some of us are more or less sensitive to these things than others. And as Pete implied, if you are running the same high pressures in the wider tires that you're running in the narrower tires, you might not notice a difference.
    -- Warren Buffett
    Nov 2014
    Since I have no way of measuring or interested in running accurate tests , I can't tell you if I'm truly faster or slower on 28/30s than I was on 23's. I can tell you it's more comfortable and after 3 years on bigger tires, I have no intention of going back. I get where I'm going at a speed that is dependant on my fitness and intent, and is more enjoyable. The biggest eye opener for me as far as tire pressure goes is when I was riding them at 85 psi when I first switched, neglected to check my pressure, went for a 75 mile ride with big climbs in the alps and realized the next morning that they had been in the 50's and hadn't felt low at all. Now I run my 30's at 50 up front and 55 in the back, I weigh 190.
    Apr 2011
    That difference is supposed to be on the rolling resistance.
    Quote Originally Posted by changingleaf View Post
    Also possible is that you're not comparing apples to apples. Going from 23mm Vit Corsa, for example, to 28mm isn't going to be an improvement with just any 28mm tire.
    Reputation: bobf's Avatar
    Apr 2015
    Yup. My take is that tire width is not the primary factor but tire pressure. When I switched to 25mm it felt the same as 23mm. When I dropped the pressure by 15psi or so it was an immediate revelation. Lower psi makes the difference, and wider tires make it safe.
    WA outdoor enthusiast
    Mar 2002
    Talking road bikes and light gravel bikes below, with tubular tires. --
    I have only a little experience on Schwalbe S-1 tubular, 30mm. My 200# body likes 70psi r/65f. But i can see lower pressures, esp if the route is familiar and generally smooth.
    I agree with many that the diff between 23&25 can be minimal, and is highly dependent on the tire pressure and between tire models. Again the 25 to 27mm, is incremental given the same variables of pressure & tire models. For me, those 2 incremental jumps make a world of added comfort for longer rides between 22mm Conti Sprinters @ 105# and 28mm Veloflex Valanderan (sp?) @ 90#.
    bas
    bas is offline
    Jul 2004
    Interesting posts.
    I did pick up a Michellin PR4 service course 25mm for the rear (not the endurance) to try out.. I've ended up with bubbles in at least 4-5 rear tires over the last few years with the PR3/23mm... - and one even blew out while I was relaxing at home. That scared the crap out of me and caused ringing in my ears!
    I see someone is looking 32's: Light road bike frame that can accommodate 700 x 32 tires?
    May 2014
    I think I would have sworn off Michelin after the second tire that had a bubble. You kept buying these?
    -- Warren Buffett
    a real member's member
    Jul 2016
    What happened? I've been riding 23mm since like 2002, and 25mm was for heavier people, now new Trek Bikes come with 28mm ? What did I miss being out of touch for so long?
    experiment if you will and ride what you like.
    i've been on 23s since i started riding again and won't be changing anytime soon.
    Quote Originally Posted by blackfrancois View Post
    There are lots of people that ignore technology and/or realizations of what is actually better in some way. They either figure it out eventually or they don't. Doesn't really matter, they will still ride and be happy.
  1. Secteur maximum tire size? (28mm)
    By framesti in forum Specialized
    Last Post: 07-26-2013, 08:50 PM
  2. Tire Size Difference ...28mm or 32mm
    By stunzeed in forum Wheels and Tires
    Last Post: 02-05-2011, 06:26 AM
  3. What is the ideal fender size for 28mm tire?
    By Bike4Obama in forum Commuting, Touring and Ride Reports
    Last Post: 11-24-2008, 11:07 PM
  4. Road bikes that will fit a 28mm tire?
    By BikeRider in forum General Cycling Discussion
    Last Post: 01-09-2007, 09:06 AM
  5. Please suggest a 25-28mm tire....
    By DIRT BOY in forum Wheels and Tires
    Last Post: 11-19-2006, 05:35 AM
