Results 1 to 20 of 20
Thread: Tire width
    Jan 2015
    Tire width
    My roubaix will fit up to 32s and I'm considering riding bigger tires than my current 28s (continental 4000s) so I can drop the psi some. Anyone know of a good chart comparison for these wider tires vs brand, etc. (listing rolling resistance, etc). Everything I find is 23/25/28 comparison, not 28+
    Reputation: GlobalGuy's Avatar
    Jun 2015
    Not sure I understand exactly what info you are seeking...probably just having a senility moment.
    The same model of tire properly inflated means wider tire has less rolling resistance. (You will be faster on the 32 than 28, etc.) As for whether one brand of the same style of tire is a faster tire the difference is measurable with instruments but not so much to effect rolling speed.
    Hope the above helps.
    May 2007
    Here's the ubiquitous frank berto chart.
    If i'm riding my road bike a bunch (i'm a **** roadie) i end up tweaking the pressures up/down about 5 psi. Your weight distribution affects handling, so it's not gospel.
    If you need more then google it and ask a more specific question. Too open ended otherwise.
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    Quote Originally Posted by GlobalGuy View Post
    I have heard this several times, but every time I try to verify it I can't find the information.
    Specifically, if you use the chart Bubble posted to select tire pressure for a given weight, the decreased pressure of larger tires increases their rolling resistance until they exceed that of the smaller tire.
    Jan 2015
    Quote Originally Posted by bubble View Post
    https://i2.wp.com/intheknowcycling.c...able.png?ssl=1
    im looking for something like this but for wider tires. I'd like to see how the different tires compare between brands, etc.
    changingleaf
    Aug 2009
    This has lots of rolling resistance information.
    https://www.bicyclerollingresistance...d-bike-reviews
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Kontact View Post
    I have not found this to be true. It's pretty much a wash.
    The misconception about wider tires having less rolling resistance is that most people forget the last part of that sentence "at the same pressure". Since the correct pressure will be less in a wider tire, that makes it, as I said, a wash.
    It's all useless information either way because it assumes everyone rides on whatever surface the test were conducted with and that ride weight is the same. And then there's aerodynamics and ability to handle the bike.
    A rock hard 23 will never be as fast as, say, 32 reasonably low PSI over cobbles. And of course the opposite would be true on a nice track. Between those extreme picking a tires is art not science IMO. There are too many variables in conditions of most real world riding conditions to use science for blanket statements.
    Reputation: velodog's Avatar
    Sep 2007
    Maybe not exactly what you're looking for but this blog post would probably be worth your time to read. It's worth reading all the responses to the blog as it is a good discussion.
    The blog is biased as Jan Heine is the Compass it is still worth a read.
    https://janheine.wordpress.com/2018/...-in-the-world/
    Too old to ride plastic
    'brifter' is a lame word.
    Don't overthink the miniscule differences in rolling resistance. If you want better ride and more traction (generally, w/ obvious limits) and more rim protection use the bigger tires. You'll go nuts trying to figure out rolling resistance differences given all the variables and as I said...the differences are tiny. Not worth thinking about.
    I work for some bike racers
    and a bunch of skateboards
    May 2014
    ^This exactly!!!^
    As I have always said, if I can't tell the difference in speed/effort required, why shouldn't I go with the wider tire that has a nicer ride - plain and simple? No sense obsessing myself with geeky formulas and engineering charts. My hands and butt don't lie.
    Sep 2007
    ^This exactly!!!^
    A more comfortable ride leads to less fatigue which leads to a fresher cyclist which leads to faster overall rides.
    A large volume, low pressure tire gives a more comfortable ride, better traction, better flat protection and less rolling resistance. That's a lot of wins for one component to give.
    Jun 2015
    I just deleted a whole post. I did so after deciding the way things get scrambled in these forums it was not advantageous to post what I originally did.
    Instead, I will simply reiterate without explanation FWIW:
    Wider tires of the same road bike model of tire roll faster than their narrower brothers.
    Personally, I found that my times improved the most on climbs when upsizing.
    I also find higher TPI better...more comfortable and probably faster.
    That's my two-cents worth.
    Jan 2015
    ^This exactly!!!^
    Makes sense. What brands are recommended for wider tires?
    Aug 2013
    Wider tires of the same road bike model of tire roll faster than their faster than their narrower brothers.
    With the proviso that both are run at the same pressure.
    Quote Originally Posted by gasman777 View Post
    Everybody makes good tires. Conti, Michelin, Bontrager, Specialized. It's not just 'who makes wide tires' it's the type of tire you're looking at. Race, Training, All Weather...
    Just be careful, some of them are wider than the numbers, and width obviously depends on the rim you're mounting them on. Sounds like you're just shy of obsessing badly. Roll it back a touch.
    Jan 2015
    Maybe so. But I'll also add that if I would've done more research the first set of tires I bought I would've saved myself some cash. I bought gator skins at first and thought they were awful. Did some research, found continentals and made the change. Theyre way better for comfort in my opinion. They run fairly wide on my wheel, maybe I'll just get another set of those even though I can only find 28s which I know will end up being closer to 30. But point taken, wouldn't be the first time I over thought something.
    Jan 2015
    Switched to continental 4000s to be more specific. I liked those much better than the gator skins so maybe I'll just buy them again.
    4000S is a great tire, definitely a much nicer ride than the Gator...the casing is much more supple. Hard to go wrong w/ those, durable/grippy/super consistent. Maybe try Vittoria Corsa, not as durable but a great tire.
    I'll add Challenge. They make some really sweet wider tires. The problem with them as compared to bigger brands is it's difficult to pay less than retail. Whereas with Conti, Vittoria, ect. good sales are the rule not the exception.
  1. Rim Width - Tire Width Questions
    By littlepitboy in forum Wheels and Tires
    Last Post: 09-25-2014, 05:35 PM
  2. Tire width vs. rim width
    By zpl in forum Commuting, Touring and Ride Reports
    Last Post: 08-19-2008, 07:22 AM
  3. Help: Tire width vs. frame/fork width question
    By TBone in forum Components, Wrenching
    Last Post: 08-07-2007, 11:51 PM
  4. Newbie Question: Tire Width vs. Rim width???
    By scotthunt1 in forum Cyclocross
    Last Post: 09-04-2005, 11:08 PM
  5. Shoulder width and bar width
    By jrm in forum General Cycling Discussion
    Last Post: 08-30-2005, 01:26 PM
