Results 1 to 9 of 9
    Road & Trail Warrior
    Reputation: jlandry's Avatar
    Jan 2007
    Why Not Stan's in the Tube?
    Regarding tubeless tires... why not just put the sealant into the tube?
    Theoretically, that would work, no?
    ----Sent via smoke signals----
    Reputation: ddimick's Avatar
    Aug 2011
    There are tubes that come with Slime sealant already inside.
    Mar 2012
    You can do it that way but that's not the only reason people go tubeless.
    Idiot at large
    Apr 2010
    Quote Originally Posted by jlandry View Post
    Because it won't be tubeless anymore.
    2010 Specialized Secteur Elite upgraded with 32T cassette and does not have Stan's (yet)
    2009 Specialized Rockhopper Comp 29er upgraded with 36T cassette and Stan's Arch EX rims and tubeless
    2013 Cannondale CAADX-6 Tiagra upgraded to 32T cassette and Stan's Alpha 400 rims and tubeless
    2008/2009 Burton T6 156cm with Burton Triad Bindings & DC Judge boots
    Jun 2010
    I do put about 1 ounce odf Stans into each of my clincher tire tubes. That was recommended to me two years ago and neither I nor my wife have had a flat since. That is about 7,500 miles between us. You do have to replace the tube though. I was told to do it after 6 months, but most of our riding occurs between April and November so I just do it before I start logging serious miles in April.
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    I put Stans in my tubes on my commuter bike. It doesn't dry out nearly as fast as slime, and it seals holes much more effectively. Just make sure you don't lose the valve core when installing!
    Reputation: foofighter's Avatar
    Dec 2008
    i had a hard time getting the stans in through the valve
    Ride More Talk Less
    - Caletti Cycles Custom Steel
    - 11 Nashbar Steel CX
    Terminal Pholocity
    Jerkhard Sirdribbledick
    Reputation: DrRoebuck's Avatar
    May 2004
    Quote Originally Posted by foofighter View Post
    TWSS.
    Also, take out the valve core and get that injector syringe.
    http://www.jensonusa.com/!KYXvoFzUhn...jector-Syringe
    "He groaned when we hung the rope over the tree but was relieved to see the white pinata."
    -- Gut
    _____________________
    L.A. Landscapes
    Reputation: froze's Avatar
    Sep 2002
    Slime doesn't work with high pressure tires. I tried a set of Slime tubes and when one went flat I aired up and when the pressure exceeded 65 psi the Slime wouldn't hold and blew out of the pin hole I had. Also Slime tubes have the poorest made presta valves on the market and will last about 6 or 7 uses before they fail.
    I don't use gunk in tubes. If you decide to use gunk get the stuff that foams instead of a liquid. The foaming action stuff will help prevent sidewall punctures whereas the other liquid stuff won't.
    http://www.youtube.com/watch?v=xk98yvozq1g
    http://www.youtube.com/watch?v=nvk63...eature=related
    http://www.youtube.com/watch?feature...&v=p92Stnnigjs
    "They don't do things that way anymore. This is the Age of Science Know-How, electronal marvels."
