Results 1 to 14 of 14
    I make Eagles fly
    Reputation: Terrasmak's Avatar
    Jan 2015
    upgrading wheels
    Well I ride a couple thousand miles a year , my current Madone 2.1 is staying around for another few years and I figured a wheel upgrade would be nice.
    Been looking at 2 sets of wheels. First is the Shimano RS81 and the other would be a lightbicycle custom wheel build.
    The Shimano set is simple , except for the size C24 or C35 is my hangup.
    Lightbicycle build , 45mm depth and 25mm wide carbon is what I have been looking at. Others are available, just don't know what is really needed for my riding. Other things, Hope RS4 road hubs and they recommend Sapim spokes.
    My riding, some climbing, constant 10+ mph winds , roads seem to be ok , and I currently am maxed at a 25c tire.
    Wheels will probably get transfereed to my next bike in a couple years.
    Suggestions, and recommendations please.
    Reputation: Lombard's Avatar
    May 2014
    If you are dealing with consistent 10+ mph winds, 45mm aero wheels are probably not a great idea. Crosswinds will be a nightmare, not to mention if you ride where you will be passed by 18 wheelers doing 50+ mph, they could be a danger.
    Before you take the plunge on an expensive pair of wheels, it may be a good idea to familiarize yourself with the "Wheels and Tires FAQ and helpful hints" sticky, post #2. I'll cut and paste it below. This will help us tremendously:
    What wheels should I buy?
    On this forum, this question gets asked often -
    Q - I want new wheels for my bike. What should I buy?
    A - Of course, for a good answer, we need as much information as possible. Some of the info we need is -
    • Why do you want new wheels? What's wrong with your old ones?
    • What are you old ones? (rim name, hub name, spokes, their numbers)
    • How much do you want to spend?
    • How heavy are you?
    • Do you ride "light" or "heavy"? Are you powerful or smooth?
    • Have you had problems with your current wheels and if so, what?
    • What condition are the roads in that you ride?
    • What tires, widths and pressures are you using?
    • What do you expect from your new wheels that your old ones can't deliver? (be reasonable and realistic here!)
    • What are you going to use the wheels for - recreational riding, touring (loaded), training, racing, general purpose?
    • Do you want custom hand-built (designed for you) or factory pre-built?
    • Do you want wheels that are easily repairable with readily available, reasonably priced spokes and rims or are you ok with maybe having to ship your wheels back to the factory and wheels that contain expensive, proprietary spokes and possibly un-obtainium replacement rims?
    • Do you need 11spd compatible wheels (can be used with 8 ~10spd cassettes too by using a spacer) or are 10spd wheels ok? (can only be used with 8 ~ 10spd cassettes). Edit - This info is for Shimano & SRAM related cassettes; not Campagnolo.
    • Do you want the wheels to be oriented towards "aero" or "light"?
    • Do you want to use regular clincher, tubeless, or tubular tires?
    • Aluminum or carbon rims?
    • Rim brakes or disk brakes?
    • Rear hub width? (120, 126, 130, 135MM)
    • Do you want adjustable loose ball bearing hubs (almost exclusively Shimano) or cartridge bearing hubs (almost everything else)?
    -- Warren Buffett
    I make Eagles fly
    Jan 2015
    Old wheels are heavy, and flex like a wet noodle.
    Looking for an all around wheel. Out if all those questions it's the Aero vs light that I am hung up on. I can get 25mm, 35mm or 45mm , I don't worry about big rigs coming by, but vegas does have wind. What depth make a normal all around great riding wheel.
    May 2014
    Quote Originally Posted by Terrasmak View Post
    Looking for an all around wheel. Out if all those quartions it's the Aero vs light that I am hung up on. I can get 25mm, 35mm or 45mm , I don't worry about big rigs coming by, but vegas diesel have wind. What depth make a normal all around great riding wheel.
    Since you have a Trek Madone, I am assuming it came with Bontrager wheels. I can't imagine they weigh more than 1800-1900g or so. Typical weight of entry level road wheels. Flex like a wet noodle is definitely not nice. This could be for a number of reasons. Bontrager wheel quality has never been tops.
    Personally, I think 20-30mm is a good depth range for a road wheel - especially if you will be riding in windy areas. The Shimano RS81 C24 is a great deal right now:
    Shimano RS81-C24 Carbon Wheelset > Components > Wheels > Road Wheels | Jenson USA
    Another great buy right now is the Shimano Ultegra WH-6800:
    Shimano Ultegra 6800 Tubeless Wheelset > Components > Wheels > Road Wheels | Jenson USA
    Granted it weighs 120g more, but costs $220 less. They are good quality wheels and trust me, you won't notice the weight difference.
    -- Warren Buffett
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    I have ridden RS80-C24, RS81-C24, and DA 9000-C24, all essentially the same. I actually like my RS80s more than the RS81s, but once I switched to 11-speed didn't have much of a choice there.
    They are light, priced well, and it's nice (IMO) to have the aluminum braking track along with some carbon elements. I wish I had gotten the DA C35s to be honest. They are not much heavier at all.
    Rider weight is a consideration, I'm about 180 and I think I'm at the high end for what these wheels would do well handling. There are not a ton of spokes...
    PS Not a wheel expert here, although there appear to be many on this site.
    Reputation: Srode's Avatar
    Aug 2012
    How much do you weigh? I weigh 170 and wouldn't likely choose Shimano wheels due to the low spoke count - but I do have an above average annual mileage probably.
    Personally, I can tell the difference easily between a 2000 gram wheel set and a 1600 gram set - they spin up much easier if most of the difference is the rim which is often the case. Stock wheels like you have are going to feel like lead weights compared to a light set. That isn't necessarily going to make you any faster though, it may just feel better.
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    I make Eagles fly
    Jan 2015
    I weight between 170 and 180. I have been eyeballing the RS81 but the odd spoke count turned me off.
    I'm going to have a set built on Hope hubs ( same brand I use for both mountain bikes) and run a standard 20 front 24 rear combo. The wheels will be a 25mm wide set, and now leaning on a 35-38mm depth
    May 2014
    Ordinarily, I wouldn't choose any wheels with a spoke count lower than 24 front/28 rear. However, I have known enough 200lb+ people who have been riding 16/20 Shimano wheels for a few thousand miles and never had a problem - never even needed trueing. Though IF you do break a spoke on a lower spoke count wheel, it will be next to impossible to get it true enough to get home. So make sure you're doing a ride where there will be a cell signal.
    This.
    Lighter rims will make you accelerate faster from a stop, but once up to speed, you won't notice any difference.
    -- Warren Buffett
    May 2014
    Or you could go with a set of these:
    Blackset Race 30 700c Wheel Set
    They have positive reviews among riders on this forum, weigh only 1497g and don't play the low spoke game. They are 24/28.
    -- Warren Buffett
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    OP, some years ago I run across a series of articles on the subject of the gains we get from the different wheels available that I deemed noteworthy and kept. Glad to see they are still available on the net:
    Great wheel test 2008 – Part 2 – Inertia | Roues Artisanales
    See their data and conclusions and argument on how close to non-existent the differences, in terms of inertia (which is the essence of your post), are between the high end aluminum wheels vs. the lower cost aluminum wheels. See also their argument about two wheelsets which makes a lot of sense to me if one has the circumstances to use the second set (i.e. Racing).
    I hope it helps you in your decision making where to put your money. IMO, with today's market pricing and following the premises in this article, there is not a lot to gain in terms of wheel inertia when spending over $500 for a set of aluminum wheels. The extra money goes to features of the wheel's components, often the hub. However, whether the hub freebody is Ti, Aluminum or steel, would not change much the way you feel while riding on them.
    With bicycles in particular, you need to separate between what's merely true and what's important.
    I make Eagles fly
    Jan 2015
    Those are pretty cool, only thing holding me back on a set is the hubs. I really want to build off my hubs of choice
    Apr 2013
    RS81 is a great wheel set. good choice
    Oct 2011
    Lots of good suggestions by the good folks on the forum above.
    Here is just one more data point for you.
    I have built up and been riding for over a year now a set of LB carbon 45mm deep wheels. I used DT240s straight pull hubs 24 hole, Sapim CX ray spokes. I am 6'4" and 200-208 lbs ready to ride.
    Been holding up perfect. They perform very well in cross winds. Way better than I ever anticipated. Even heavy Santa Ana gusty winds are fine.
    I built up a set of LB 35mm deep for my wife who is very petite. No issues at all in cross winds. Could have gone 45mm even for her without worries.
    Guess what I am saying is that in these sizes the LB U-shape profile works well in cross winds. Yes big trucks pass us at freeway speeds, no issues.
    BTW, these wheels built up quite easily for me and have stayed tight and true.
    Of course what works for you may vary, just a data point to consider.
    Suggest you borrow wheels from riding buddies etc if possible to get a feel for different wheel, rim combinations to see what works for you.
    Good luck.
    Apr 2013
    I ride on Dura Ace C-24's and use them for everything. Never felt a need or desire to go carbon or deep rim
  1. Thinking about upgrading from Ultegra 6600 wheels
    By VeloMellow in forum Wheels and Tires
    Last Post: 07-18-2008, 09:12 AM
  2. upgrading wheels
    By kermie in forum Wheels and Tires
    Last Post: 04-02-2008, 01:46 PM
  3. Upgrading Wheels
    By icamp in forum Wheels and Tires
    Last Post: 02-17-2008, 07:10 PM
  4. Upgrading wheels
    By robertburns3 in forum Cannondale
    Last Post: 10-29-2007, 03:24 PM
  5. Upgrading Wheels
    By durkind in forum Wheels and Tires
    Last Post: 06-03-2004, 11:55 AM
