Results 1 to 11 of 11
    Mar 2012
    Wheelset build for hybrid 135mm
    I'm looking to build my second set of wheels. I'm not all that experienced but the first build did go alright a year or two ago. Want to keep this one inexpensive as its for a hybrid. Also just want some more experience before I build up something more expensive for my road bike.
    Just wanted some suggestions as I don't see much for 135mm hubs.
    I'm thinking FH-t610 Deore rear hub and the hb-t610 for the front? Would those work? Any other suggestions?
    How about the rim. Would the dt swiss 460s work for a hybrid with those hubs? Again any other suggestions?
    I'm riding a few year old Specialized Sirrus with vbrakes. Also planning on using 28 or 32mm tires. I don't ride the bike hard, only use it around the beach or when I'll be commuting.
    My last build was 105 hubs with h plus son rims. I would of just liked to use these on the Sirrus but when I tried to fit the wheel it seemed like the sirrus uses 135mm.
    Thanks for any help.
    Dec 2011
    They shouldn't be impossible to find but they're not common. White Industries will make T11s in 135 spacing. Another alternative is just use a 135mm disc hub, which would work fine.
    Quote Originally Posted by sheepherder View Post
    If your hybrid is 8, 9 or 10 speed, yes, it'll work.
    I'm not aware of any others in the same price range as the Deore. It's amazing how cheap those hubs are and I hear they're actually half decent.
    grizzly moderator
    Reputation: dcgriz's Avatar
    Feb 2011
    The Deore LX FH-T670 would be another choice. Middle of the road, good touring hub.
    With bicycles in particular, you need to separate between what's merely true and what's important.
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by dcgriz View Post
    This is the way I would go. But does Shimano even make these hubs anymore? All the ones I've seen are new/old stock. The latest generation Deore series seems to have gone all disc.
    -- Warren Buffett
    grizzly moderator
    Feb 2011
    Discs is what is shown on their Tech Docs site. So I'm not sure but if I had to guess it would be "No".
    The 670 is readily available though so it doesnt really matter, at least for the short term. They are inexpensive enough to buy two, the second for parts.
    May 2014
    Quote Originally Posted by November Dave View Post
    I didn't know you can use a disc hub for rim brakes. Is this possible?
    -- Warren Buffett
    Dec 2011
    Sure. Just don't put a rotor on. Done. I rode a set of mtb wheels like that for ~18 months when I knew I'd be getting disc brakes but hadn't yet done it, and needed new wheels.
    May 2014
    Wow, I never knew it was that simple. Though of course, they would need to be quick release, right? Aren't most disc brake hubs going thru-axle now?
    -- Warren Buffett
    Dec 2011
    Most current hubs are adaptable to whatever axle format is needed.
    May 2014
    Good to know. Thanks Dave!
    -- Warren Buffett
  1. Wanted: 700c wheelset with 135mm rear spacing - buy or trade?
    By ChilliConCarnage in forum Wheels and Tires
    Last Post: 08-21-2006, 12:25 PM
  2. Wanted: 700c wheelset with 135mm rear spacing - buy or trade?
    By ChilliConCarnage in forum Pacific Northwest
    Last Post: 07-21-2006, 03:42 AM
  3. Wanted: 700c wheelset with 135mm rear spacing - buy or trade?
    By ChilliConCarnage in forum Cyclocross
    Last Post: 07-21-2006, 03:33 AM
  4. help with mt/road hybrid build up
    By grrrah in forum Beginner's Corner
    Last Post: 04-21-2006, 12:34 PM
  5. Help me build a tubular wheelset(135mm hub)
    By cantdog in forum Cyclocross
    Last Post: 09-12-2005, 06:09 PM
