Results 1 to 11 of 11
    Jan 2009
    why did ligero stop making his hubs?
    just wondering why ligero stopped making his hubs?
    anyone know?
    Jan 2005
    The simplest answer is that his company went out of business. Why his company went out of business is not likely known to anyone but him (Troy), but it probably had a lot to do with poor customer service and missed product delivery promises to too many customers. Guessing that caused orders to dry up. Now Troy works as the wheel builder at Fairwheel in AZ.
    By the way, I am about to replace my Ligero "Model 1" wheels built on his last model hubs and ceramic-coated XR-300 rims. They have probably 1,000-2,000 miles on them and are in perfect working order. Let me know if you're interested in buying them.
    Nov 2008
    Troy left Fairwheel months ago.
    Jan 2009
    is there any other 2:1 specific hub out there?
    anyone know the flange dimensions of the ligero hub? i cant find it anywhere.
    Jan 2005
    Quote Originally Posted by aranesp View Post
    A few years ago after Troy started producing his last model of 2:1 hub, Fairwheel did post measurements and other comments about them (and many others) as part of a broad hub review. It used to be here, but is now gone: http://fairwheelbikes.com/forum/view...hp?f=65&t=6940
    Maybe contact Fairwheel and ask them? Or contact "madcow" on the Weight Weenies forum (he's at Fariwheel).
    Oct 2012
    tune and BikeHubStore offer hubs for 16:8.
    Jan 2009
    Quote Originally Posted by Orfitinho View Post
    not to sure if those are really 2:1 specific. just drilled that way.
    Jun 2005
    correct. same flange spacing as the 1:1 drilled ones.
    But the NDS flange spacing is kind of wide on those hubs.
    I hope Troy landed somewhere good. I had a set of his wheels that well built. I eventually found some rims I liked better and rebuilt the hubs on the new rims. I followed Troy's spoking pattern though and it's worked well on the new wheels.
    Jan 2009
    still having a hard time finding the dimensions, anyone know them?
    woz
    woz is offline
    Madcow
    Reputation: woz's Avatar
    Dec 2005
    Manufacturer: Ligero
    Model: Triplet road
    Notes: Rec. lacing 1x nds, 3x ds.
    Weight, Shimano: 249gr
    Available drillings: 24 Triplet
    Bearing material and other bearing notes: Ceramic with stainless option
    Bearing size, hub shell left: 6903
    Static load: 477
    Bearing size, hub shell right: 6806
    Static load: 650
    Bearing size, freehub body: MR1526 15x26x7mm (pair)
    Static load: 390
    Axle diameter: 17/15mm
    Freehub body material: Al.
    Available colors: Black, Blue, Gold, Green, Orange, Pewter, Pink, Red, Silver
    Price in USD: est: $400. (Sold for $600 as a pair)
    Flange diameters, L/R: 41/60
    Center to flange, Shimano: 49/18.5
    Bracing angle, Shimano: 10/3.9
    Tension differential Shimano: 72%
    Jan 2009
    wow, thanks for the info!
  1. Replies: 26
    Last Post: 09-14-2011, 11:46 AM
  2. Slate: Stop Means Stop. How do we get bikers to obey traffic laws?
    By 55x11 in forum General Cycling Discussion
    Last Post: 06-20-2011, 10:00 AM
  3. Ligero Version 2 Hubs/Wheels - First Impressions
    By Wines of WA in forum Wheels and Tires
    Last Post: 03-19-2010, 12:56 PM
  4. Hubs-Alchemy vs Ligero SLW
    By Pegorider in forum Wheels and Tires
    Last Post: 02-16-2010, 04:24 PM
  5. Replies: 81
    Last Post: 11-18-2009, 06:56 AM
