Results 1 to 2 of 2
Thread: Wider Wheels
    Wider Wheels
    I've got a 2003 Trek 5500 with Bontrager Race X-Lites and probably want to go with HED rims. (not the plus size) There's only a small amount of wheel clearance so I didn't know if they'd fit or not. I plan on going to a local shop to try a wider wheel on for size, but I'm wondering if anyone else with a similar bike already has the wider wheels.
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Stew View Post
    Is it the wheel clearance that is tight, or just the tires? My guess is it's the tire clearance that is the issue. If this is the case and a wider rim fattens the tire to where it rubs against the frame, you will need to use the next size narrower tire.
  1. Wider Road Wheels
    By Lombard in forum Wheels and Tires
    Last Post: 11-16-2015, 06:18 PM
  2. Wider Rim Width for Road Wheels
    By gearloose in forum Wheels and Tires
    Last Post: 06-27-2014, 05:21 AM
  3. Wider rims, Wider tires... Wider inner tubes?
    By ToffieBoi in forum Fixed/Single Speed
    Last Post: 08-18-2013, 11:54 AM
  4. Determining clearance for wider wheels and tires
    By Wines of WA in forum Wheels and Tires
    Last Post: 07-17-2013, 01:16 AM
  5. Wider wheels...Who sells them?
    By B.Garcia in forum Wheels and Tires
    Last Post: 06-02-2013, 10:53 AM
