Results 1 to 5 of 5
    Tubes for 40 MM Tires
    Anyone happen to know of a tube that can be used with a 40MM tires that has a smooth valve? Because I'd rather not threaded if it can be avoided.
    It seems all the bigger ones are threaded. I'm not at all hesitant to use a smaller tube that, on paper, won't work with a 40 but I'm afraid something that tops out at 25mm might be pushing it with a 40mm tire. Although I have used 23mm tubes with 35mm tires so maybe I'll try it.
    I did find some 38mm zipp tubes but the valve is shorter than I want and it sounds like they went weight weenie on the stems which sounds stupid to me if that at all impacts durability and function. (see description below)
    "is designed to improve rotational stability by decreasing rotational mass at the valve body. It features a lightweight, smooth aluminum Presta-valve body, 37 mm length with a removable valve core."
    Reputation: velodog's Avatar
    Sep 2007
    Here's a couple but only rated into the 30's.
    25-35 with smooth 48mm valve
    https://www.amazon.com/Diamondback-7...x38c+bike+tube
    These are 25-32 with a smooth 40mm valve.
    https://www.amazon.com/Michelin-Airs...CJ823MQVWGNQ6M
    I don't know about the diamondback tubes but I've been using, and happy with, Michelin tubes for a number of years now. In 700c only up to 25mm's but in my 650b wheels I've used Michelin tubes in both 650b and 26" rated for 40mm tires to good effect.
    I have used 700X25 Michelin tubes in my wifes wheels with 32mm tires mounted and that works just fine. And she rides "heavy". I'll trust you not to mention to her that I said that.
    Too old to ride plastic
    Sep 2007
    I got to thinking about this since writing the last post and came up with a maybe.
    Like I said, I've used 26" tubes in my 650b with no issue. That's 559 ETRTO in place of 584 ETRTO. It's a bigger difference, but maybe you could try a 650b(27.5) tube in your wheel. 584 ETRTO in place of 622 ETRTO.
    https://www.modernbike.com/michelin-...27.5-x-1.9-2.6
    https://www.ebay.com/itm/Kenda-650b-...MAAOSwNURbRyrI
    Thank you. Both are what I want and didn't turn up in my search so I appreciate it.
    Another option in case anyone else is looking for the same thing is: https://www.excelsports.com/main.asp...jor=1&minor=31
    They are latex though. I like and use latex tubes on my road bike but the 40mm tires bike in addition to gravel and trail rides gets used almost daily during the week sometimes just for quick grocery runs so I don't want to have to pump up every ride with that bike. They'd be a great option for those using bigger tires just for performance type ride and not frequent utilitarian rides though.
    Thanks. I hadn't seen this when I first responded. The first two you posted should work but I'll look into what you're saying here if I have problems with one of those (likely the Diamonback).
  1. Tubes, Tubes, Tubes, there is a difference
    By Mr645 in forum Wheels and Tires
    Last Post: 10-06-2014, 08:26 PM
  2. Replies: 23
    Last Post: 05-31-2014, 07:57 PM
  3. Are all tubes created equal? (Long Valve Tubes)
    By r_mutt in forum Wheels and Tires
    Last Post: 01-30-2008, 06:15 PM
  4. tires, tires, tires
    By sparky821 in forum Commuting, Touring and Ride Reports
    Last Post: 01-22-2008, 03:39 PM
  5. Of tubes more tubes
    By Enviro Mental in forum General Cycling Discussion
    Last Post: 07-08-2005, 10:15 AM
