Results 1 to 25 of 38
    Jun 2005
    Velocity A23 Pro Build Wheelset
    Wondering if anyone has tried these? Are their house brand hubs any good? Do they come in pretty close to their 1400g claimed weight? Considering either buying this complete wheelset or picking up some a23 rims & lacing up my own set with some DT hubs. Thanks for any replies
    Oct 2008
    Link?
    Jun 2005
    May 2011
    I had these built last year at Pro Wheelbuilder in Las Vegas. Have put 1,900 miles on the wheels. Love them. I am running Continental Gatorskins 25mm on my CAAD 10. The handling especially on the corners feels a lot more secure and the comfort has improved on my aluminum frame. See below a copy of my order to get an idea of the build.
    Front Hub
    VELOCITY ROAD HUB FRONT BLACK Price $53.00 Drillings 24
    Axle Width QR 100mm
    *No Bearing Upgrade
    Front Lacing Pattern
    Lacing: Two Cross
    Front Nipple
    DT SWISS RED 14G 14MM ALLOY PROLOCK HEX NIPPLE
    Price $0.85
    Front Rim
    VELOCITY A23 MSW BLACK 700C FRONT RIM Price $61.00 Drillings 24
    Size 700c/29er
    Velocity Velo Plugs for 1 wheel + 7.50
    Front Spoke
    SAPIM CX RAY J BEND BLACK SPOKES
    Price $3.10
    Use
    Commute Fitness
    User Weight
    220
    Wheel Build Weight
    619.04
    Rear Wheel
    Build Time
    Your wheel should be ready for shipment by July 18, 2011
    Rear Hub
    WHITE INDUSTRIES H3 BLACK REAR HUB Price $258.00 Drillings 28
    Axle Width QR 130mm
    Ti Shimano/SRAM 8,9 or 10spd
    *No Bearing Upgrade
    *No Skewer
    Rear Lacing Pattern
    Lacing: Three Cross
    Rear Nipple
    Price $0.85
    Rear Rim
    VELOCITY A23 MSW BLACK 700C REAR RIM Price $61.00 Drillings 28
    Size 700c/29er
    Rear Spoke
    Price $3.10
    Use
    Commute Fitness
    User Weight
    220
    Wheel Build Weight
    802.88
    Jun 2005
    thanks. How is the velocity front hub? Any comments on their rear hub? I see you opted for a white industries rear hub in the back instead (nice).
    on a side note, also wondering if these wide rims can be setup safely to run 700 x 23 tubeless tires with stans conversion kit?
    May 2011
    The weight I believe was around 1430. Hubs so far are pretty good but have not put too many miles on the wheels. My LBS really liked the rear White Industries hub but had no comments on the Velocity.
    Reputation: krisdrum's Avatar
    Oct 2007
    I have a set of Escapes on the Velocity hubs, front and rear. They are 1 of my sets of Cyclocross race wheels. They are more than fine. Not the greatest spacing in the world, compared to Shimano specific hubs, but probably not far off from the DT Swiss 240 you are looking at as an alternative. The newer hubs coming out of Taiwan for the most part are pretty high quality. Pretty sure that is where Velocity sources there stuff, just like most of the folks out there.
    As for A23 builds, if you search around and have an LBS willing to do the build for you, you can source the parts for the build for under $300 from online sources. I just did it. Probably add another $100 to have the LBS do the assembly and build. Just another option.
    Burnum Upus Quadricepus
    Reputation: brucew's Avatar
    Jun 2006
    I bought a set of A23 Pro Builds last March.
    I have about 2,000 miles on them. (It's one of four bikes, so my miles get spread around to the other three as well.) I've been very pleased with them. The hubs at both ends roll and roll and roll…
    The freehub body is aluminum, so you'll want to be sure that you torque your cassette fully so that the gears don't dig into it. But that's true of every aluminum freehub body.
    I ride these wheels on cobblestones, on dirt and gravel roads, and on the potholed pavement of my commutes. They never complain. They happily ride over everything I've thrown at them. FWIW, when I can find some, they ride nice on good pavement too. ;)
    When I bought mine, the best price I found was at bikemania.biz. Their price is still $600 for the set. I haven't compared pricing lately.
    I have Velocity hoops on two other bikes, and one of those also has Velocity hubs. All together, I have about 11,000 miles on the three wheelsets. After 2½ years, I think I'll need to true the rear on my primary commuter come spring. That's all the maintenance any of them have had.
    Jun 2005
    Thanks for the replies. Thinking I'll just pony up for the complete wheelset since their hubs are decent & they come with cx-ray spokes standard. Fair to say I could save a some coin by lacing up my own set with revolutions & comps instead, but I do really like the look, quality, & strength of the cx-rays. Cheers
    Oct 2007
    Just a question for clarification. Are CX rays any stronger than Lasers/Revolutions? I know they are more aero, but they have the same gauge dimensions, so...
    Jun 2005
    round vs bladed.
    x-rays do not require filing to fit thru thru a normal hub spoke hole
    splitting hairs here a little - the weight of revolutions & cx-rays are about the same but cx-rays can be used on both the drive & not drive side of the rear wheel because they are stronger. Round spoked rear wheels typically use heavier (DT comps) on the drive side to balance the tension, but consequently makes for a slightly heavier wheel
    Just my personal experience, but the sapim spokes have a much softer flex when you are handling them. Not trying to start a debate on which is better, but I think they ride nicer too.
    DT-Aerolites are almost identical cx-rays, but for some reason are even more expensive
    Jun 2005
    sorry double post
    Oct 2007
    Quote Originally Posted by farva View Post
    round vs bladed.
    Not looking to debate this either, it was a straight forward question, no hidden agenda, just trying to understand. So having the ovalized cross-section makes them "stronger" because they don't flex the same in all directions? I'm still not following the "stronger" claim. Stiffer maybe because of the change in shape and the directions of stress.
    I've also seen plenty of full Rev builds DS and NDS in the rear. I guess that would be specified to a rider's needs. But I wouldn't say, based on my observations, that thin spokes always have a heavier thicker gauge spoke on the DS, so I am just trying to understand why someone would pick a particular build over another.
    Jun 2005
    My apologies, I don't have the answer why they are physically stronger. Perhaps it's a combination of the material, shape, & processing they use? Maybe a metallurgy whiz can chime in...
    I'm just saying since they are stronger in tension & more ductile in compression so they can handle the loads of both sides of a rear wheel better than the a single diameter round spoke used in the same application. Could someone get away with rev's on both sides? probably depending on weight, spoke count, usage etc...Personally I agree with Sheldon brown's recommendation & use larger diameter on the DS when lacing round spokes. It just makes sense to me
    Nov 2008
    I'm about to build a set of a23's while I'd love to save money I'm going with the cx rays as opposed to the thin round spokes. the ability to control twist during the build and any subsequent adjustments that might be required the only reason.
    life is short...bike rides don't have to be
    Oct 2007
    Sorry, not trying to be difficult or beat a dead horse, but where are you getting the tension and ductile compression information from? Mind sharing a link? My education and job has me using the scientist/practicioner model, so I tend not to take anything at face value.
    Reputation: NolesOrNothing's Avatar
    Aug 2011
    195 LB rider currently in the process of an A23 build with my LBS. 24 radial front, 28 3X rear. DT Comps all around to save $ and brass nips. They will be laced to a AC Micro 58 and a AC 205. All Black components. Projected finished weight is 1500g. Seems to be a bit of a back log for the 24 hole A23 at moment leading to impatience. These will be an everyday set replacing some well used and still true 2005 Ksyrium Elites.
    Apr 2007
    I'm running Hutch. Intensive 25mm on my Deep V's tubeless. I know the A23's are just a bit wider, so I'm sure you'll have a nice wide profile on a 23mm tire like the Atom or Fusion. There shouldn't be any problems.
    Oct 2010
    Have been riding on a new set I built 2 week ago; A23's, 28/32h, Laser's all round except for Race on DS with BHS hubs - 1560g, i'm 87kg. Seem great so far, have Hutchy Intensive's on them and the tyres are 23mm on my digital calipers, was a little disappointed on the tyre width actually, I was hoping for more girth.
    Oct 2007
    Quote Originally Posted by Crawf View Post
    I think a wider rim is less about girth and more about tire profile. What does the profile of the tire look like on the A23 compared to a more standard 19mm wide rim? That is where the difference will be seen (and I'm assuming felt).
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Quote Originally Posted by krisdrum View Post
    The general claim of enhanced strength for the rays is that the forging process to make them oval also strengthens the spoke, as compared to the drawing that a butted spoke takes.
    I won't back or deny the claim; that's just what it is.
    A good habit is as hard to break as a bad one..
    Jun 2005
    Quote Originally Posted by danl1 View Post
    - on the ductility Q (flexibility maybe the more appropriate term)
    take one round spoke & one cx-ray spoke of equal length & weight.
    put the threaded ends in a vise the same depth.
    flex the end of each spoke laterally with the same force.
    the cx-ray will deflect significantly further under the same force (without yielding)
    Because they are just as strong yet more flexible is why they cost 3x as much
    ...and IMO why they make a slightly better wheel.
    Just my .02
    EMR
    EMR is offline
    Apr 2002
    NolesOrNothing,
    I'm interested in your feedback on your custom wheel build.
    Aug 2011
    EMR,
    Thanks for you interest. The black A23s are 24 front 28 rear. I opted for Black American Classic Micro 58 front and 205 rear hubs on a very high recomendation from my LBS. I know folks on here have issues with them, but AC is located an hour from my LBS and I have a good relationship with the shop, so the expectations/ understanding is that if any issues arise they will be addressed quickly. I was also lucky in that a retired AC wheel builder did the build thru my LBS. They are laced radial front and 3X rear with black DT Comps and brass nips. Final weight is 1580 with skewers.
    I'm 6' 2 " 195 on a 60- 2005 Cannondale Caad8 R1000, flat black of course. So far after 150 miles, they're great. Roll so much smoother and efficient than the 05 Mavic Ksryium Elites they replaced.
    I can roll right along with my training partner who sports Zipp 404s. They're stiff with no flex and corner great with a new set of Hutchinson Fusion 3s, 23 wide.
    Attached Thumbnails Attached Thumbnails Velocity A23 Pro Build Wheelset-img_0410.jpg   Velocity A23 Pro Build Wheelset-img_0420.jpg   Velocity A23 Pro Build Wheelset-img_0419.jpg   Velocity A23 Pro Build Wheelset-img_0417.jpg   Velocity A23 Pro Build Wheelset-img_0415.jpg
    Feb 2012
    Just got my A23 build from Valleycyclist. Total weight 1549g I went with an all silver set up:
    Front: 652g
    A23 rim 24h
    Velocity Race Hub
    Spaim lasers
    Brass nips
    2x cross
    Rear: 897g
    A23 rim 28h
    Velocity Race Hub
    Spaim lasers NDS
    Spaim race DS
    Brass nips
    2x cross
    They sure look pretty. Hub is quieter than I would like, but they seem to roll smooth. I will post pics tonight. This was an upgrade over my Mavic Aksiums. I ended up fitting them with 700x23cc Vredestein Fortezza Tricomp's. Get to test them this weekend.
  1. Velocity A23 Custom wheelset
    By Guymk in forum Wheels and Tires
    Last Post: 10-23-2011, 09:14 AM
  2. Velocity A23 Wheelset
    By ticmxman in forum Wheels and Tires
    Last Post: 09-03-2010, 11:54 AM
  3. Velocity Tandem Wheelset
    By bobthib in forum Tandems
    Last Post: 11-22-2009, 08:26 AM
  4. Velocity Tandem Wheelset
    By bobthib in forum Wheels and Tires
    Last Post: 09-03-2009, 01:19 PM
  5. Velocity Spartacus Wheelset?
    By psuambassador in forum Wheels and Tires
    Last Post: 06-16-2005, 09:21 AM
Sea Otter Classic
Contest
