Results 1 to 5 of 5
    Reputation: threebikes's Avatar
    Jan 2009
    Valve Stems - how long?
    I have 32mm carbon rims and a few tubes with 42 mm stems.
    Should I buy some tubes with 52mm valve stems or just
    use the 42's ?
    The most expensive thing you can buy for your road bike is a scale.
    LC
    LC is offline
    Depends on your pump but I would get stems at least 48mm long.
    Jan 2009
    Thanks LC
    Reputation: martinot's Avatar
    Aug 2009
    It probably adds a bit to the imbalance of the wheel (although I have not noticed even @ super high rpm) but I like my stems to be exposed by at least 2 cm and preferably even 3 cm. Anything less than that is a pain during first stages of pressurizing (and I ride exclusively on latex tubes so pressuring is a daily routine). I'd go with 52 or even 60mm length.
    Tiremaniacs
    Continental - Schwalbe - Veloflex
    Racing and Training Cycling Tires
    Dec 2012
    I would use whatever fits. if the pump works on it then it's all good. That being said, I wouldn't use 80mm steams.
