Results 1 to 25 of 30
    Aug 2011
    Tune or Chris King Hub to be installed with Enve 45 composites?
    Which hub will you select to be installed with Enve 45 composites carbon clincher between Tune mig 70 Front hub+ Tune mig 170 Rear hub or Chris King R45 Front hub + Chris King R45 Rear hub? Plaese give me your recommendation. Thank you.
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    Why be restricted to the options that Enve offers? It seems if your paying that much for a wheelset, you shouldn't be restricted to just two options for hubs. The Tunes have been known to have creaking problems and frankly the Chris Kings are a bit heavy. If you were absolutely set on one of the two, I would say go for the Kings. However, Enve does charge a good premium for their builds. So you may want to consider other options to get a better bang for your buck.
    Aug 2011
    Quote Originally Posted by Zen Cyclery View Post
    In my country, there aren't many choices. Tune and King are popular among bike ridres in Thailnad.
    Mar 2009
    Quote Originally Posted by tanong View Post
    That fact that you are on the mighty Interwebz gives you more than enough power to choose your own options. And just because products are popular in your part of the world doesn't necessarily mean that they are the products that are best for you.
    Cpark
    Reputation: cpark's Avatar
    Oct 2004
    Neither.
    Alchemy hubs are the ones I would recommend.
    Oct 2001
    tune has new hubs out now that are supposedly quite an improvement over the old ones. That said I had tune hubs on two wheelsets, one of them creaked, jeremy at alchemy fixed it under warranty and then did the other one just in case and I never had a problem w/ them after that.
    I still think there are better options than tune, however.
    Höchstgeschwindigkeit
    Reputation: mimason's Avatar
    Oct 2006
    tanong, I have King R45s on my Enve 65s and am very happy with them. The only other hub I would want instead would be the Alchemy hubs but that was not an option for me where I purchased them.
    Mar 2009
    Aside from being manufactured by one of the leading machine shops in the business the folks at Alchemy designed a set of hubs that have the BEST flange spacing of any hub on the market. This allows them to build up into very laterally stiff wheels which is an extremely important consideration for someone who is 80 kilos.
    King makes some GREAT hubs but Alchemy makes better ones.
    FWB wheelbuilder
    Oct 2005
    Tanong,
    I remember responding to a post that you put up a few weeks ago and you in which you admitted that your 80 kilos. At that weight you will crack a Tune hub. We stopped carrying Tune because they are simply not durable enough for the majority of riders. The best set of hubs to build up a pair of ENVE 45s with is a pair of Alchemys.
    Your experience is with the mag180 hubs which is completely different animal than the Tune mag170. I weigh 93kg not counting the 9kg of stuff I carry in pack on my back, and I have been riding a set of the mig70/mag170 and amazingly they have not made a single noise or "cracked" as you say they should for someone 13kg lighter then me. The 170 is the same basic design as the 180 but with a lot of improvements. It has a larger axle, larger drive ring and larger bearings, they have also got rid of the xot double bearing in the center of the hub and replaced it with 2 separate bearings.
    So yes, there were issues with the mag180 hubs but the new 170 hubs do not have any of those issues.
    Nov 2008
    How about White Industrys?
    Embrace the fact that everyone on these forums has their own unique desires, needs, experiences and environment so what works for you may not work for others.
    FWB wheelbuilder
    Oct 2005
    Quote Originally Posted by Maximus_XXIV View Post
    Great long lasting and well made hubs but not in the same weight range as the Tune or Alchemy. The White Ind hubs are 95g front and 255g rear, Tune is 70g front, 168g rear and Alchemy are 65g front and 225g rear. If you don't care about how much the hubs weigh and you want to save some money go with White Industries.
    Smiling Wolf Puppy
    Reputation: Big Bad Wolf's Avatar
    Jun 2007
    What axle widths does the Alchemy Orc come with? I'm looking for a 135mm rear with campa freebody. Tune does them on its MAG 170.
    That is a very bold statement
    Bianchi-Campagnolo
    Reputation: kbwh's Avatar
    I've noted that Roues Artisanales have chosen Alchemy front and Tune rear for their standard wheels, but that might have something to to with the triplet spoking pattern Adrien prefers?
    They do anything just to win a salami in ridiculous races. I take my gear out of the car and put my bike together. Tourists and locals are watching from sidewalk cafes. Non-racers. The emptiness of those lives shocks me. It was the illest of times, it was the dopest of times. And we looked damn good. Actually the autobus broke down somewhere on the Mortirolo.
    Aug 2003
    I've ben cautioned about parts availability for Tune hubs. Considering 70/170 hubs for a new build, but the parts availability issue has me concerned.
    Any insight into this, and into Tune 70/170 reliability in general is appreciated.
    Reputation: dcgriz's Avatar
    Feb 2011
    I had Enve lace my 45 clinchers on CK R45, 24f/28r radial-f/2x-r, cx-rays. I am a big guy and able to put down the watts. I must have about 800 miles on this particular set since last January when I got it and it has remained as true as originally was. My vote goes to CK. As a matter of fact, I have a couple of other handmades on CK R45s and have nothing to complain about. If radial lacing is your preferance, the wide flanges of the CKs are able to safely accomodate it which is important if you are heavier than the typical 165 lber.
    woz
    woz is offline
    Madcow
    Reputation: woz's Avatar
    Dec 2005
    Quote Originally Posted by tvad View Post
    This was definitely more of an issue with the 180 than the 170. The 180 used a proprietary bearing called the XoT, the 170 uses standard bearings available just about anywhere. End caps and axles have not been an issue with availability either. So unless you're converting from Shimano to Campag or back and need a freehub body there really isn't anything to worry about. There have been some supply issues with getting freehub bodies, but I don't believe that's related to it being a replacement part, because getting the complete hubs has been just as difficult. I think Tune just haven't been able to keep up with demand this year.
    We've sold quite a few of the new 70/170's and have been totally happy with them. So far we've seen only one single issue with a hub making some noise and it turned out to be that it was missing a preload spacer from assembly. Otherwise they've been stelllar.
    A couple years back I wrote a pretty thorough hub review in conjunction with rruff from white mountain wheels, currently we are working on our newest one which will include updates and new models.
    Reputation: ms6073's Avatar
    Interesting. I have a set of Enve 65 tubulars (16/20) built on Tune Mig 45/Mag 150 hubs and while I initially had issues with creaking of the rear hub, this was corrected under warranty at Fairwheel. As for durability, despite a weight of 1045 graams for the wheelset, they have worked great for road racing on all kinds of terrain and also worked just as well after I mounted a set of file treads and raced them at several fair weather CX races last season.
    Michael - There may not be an 'I' in team but there is a 'U' in suck!
    __0
    _ \ |_
    (O)/ (O)
    Aug 2003
    Thank you, WOZ.
    Smiling Wolf Puppy
    Jun 2007
    I haven't had a Tune product that didn't develop troubles after a while. Not sure if they used standard bearings now, they used to use very specific ones only available from Tune themselves.
    Chris King otoh , no troubles at all.
    I have R45 ceramics running on my everyday wheels and they are a dream.
    I've had CK hubs on my wheelset for 8 years serviced once in that time period with no problems, I haven't even had them serviced and they run similar to how they did when I bought them.
    I asked once, and my LBS actually told me they would be happy to service the hubs, more oftenm but feel they are sealed so well that its unneccesary,
    Oct 2008
    The alchemy rear hub weighs 222g, the king is 218g. Theres nothing heavy about that hub. The front hub is about 35g heavier than alchemys. Kings would build a splitting hairs heavier wheelset.
    Aug 2003
    Quote Originally Posted by woz View Post
    I see that Chris King has a 5 year warranty. What's Tune's warranty?
    Mar 2007
    The nice thing about Chris King hubs (and all of their other bearing components) is that you won't ever need the warranty. I have five sets of King Hubs across my MTB and road bikes and as well as a couple of headsets and bottom brackets. Some of them are twenty years old. I've had no issues. Chris King makes a great product.
    Aug 2003
    Quote Originally Posted by TimV View Post
    Warranty is definitely a benefit of CK hubs.
    BTW...I found the Tune warranty:
    Warranty:
    Tune hubs are covered by a 2-year warranty against breakage from the date of purchase when built using a three cross spoke pattern. The warranty period for radial laced wheels is 3 years. The bearings have a warranty period of one year excluding wear and tear.
    Feb 2011
    No comparison between the two. It's a no brainer
  1. Great things over at Enve Composites
    By ergott in forum Wheels and Tires
    Last Post: 06-28-2011, 09:40 AM
  2. Chris King BB help PLEASE!!!
    By redpoint510 in forum Components, Wrenching
    Last Post: 04-09-2010, 12:17 PM
  3. Chris King and FSA
    By nick kitchen in forum Components, Wrenching
    Last Post: 12-07-2009, 05:49 PM
  4. King cross with Edge Composites carbon tubular
    By the Inbred in forum Wheels and Tires
    Last Post: 11-09-2007, 11:04 AM
  5. Chris King
    By andre71144 in forum Components, Wrenching
    Last Post: 11-17-2006, 06:37 AM
