Results 1 to 12 of 12
    Feb 2009
    using tire levers to get tire on.?
    as im putting on the tire and it gets to the last 4-5 inches... where it gets impossible...
    is it safe to use the tire lever to help me force it up? or is it going to bend the rim outward?
    duh...
    Jan 2005
    sure.
    vexatious enigma
    Reputation: waldo425's Avatar
    Sep 2008
    You shouldn't have to, but it's perfectly fine to do so.
    Ive never had to use a lever to get the tire on. Normally what I do when it gets towards the end and gets hard Ill go to the opposite side wiggle the tire and try again. If I'm still having trouble Ill let some air out of the tube then go at it again. Ive also had major problems with getting the bead on whenever I have cheap tires with too stiff of a bead on it.
    Quote Originally Posted by JoeDaddio
    Unlike Roebuck, you do "do" people.
    Maybe Judas did it for a Klondike bar.
    Life in the fast lane with no brakes
    Feb 2002
    Being good and being careful
    Quote Originally Posted by daivs_T
    as im putting on the tire and it gets to the last 4-5 inches... where it gets impossible... is it safe to use the tire lever to help me force it up? or is it going to bend the rim outward?
    It's not going to bend the rim, but you do risk pinching the tube and causing a puncture. The first thing to do is to make sure that you have centered the bead of the tire in the rim before you try to get that last bit on. This makes sure that the bead is in the smallest circumfrence of the rim, making it easier to mount the tire. If you've done that, and you still can't get the tire on (even when using the butt of the palm of your hand to work it into place) then you may find tire levers to be your only option. Just be careful that you have the tube fully worked into place and that you don't get the tube between the tire lever and the rim - doing that will likely puncture the tube. This will then cause frustration and the occasional use of bad language, not suitable for children.
    Old and Fixed, Moderator
    Jan 2002
    In my experience, it's one of the following:
    1. You might need to work on your tire mounting techique. There are various online sources on proper way to mount a tire. Basically hold the wheel against your gut and work the tire onto the rim so the last few inches are on the outside of the wheel(not the part against your gut). As you work the tire around the rim, it's very important to get the tire bead in the center of the rim as that is the deepest part. It allows the most room the mount the last few inches...
    2. If your techique is good, than you might have a bad tire/rim combination......not all tires work with certain rims...
    Others might disagree but I will never use a tire that needs a lever to mount....I'd hate to be stuck somewhere with a tire that won't go on the rim..
    Dave Hickey/ Fort Worth
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Quote Originally Posted by Dave Hickey
    Personally I will never use a tire that needs a lever to mount....I'd hate to be stuck somewhere with a tire that won't go on the rim..
    Also Campy rims are notorious for being on the large side, and just about any tire will be a bear to get on and off.
    Jun 2007
    I agree with everything said about technique. However, I never hesitate to use tire levers, because they are a tool intended to make this job easier, so why not use them. Just take care not to pinch the tube. I carry two plastic levers in my tiny seat pack and they take up virtually no space and weigh next to nothing. I tend to use them more on the road than at home, mainly because when I'm changing a tire on the road, I'm feeling some sort of time pressure (others in ride, late for work on the commute, etc.).
    Jan 2002
    Quote Originally Posted by Camilo
    I hear you....I carry and use levers but I only use them to remove the tire...not to mount.... A tire can safely be mounted using the lever but personally, I'd rather not risk puncturing a new tube in doing so...
    Reputation: ClassicSteel71's Avatar
    Mar 2009
    Put on your gloves and roll the last few inches. Two hands on the tire and roll towards the rim.. Or a worse idea is find a tire that fits your rim better. Some slip on like Cinderella's slipper.
    Big is relative
    Reputation: bigbill's Avatar
    Feb 2005
    I put a new set of Conti Gatorskin Ultras on my training wheelset today. The rear has a Mavic Open Sport rim and I needed a tire lever. The front is a CPX33 and I only needed my thumbs. For whatever reason.
    Retired sailor
    Reputation: saccycling's Avatar
    Sep 2004
    Use the butt of your hand to roll the tire on. Work on one side and then the other to get that last 4 or 5 inches on. You shouldn't need a tire lever unless you got weak hands.
    still shedding season
    Reputation: kykr13's Avatar
    Apr 2008
    Quote Originally Posted by Kerry Irons
    Just to clarify, make sure the bead is in the middle of the rim (where the spokes are) because that's the smallest diameter of the rim - at least that's what I think you're saying and it does help. This, Velox-type rim strips and putting some baby powder on your tubes so they slide a little easier all help.
    I have wire-beaded tires on my old bike that are really tight. I'm able to get really close without using a lever, but this one was a huge help for the last few inches - "normal" levers would break. You only need one of these levers, and mine stays in the saddle bag on this bike.
