Results 1 to 13 of 13
    Have any Grey Poupon????
    Tubeless sealant spilling when airing up tires
    Recently bout new road bike with tubeless wheels. However when i ride i always adjust my tire PsI where i need it.. however every time i pull my pump off of the presets valve after airing up the tire a small amount of sealant shoots out in a mist. It usually ends up on the brake track of the wheels which results in cleaning the brake track.. rear tire doesnít do that at all just the front. Any idea why?
    I check and valve stems are fully secured to wheel so i canít tell why it mists out sealant when i remove my pump head.
    Don't bother just to be better than your contemporaries or predecessors. Try to be better than yourself- William Faulkner
    Road: 2011 Tarmac Comp
    MTB: 2011 Epic Comp 29er
    MTB SS : 2010 Rockhopper Expert
    Trainer : Trek 1000
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by jeeper006 View Post
    Before pumping your tires, put the valve stem at 12:00 and let it sit there a moment so all the sealant runs away. It should eliminate the spraying. Never pump your tires with the stem at 6:00.
    If you keep spraying sealant, it's going to eventually clog up your valve and you won't get air in or out.
    Maybe more or too much sealant in the front.
    ahhh, i like the idea of letting the valve drain completely before airing. ive only aired tires probably 3 times so both of these scenarios are possible.
    I will start letting my stems drain for a minute at 12 o clock then fill hook up air pump at around 9 o'clock. My bike is due for its 30day tune-up in the week or so so i'll mention it to the bike shop and have them check the sealant levels if im still getting sealant spray.
    Trainer : Trek 1000
    tlg
    tlg is online now
    May 2011
    It's also a good idea when storing your bike, make sure the valve stems are anywhere but 6:00. It'll help keep sealant from collecting and drying up on them.
    Nov 2002
    I don't get this. Are you mixing up your 6 and 12 o'clock positions? At 6 o'clock (actually, anywhere between 4 and 8 o'clock) liquid sealant drains out of the valve. Getting sealant into the valve core will plug it up.
    Sep 2011
    if you have a lot of sealant, this is gonna happen, regardless of stem position.
    Nov 2002
    I think you're right. What about Milkit valves?
    Reputation: Srode's Avatar
    Aug 2012
    At 6:00 if there's a lot of sealant it will spray out when you pull the hose off the valve. I always air up at 3 and 9 positions to allow it to drain and make sure it's not close to submerged in the event I went overboard filling it (not admitting that I've ever done that of course).
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Russian Troll Farmer
    Sep 2016
    Before pumping your tires, put the valve stem at 12:00 and let it sit there a moment so all the sealant runs away. It should eliminate the spraying. ....
    You're actually safer putting it at about 8:30; that way none of the sealant will go down the valve stem.
    "L'enfer, c'est les autres"
    tlg
    tlg is online now
    May 2011
    No I mean 6. All the sealant inside the tire and rim will drip down and collect on the valve. Some will drip off, but some will stick to it. Do it repeatedly and it'll start to build up.
    Plus if you have too much sealant, it could fill up into the valve.
    Reputation: Notvintage's Avatar
    May 2013
    Or even easier, put a tube in there and be done with it. LOL.
    Aug 2013
    Whenever I add new sealant, I also clean the dried sealant out the valve stem and core. You have to pull the core anyway. Adding a few minutes of time to clear out the valve parts is not a big deal.
    Nov 2002
    The instructions that came with my Bontrager tubes with sealant in them said to inflate in the 4 or 8 o'clock position.
  1. Do tubed tires work as well with sealant and tubeless?
    By rx-79g in forum Wheels and Tires
    Last Post: 03-20-2011, 01:38 PM
  2. Tubeless Tires - Sealant or No Sealant
    By Weav in forum Wheels and Tires
    Last Post: 08-28-2010, 05:52 AM
  3. Sealant in Road Tubeless Tires?
    By z5Thor in forum General Cycling Discussion
    Last Post: 07-14-2010, 10:36 AM
  4. Hutchinson Road Tubeless - Sealant or No Sealant
    By Jon3234 in forum Wheels and Tires
    Last Post: 08-05-2009, 05:20 AM
  5. Deflating road tubeless tires containing sealant
    By ukbloke in forum Wheels and Tires
    Last Post: 01-08-2009, 10:04 AM
