Results 1 to 25 of 28
    Manchester, England
    Reputation: Chocolatebike's Avatar
    Feb 2011
    Velo plugs on Velocity A23 rims ?
    Is anyone using the plugs with these rims ?
    The well in the centre of the rim looks to be too deep and narrow to get the plugs in to me.
    Also, if it works, do I need red or yellow ?
    TIA.
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    No go. Matt at Velocity said that they to do not recommend it, simply because of the bed shape.
    Reputation: krisdrum's Avatar
    Oct 2007
    That must be on the newer version. I have older ones and the red version works great.
    Burnum Upus Quadricepus
    Reputation: brucew's Avatar
    Jun 2006
    Quote Originally Posted by krisdrum View Post
    Me too.
    Aug 2011
    I built up a set of wheels using A23s. One rim had the older style bed (made in aus), the other had the newer style (made in the us). Red plugs worked well on the older style, but part of the spoke hole would creep out from under the plug on the newer style.
    Reputation: Clipped_in's Avatar
    May 2011
    Same here
    Ride lots!
    Eddy Merckx
    Jul 2011
    I have the new USA rims. The red plugs took a bit of push to get them seated. Tried velox tape first, but it made for a tough time getting the tire on.
    Manchester, England
    Feb 2011
    Thanks for the feedback.
    The rims I have are US production and they were made in October 2012 (some head scratching 'til I realised that y'all write down dates differently to us ).
    Looks like I'll be using rim tape unless I can persuade a plug in there.
    I'll post pics of the wheels when they're built.
    Nov 2012
    I have two sets of Velocity A23's. Both of them are new USA model rims. I'm using "red" plugs in all of them and they installed fine and very pleased with them. Once you muse them you'll never use rim tape again! I have a few extra and if you PM me I'll send them to you free if charge so you can check them out for yourself.
    Manchester, England
    Feb 2011
    Quote Originally Posted by Bianchi-001 View Post
    That's a very kind offer, thanks !
    Just be aware that I'm in the UK and it might be cheaper all round if I source a couple of plugs locally (unless you're over here as well).
    I'll PM you.
    Thanks again,
    Andrew
    Reputation: xjbaylor's Avatar
    Dec 2006
    I have red veloplugs in my "Made in the USA" A23's and, like others, the fit is less than ideal. They work, but are not as flush to the rim as on other rims. I have been fine with it running CX pressures, but decided that I will probably replace it with Stan's tape if I decide to run those wheels at higher pressures on the road. YMMV, etc.
    Nov 2002
    Is it something with 23mm rims in general? Both the Archetype and the BHS c472w (yes, yes, it's a Kinlin XC279, but hey, I got them here first!) are also in between red and yellow - neither really fits well.
    Reputation: froze's Avatar
    Sep 2002
    Why plugs? they cost $13 for 72, not bad, but why spend that kind of money when rim tape is close to same weight and cost less, and they won't accidentally fall when you try to fix a flat on the side of the road and can't find it to put it back in!
    http://www.youtube.com/watch?v=xk98yvozq1g
    http://www.youtube.com/watch?v=nvk63...eature=related
    http://www.youtube.com/watch?feature...&v=p92Stnnigjs
    "They don't do things that way anymore. This is the Age of Science Know-How, electronal marvels."
    Feb 2012
    I have a set of Velocity A23 wheels with Velocity hubs with the Pro build. I had many problems with rim strips and Velox rim tape sliding around while mounting tires with resultant flats when the spoke holes were exposed. Tried Veloplugs, the red variety, and they worked great. They were a somewhat tight fit but the all went into the spoke holes nicely and they also made tire mounting quite easy. I've had the wheels about a year so I don't know if the are the old or the new rim type. I must admit that paying $15 for 50 cents of red plastic is kinda steep! But they work.
    Sep 2002
    Quote Originally Posted by eickmewg View Post
    I've never heard of any one having problems with tape, what you said makes no sense.
    Reputation: PlatyPius's Avatar
    Feb 2009
    Quote Originally Posted by froze View Post
    Because some tires (tyres) are such a b@#$h to install that tape makes it just a little too tight. The plugs give the tire a mm or two of extra space.
    I do find it amusing that Velocity says VELOCITY Velo Plugs won't work on some VELOCITY rims.
    Disclaimer: I own a bike shop. Yes, I'm biased.
    Other countries need to stop hatin' or we'll unfriend them
    . - Christine
    Apparently I left my reading comprehension glasses in my ass. - DrRoebuck
    Still, it felt great and I felt like I was sitting on some kind of vibrator -Touch0Gray
    and yet another unnecessary A**hole! go F*** youself! - some loser
    Sep 2002
    Quote Originally Posted by PlatyPius View Post
    Right, but that's why they make 10mm wide tape so it just cover the holes, if your using the right width tape you should have any problems. I've heard on forums from others, and had a friend that removed a tire on the road after a flat and a plug came out and got lost; after my friend told me this story I told him to carry a couple spare plugs. My friend switched over to plugs from tape and he can't tell the difference in tire installation, he never could give me a good reason for the switch!
    Feb 2009
    Re: Velo plugs on Velocity A23 rims ?
    The problem with using 10mm tape is that it *barely* covers the holes. I've seen a whole lot of 10mm tape bunched up on one side with spoke holes exposed. Tight tires push it to one side as they're being installed. It also just seems to migrate on its own after a while.
    . - Christine
    Sep 2002
    I'm not denying your experience, but my experience is different from yours, I haven't ever seen that happen in 40 years of riding either with my own wheels or others I've seen. The fact I've never seen it caught me surprise when you mentioned it!! I have seen 10mm rubber and plastic strips do that and shift around, not sure why some rim manufactures back in the 80's even used those strips.
    By the way, there was at least two guys on a forum that had problems with the plugs that made it MORE difficult to install his tire, not less; see: Anyone had this problem with rim plugs?... [Archive] - Bike Forums
    I hate to sound weird, but you all should be use to that! Anywho, I can't help to think that the only reason tape would move is by improper preparation and application, then perhaps as the tape got to be several years old maybe, but I've never seen that even then, right on up to replacement time, which the tape lasts so long it may take 10 years for the tape to get to the point of replacement. I've used different brands of tape over the years and never had any issue with any brand so I can't see that as being a brand specific problem like I do with glueless patches. (I only use Park and Specialized glueless patches and those have never failed in 20 years of use while others have).
    But I would advise that if you're going to use the plugs to carry a couple with you just in case while attempting to fix a flat that you accidentally don't lose one or two if they should fall out. My understanding is too that those plugs should only be used with deep aero rims where the nips are well countersunked.
    Another thing, I use to know a guy that all he did was to go the el cheapo route, he used 3M filament packing tape! It must of worked because he used it for all the years I knew him, and he got that idea from another rider who did it. I also heard some used electrical tape but I wouldn't advise it, it doesn't stick as well, leaves a goo behind, and will stretch when the tube gets pressurized. I carry a bit of duct tape with me when I ride, in a pinch I could cut off a small strip and use it to cover a hole or two or more if I ever did have a strip issue. The only time I ever had a strip issue is when I waited too many years before replacing it, I had a flat on the road once after a 12 year old strip failed in one section...duct tape to the rescue. A lot of LBS mechanics recommend changing the tape with every new tire, that's just plain nuts and a waste of money.
    May 2011
    That was an interesting read. All that talk about rim jobs and butt plugs made me blush.
    Ride lots!
    Eddy Merckx
    Reputation: oldroadie_nc's Avatar
    Mar 2011
    I installed the red Veloplugs on Velocity Aerohead rims and rode them for many thousands of mile with zero spoke-hole related flats, and never lost a plug during a roadside repair. I've recently built a wheelset with HED C2s which, with somewhat larger spoke holes, required the yellow Veloplugs. After >1500 miles, no flats at all, so I'd say the Veloplugs work. They certainly do make tire installation easier.
    Sep 2002
    Quote Originally Posted by Clipped_in View Post
    I think the one poster had excessive gas thus the need for butt plugs.
    Reputation: slowdave's Avatar
    Nov 2005
    I have had issues with rim tape slipping and exposing spoke holes. I also have had trouble with very thin tape and offset drilling methods. I have used velo plugs red and yellow in my rims for years, expensive yes but I have used them on different rims after wearing the rims out and relacing to the same hub. What do though is to install the plugs then wrap the rim with one layer of elec tape. This means no lost plugs and gives my a margin more room to install continentals or veloflex on campagnolo rims without the need for tyre levers or massive thumb blisters.
    Not F Schleck. The last 24k is downhill, and he descends like a drunken cat. Quote: justinb
    Manchester, England
    Feb 2011
    Not that it's particularly relevant to my OP but I've got the wheels and I'm very happy with them.
    Pictures are worth a thousand words (and any chance to show wheel bling):-
    13-03-28 Dirty Disco Hope hubs Velocity A23 by Chocolatebike1, on Flickr
    DSC_0280 by Chocolatebike1, on Flickr
    DSC_0276 by Chocolatebike1, on Flickr
    Back OT, the rims are taped.
    I've been using filament/shipping tape for years with excellant results. It weighs next to nothing. One layer seems to work fine. Makes tire changes easy since it doesn't take up any room, even if you use 2 layers for added security. The 3M tape is the best. Electrical tape is a "No GO". It stretches too much.
