Results 1 to 8 of 8
    Apr 2004
    Wheels for a 250lb rider.
    Looking at a GIANT TCR COMPOSITE 2 but am nervous about the wheels.
    Any idea if the Shimano R-540 Areo Wheelset will hold up to a 6'5" 250lb guy?
    Don't know those wheels, but I AM a 250-pounder...
    Used to be, anyhow, and I seem to be headed that way again...apparently the beer-and-ice cream diet isn't the long-term answer.
    As far as wheels go, though, I rode thousands of miles at 240 and above, and I invariably had trouble with fewer than 32 spokes. We have a couple of good wheelbuilders here, and occasionally one would insist he could whip out some lightweight wheels that would do the job. Never happened. I suspect most mechanics, who like most cyclists are <150 pounds or so, don't really have any concept of what it takes to hold up a Clydesdale...
    Most of my riding now is on a pair of Rhyno Lites laced with 36 14ga. Wheelsmith spokes to Deore XT hubs (it's on an Atlantis, w/135 spacing, so I use an MB rear hub). Only very minor truing in about 3000 miles. I also have a backup set, some old 32-hole RSX hubs laced to Velocity Deep V rims. They seem plenty strong, too, but they're heavy.
    It's tempting to go lighter, but I've tried it often enough that I'm able to resist. If anybody says he can build you something like an 18- or 24-spoke wheel that will last, I'd ask him to guarantee it.
    Cicloturista
    Reputation: ruly62's Avatar
    Thumbs up Mavic Cxp33 36 Spokes
    Go with this wheelset,Colorado Cyclist sells this 14 spokes(ultegra or dura-ace)
    I am 230 and have broken many wheels. Spinergy spoxs, xeros, Rolf Pros, Mavics and I finally gave up on light wheels. I am now riding Chris King hubs 32, 14gaug, brass nibs and an offset rear rim. I have not had any problems with them. Don't go with lighter wheels because you will have problems down the road and will be upset.
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Quote Originally Posted by m0txr
    I've had good luck with the Ksyrium Elites, and I'm 6'4"/220 (on a good day). If that's too chi-chi for you, the CXP33's already recommended are fine, or, really, anything that you can get in 36-hole form will work well.
    jrm
    jrm is offline
    Dec 2001
    A good 32H 3x will work fine
    Im riding OP's with CK hubs, Therer 32H and laced 3 x with 14/15 guage spokes. Im hard on um and they hold up great. You wont need anything more than that IMO.
    The C/C wheels have worked well for me.....
    Quote Originally Posted by ruly62
    I've got a set of the CXP33 Mavics laced 36-3X with straight gauge 14s and Ultegra hubs and they are holding up well for me. Previously I had broken several spokes in my stock Lemond Poprad wheels. So far no truing has been necessary. I ride mainly pavement with some gravel roads and light trails mixed in. I'm usually anywhere from 225#-235#.
    Jun 2003
    I'm in the same weight class as you and ride M540s on my commuter bike - I haven't had to touch them in 6 months. They're light(ish), reasonably stiff and reasonably aero with teh low spoke count and bladed spokes. My LBS guy reckons the R-540s are just as strong. That said, the smaller diameter of the M's vs R's might be a factor. On my road bike I run CXP33s, 32H, 3x tied and soldered on campag hubs - these wheels are BOMBPROOF!
  1. Litespeed Choice - better frame, lower wheels or lower frame better wheels
    By Cool Roadie nom de Plume in forum Bikes, Frames and Forks
    Last Post: 04-15-2004, 10:29 PM
  2. Need cheap road wheels
    By weltyed in forum General Cycling Discussion
    Last Post: 04-02-2004, 02:35 PM
  3. why 700c wheels?
    By colker1 in forum General Cycling Discussion
    Last Post: 03-28-2004, 02:32 AM
  4. Low spoke count wheels - too fragile for me?
    By Rocketman58 in forum General Cycling Discussion
    Last Post: 03-02-2004, 11:13 AM
  5. Which wheels??????
    By JBergland in forum General Cycling Discussion
    Last Post: 02-18-2004, 04:02 PM
