Results 1 to 6 of 6
    May 2015
    Stock Madone 3.1 WSD...what's the largest tire that fits?
    Like to move up to a 28 if possible, however just don't know if it will fit. Looks like a 25 will for sure. Any advice?
    Dec 2006
    The surest method is to buy a tire and mount it to check for clearance. You can always return it unused for a refund.
    I did just that when I was curious how large a tire would fit on my new fork and frame. I actually returned the tire twice, to try the next largest size. When I was done with the experiment, I returned the last tire and got a refund. The shop didn't mind at all as the tire was not used. Keep your receipt!
    Reputation: Alfonsina's Avatar
    Aug 2012
    Really, if you have a proper bike shop, they are going to be able to get you that information. Or the manufacturer of said bike.
    May 2009
    Try a measuring tape. Measure between the brake pads, measure distance from the top of the current tire to the top inside of the fork, and clearance from the tire edges to the insides of the fork. That should at least let you know if it's worth ordering anything.
    And buy the tires from somewhere you can return them.
    May 2015
    Quote Originally Posted by Peter P. View Post
    Yep, that would do it, just wondered if someone had gone that route before me.
    Quote Originally Posted by aureliajulia View Post
    Thanks!
    Mar 2014
    One problem with this method is that different tires have different profiles. One company's 28mm tire will be taller and rounder than another's, so the best method is the one that Peter P. suggested: buy one and try.
  1. Replies: 4
    Last Post: 05-06-2013, 11:53 AM
  2. Replies: 2
    Last Post: 02-25-2013, 12:10 AM
  3. Replies: 2
    Last Post: 02-13-2009, 12:10 PM
  4. Largest Tire Width on Your Madone?
    By slideeslide in forum Trek
    Last Post: 10-06-2008, 07:27 AM
  5. anyone go custom if stock fits fine?
    By jimcav in forum Bikes, Frames and Forks
    Last Post: 02-07-2007, 11:53 AM
