Results 1 to 6 of 6
    Jan 2005
    when to replace alloy rim?
    I have some wheels with velocity A23 rims, with at least 15-20,000 miles on the front rim, which has never been replaced. I don't use a bike computer so I don't know really how many miles. It is hilly here, I brake a fair amount. How do you know when to replace a rim? I don't have a micrometer, but I could find one.
    Thanks for any comments!
    Feb 2002
    Quote Originally Posted by deadleg View Post
    No real need for a micrometer. You can basically feel/eyeball how much brake track wear you have. My approach to rim replacement has always been to have a spare rim on hand and then to rebuild the wheel if/when there is a problem with the current rim. Regular inspection of your wheels will tell you if there is any cracking or incipient brake track failure. There is absolutely no way to predict how many miles you will get out of a given rim - WAY too many variables.
    Many alloy rims have wear indicator. I don't know if yours do (or did). See if you can see one and if you can't maybe google to see if it came with one so you know if it's gone or was never there to begin with.
    If your break track seems overly concave then it's time. What is overly? I don't know, just use your best judgement I guess.
    Miles mean nothing. If you ride in the rain a lot, don't clean brake pads much, and brake hard alot you'd have a lot of wear. If you live in Florida (flat and good weather mostly) for example your brake track probably has very little wear.
    Jun 2017
    In case you don't trust your rims:
    Pump 15 PSI more than you do normally.
    If it doesn't fail it's fit for pupose....
    Quote Originally Posted by Keezx View Post
    I doubt it. I'd have to think rider weight hitting a pot hole would create more stress than 15 additional PSI.
    Or are you suggesting seeing if you can induce failure with too much PSI on when riding. That wouldn't be very bright.
    Reputation: Lombard's Avatar
    May 2014
    Trolls taste like chicken.
  1. cracked rim at spoke eyelet? replace rim or new wheels?
    By deadleg in forum Wheels and Tires
    Last Post: 08-30-2016, 10:54 AM
  2. Alu alloy free hub to alu alloy carrier cassette ?
    By Markocycling in forum Bikes, Frames and Forks
    Last Post: 04-02-2016, 03:48 AM
  3. Replies: 22
    Last Post: 10-04-2015, 10:27 AM
  4. 2006 Chorus alloy or 2006 Centaur alloy?
    By acid_rider in forum Components, Wrenching
    Last Post: 06-23-2006, 07:04 AM
