Results 1 to 8 of 8
Thread: Zipp 404 help
    Dec 2013
    Zipp 404 help
    Hey guys, i really need help with next thing. I got Zipp 404 rear wheel, but im not sure what year is it. I believe it is 2010, but i would need comfirmation. So if anyone can detect what year are they i would appriciate. Next question i got is..can the wheels fit 23mm tire? I think they are 25mm wide. Any opinion welcome.
    Thanks!!
    Zipp 404 help-img_6008%5B1%5D.jpgZipp 404 help-img_6007%5B1%5D.jpgZipp 404 help-img_6006%5B1%5D.jpgZipp 404 help-img_6009%5B1%5D.jpgZipp 404 help-img_6010%5B1%5D.jpg
    Feb 2012
    Zipp 404 with 188 V6-V8 rear hub.
    There's a recall for the front 88 hubs.
    http://www.zipp.com/_media/pdfs/supp..._2016_edit.pdf
    Dec 2013
    I do not have front wheel.
    'brifter' is a lame word.
    23mm tire fits.
    I work for some bike racers
    and a bunch of skateboards
    Dec 2013
    Thanks for replay! R u sure? This is not 27mm wide rim
    Quote Originally Posted by karlov View Post
    You talking about the 23mm tire fitting? Of course it would...do you know of ANY rim made in the last decade that a 23mm tire won't fit on?
    If you want to make sure your question gets answered by the right person use the quote feature.
    Dec 2013
    Thanks! And what about 25mm. Im riding Scott plasma 5 but it looks like 25mm on other rear wheel doesn't fit good on frame.
    Feb 2002
    Fit in the frame has nothing to do with whether the tire will fit on the rim. A typical road rim will easily fit 19-32 mm wide tires, and wider probably as well. Whether that will fit in your frame/fork has virtually nothing to do with the width of the rim. Rim width slightly affects the width of the mounted tire, but it is not a big effect.
  1. Zipp 60 vs Zipp 404 Firecrest (clinchers)
    By superflylondon in forum Wheels and Tires
    Last Post: 09-16-2014, 08:05 AM
  2. CLYSDALE SRAM S60 zipp 404 zipp 60 cosmic carbone SL
    By mxadam579 in forum Wheels and Tires
    Last Post: 05-27-2013, 09:04 AM
  3. Zipp 404 or custom build with zipp rims?
    By domo in forum Wheels and Tires
    Last Post: 05-27-2005, 07:21 AM
  4. Zipp 303 Tubular wheels / Zipp 280 rims
    By Daddy yo yo in forum Wheels and Tires
    Last Post: 04-07-2005, 01:24 PM
