Page 2 of 2 FirstFirst 12
Results 26 to 41 of 41
Thread: Yoeleo
  1. #26
    Pathlete and Pedalphile
    Reputation: redondoaveb's Avatar
    Jan 2011
    Quote Originally Posted by myhui View Post
    I have found the same thing with my Farsports wheels. I don't know whether it's because the heat dissipates more evenly throughout the wheel due to the basalt surface, or the heat goes onto the brake pad more than onto the wheel. Aluminum is a poor heat conductor, so localized heating on it is to be expected.
    My wheels are Farsports also.
    If you try to fail, and succeed, which have you done?
  2. #27
    Sep 2011
    Quote Originally Posted by redondoaveb View Post
    Bottom line for me anyway is that I'm not sure if my wheels will ever fail but for them to fail due to heat build up is not on my list of concerns.
    if it's not of concern for you, than that's good
    for those who may not be as unconcerned as you are, the information is out there.
  3. #28
    Jul 2011
    I would not ride Chinese carbon wheels downhill. No freakin way. Their resin is not anywhere close to dealing with heat like wheels made in Europe and the US. On the flat, ok. Downhill, no.
    LOL, chances are they may have better resins in China as they don't have the regulations that we deal with here. I spent a good part of my work efforts dealing with failing materials when regulations kicked in limiting what can be used in the US.
  4. #29
    Jan 2014
    Well the wheels arrived less than one week for delivery. The curier actually said is there anything in this box it's vey light.
    on opening everything looks ok & is very neat just no bloody rim tape so it's back to the bike shop tomorrow to purchase some. On the scales front wheel weighs 1.8lbs rear 2.8lbs.
  5. #30
    Jan 2011
    Please provide information that tells me that Chinese wheels are not to ridden downhill. I believe any concerns that are out there apply to all carbon wheels with carbon brake tracks, not just Chinese wheels.
  6. #31
    Dec 2012
    Quote Originally Posted by skott80 View Post
    814grams for a front wheel ? What's the point ??
  7. #32
    Jan 2014
    Ok iv finished two rides now on the carbon wheels, I'm very impressed with the quality & finish. Ride one was during cold frosty weather, ride two wet & windy. There was no handling or braking issues. The wheels were very responsive and I have noted a increase in speed. I can reccomend this seller and I will purchase from them again.
    Any questions please ask.
  8. #33
    Jan 2014
    Hi I choose 3k
  9. #34
    Jan 2014
    4.6 lbs! That is 2100g! Kinda heavy in my book!
  10. #35
    Jan 2014
    skott - If you purchased the 50mm clinchers you posted a link for in your first post then the wheels should weigh in at 1650 +/- 10 grams... something is not right.
    1650+/-10g/set
    1650+/-10g/set
  11. #36
    Jul 2012
    Old post I know. All of the Yoeleo wheels are UCI approved, so has that changed the minds of the cautious ones?
  12. #37
    Oct 2013
    He decided to use lead rim tape, cause it's metal.
    BANNED
  13. #38
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Helps electrosensitivity and/or windfarm-disease sufferers. Has to.
  14. #39
    Jul 2012
    Lost me on the last 2 posts.
  15. #40
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by Methodical View Post
    Your sarcasm detector must not be working.
  16. #41
    Jul 2012
    Yeah a bit slow. forgive. I figured it was sarcasm, but wasn't sure if it was directed at the OP or the poster who had issues with Chinese carbon wheels (thinking this person).
  1. YoeLeo Rim rear build
    By boneman in forum Wheels and Tires
    Last Post: 08-23-2013, 12:56 AM
  2. Yoeleo Build Finished
    Last Post: 04-12-2013, 02:39 AM
  3. Yoeleo 23 Rims Early Report Pre-Build
    Last Post: 01-13-2013, 12:33 AM
