Results 1 to 25 of 47
Thread: Tubeless
    Jan 2015
    Tubeless
    For my own learning. I've read good reviews on mtn bike tubeless but have read mixed reviews for road bikes. If your wheel can handle tubeless, is there any real draw backs on road bikes? I've read that once you have an actual flat that won't seal itself up, that its a huge mess...but the other side is....how awesome it is to not carry co2 or tubes and just keep riding....are there other advantages or disadvantages for road bikes?
    Oct 2014
    You still have to carry those things. If you end up with a puncture or cut that won't seal, you need a tube and a boot to get you home.
    Also, punctures don't always seal instantly. You will need a way to top off your air
    The main benefit of road tubeless is reduced likelihood of small punctures forcing you to patch, and some reduction in pinch flats, which can allow you to run lower pressures with less risk.
    If your rides are on hard clean pavement, and you aren't prone to flats, the benefits are fairly minimal.
    Sent from my Pixel using Tapatalk
    'brifter' is a lame word.
    Why would you not have to carry a tube and a way to inflate it? It's not like they're 'flat proof'...As Migen21 posted you have to carry the exact same stuff you'd normally have, possibly more. Tubeless tires are tight, so you'll need levers to get the bead off the rim. Sealant is a big mess, so I used to bring a shop rag...which wasn't enough the time my tire got well and truly slashed. I used road tubeless for years, not anymore. Mountain bike, yes. Road, no.
    I work for some bike racers
    and a bunch of skateboards
    Jan 2015
    Makes sense
    Pathlete and Pedalphile
    Reputation: redondoaveb's Avatar
    Jan 2011
    If you try to fail, and succeed, which have you done?
    Oct 2014
    Quote Originally Posted by redondoaveb View Post
    That was hilarious!
    Sep 2011
    the other thing is, even if a hole seals, there is still a great chance that its latex plug will become unseal as the tire wears down in like, 100-200 miles. Then you're screw. This happens to me in just 1 subsequent ride on a tire that just had about 300-400 miles on it.
    Reputation: Lombard's Avatar
    May 2014
    This is the primary reason I have no interest in trying tubeless.
    Not to mention that I probably get no more than 1 flat per year, if that. Tubes are cheap. They're also not that heavy - REALLY!
    And are tubeless really more puncture resistant? That all depends. Last year, I was on a club ride where traffic made these two potholes unavoidable. I rode through them and so did the rider behind me. Guess who had two flats (tires trashed) and had to call Uber for a ride home? Not I.
    Jul 2014
    I love Seth Davidson's blog, he's hilarious.
    Jan 2011
    Quote Originally Posted by cobra_kai View Post
    Yep, Wanky's the man!
    Nov 2013
    We really need a sticky objective thread discussing the pros and cons of tubeless as this has been debated about a dozen times in the last few years. If there can be three stickys on Chinese carbon wheels, then this topic deserves one too.
    May 2014
    Quote Originally Posted by cooskull View Post
    Well if we do that, we must also have stickies on the following beaten to death topics:
    Wide vs. narrow tires
    Lower pressure vs. higher pressure
    Rim brakes vs. disc brakes
    Aug 2013
    I've gone tubeless on my fatbike and my cross bike (with the gravel wheels) with no issues but I really don't see a point in going tubeless on the road. I don't flat that often and it's a pretty easy change when I do. I don't know a lot of guys running tubeless on the road but the one time I did see it he got a puncture and the sealant didn't seem to work. Ended up calling a cab home.
    Nov 2013
    Even in the movie Groundhog Day there was a way to end the madness. If the sticky threads won't work maybe I'll try binge drinking and some one night stands next to see if those break the loop...
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    Think the Sticky is a great idea.
    As written many times before, I've been a fan of TL since Stans started the tubeless conversion kits for non-TL rims, going back 8 or 9 years at least.
    To me the real advantage is being able to ride a narrower tire with the feel of a larger one, and since I'm a larger rider (and should be on 25's at least) one of my frames won't fit a 25 so I'm able to run a TL 23 with the feel of a 25.
    I realize this is a non-issue on many newer frames that allow spacing for larger tires but it works for me.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Dec 2010
    Upsides:
    - ability to run lower pressure without increasing the risk of a pinch flat
    - significantly lower rolling resistance (apparently)
    - sealant works pretty well, in my experience
    Downsides:
    - there's a direct correlation between how tight the beads are and how well the tire seals. Essentially, the tighter the bead the better. This makes mounting good tubeless tires a pain.
    - screwing around with taping rims. Then there's the issue of damaging/shifting the tape while mounting/dismounting tires. On top of all this, there's no industry standards for tubeless setups so you're never quite sure if a given rim/tape/tire combo will work well.
    - expense. Valves, sealant, tape, tires. None of this is cheap. There are homebrew alternatives to all of this but usually these don't work as well.
    Mixed issues:
    - sealant being a mess: pull the valve core and install sealant after mounting the tire. No mess. If you blow a tire catastrophically, it can make a mess but at least you're outside. Also, in my experience sealant doesn't leave a ton of residue on the inside of a tire unless you live in a really hot/dry area and constantly need to refill the tire.
    - getting a cut in a tubeless tire is a real pain as installing a tube on a tubeless tires is really tricky, especially on the side on the road. One the upside, tubeless sidewalls are generally much tougher than non-tubeless sidewall which makes getting a cut somewhat less common on tubeless tires.
    - tubeless tires weigh more than regular tires but about the same as a regular tire + tube.
    May 2014
    Quote Originally Posted by Hiro11 View Post
    I have seen tubeless tires that had paper thin sidewalls cut when going over big bumps.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Downsides:
    Not if you use a rim without spoke holes. Then it's a non issue.
    May 2014
    Not to seem ignorant, but how do you lace a wheel that doesn't have any spoke holes?
    tlg
    tlg is online now
    May 2011
    No spoke holes on the inside.
    You never seen a Mavic wheel? UST wheel? Shimano and Easton Tubless rims are this way as well.
    Shimano Dura Ace Tubeless
    May 2014
    How do you get the nipples inside the rims? Am I missing something?
    tlg
    tlg is online now
    May 2011
    Threaded nipple in the rim.
    May 2014
    Interesting. I learn something new every day!
    changingleaf
    Aug 2009
    With THE RIGHT RIM tubeless tires are easy to mount and inflate. It's always a good idea to carry a tube in case the tire has a cut that won't seal, but in six years of running tubeless I've only had to resort to a tube once. There is a small learning curve for mounting and inflating tires.
    Quote Originally Posted by changingleaf View Post
    What is this magic rim you're talking about? Pretty much every tubeless compatible rim I've mounted tubeless tires on has been more difficult than most non-tubeless set-ups. Getting normal clinchers on the new tubeless Zipp alloy rims is a pain in the ass. For anyone. The whole idea is that they fit tightly so they seal well. If you have an 'easy' to mount tire/rim combo it's most likely not as safe.
    If you get a flat that the sealant won't work on it's a big mess...no question about it. You WILL get sealant everywhere and it WILL be a pain to get your tire back on once everything is covered in it.
    If 1-2 flats a year are 'too many' maybe these riders should take another sport. I am completely over tubeless for road use. Still convinced it's the only way to go for mountain bikes, but not for road.
  1. Replies: 48
    Last Post: 11-03-2015, 07:17 AM
  2. Road tubeless on non-tubeless wheels
    By SwiftSolo in forum General Cycling Discussion
    Last Post: 05-11-2015, 10:20 AM
  3. Replies: 6
    Last Post: 04-20-2014, 03:00 PM
  4. Replies: 10
    Last Post: 02-24-2014, 10:01 PM
  5. Replies: 20
    Last Post: 07-29-2011, 05:12 PM
