Hello. I have Shimano RS100 wheels that are 17c. 28c GP5000 tyres and I weigh 183lbs. I know this gets asked alot but what would you recommend for psi for the most comfort? I ride on alot of rough roads so comfort is paramount.
Also what is the lowest psi I could get away with?
"Also what is the lowest psi I could get away with?"
The answer to that, and your overall question, is 'trail & error". Or 'it depends'. Some people 'ride heavy' and have a knack for not seeing railroad tracks while others just float over stuff.
At your weight I'd start at 85 and experiment from there.
Use that as a starting point. The 2nd calculator. Then adjust till you get it dialed in.
^^^^ This.
I know a guy who weighs ~220-240. Rides 23/25mm tires. He rarely gets flats. Rides low spoke wheels without destroying them.
And I know many others who weigh much less who seem to get flats just from looking at their bike.
I started my relationship with road bike cycling back in 1983. Back in the eighties the stock or standard everyday tire on bikes got flats just sitting in corner of your room or even if you looked sternly at them.
^^^^ This.
Thanks very much. Using the calculator what weight distribution do you think I should use?
Haha, according to the first calculation on that site, I should have my tire pressure at 185 psi.
Lost in translation?
What Does ‘weight measured at wheel’ mean?
Like most topics regarding bikes there is disagreement on what is the best air pressure or formula for coming up with a number. The disagreement extends to certified experts on cycling and those that are accepted as experts based upon their body of work. I am neither. The only thing that seems agreed upon on air pressure is if you lower the PSI within tire recommendations of maximum and minimum the ride will be softer.
Here is one answer for someone that has achieved a satisfactory air pressure on a 23c and is moving up in size. It explains larger tires mean larger volume so a lower PSI is appropriate as you move up in tire size.
It means exactly what it sayes, measure your wt at the wheel. Put the scale under the front wheel, sit on the bike, read the wt. Repeat the the procedure with the rear wheel.
If you want it exact, do the same without u... subtract those wts.
Is that so complicated?
Another question. In the Beginners Corner it doesn't show any threads. This is the same when using Tapatalk and also the web page, all i can see are the sticky threads. Any ideas?
I'm running a similar wheel, Ultegra 6800's with GP4000's in a 28 width. I'm 225 and running 75 psi front and rear. Have about 200 miles on this combo without a pinch flat so far.
You can't fix stupid.
Originally Posted by JoeDaddio
Many thanks.
Sent from my SM-N920I using Tapatalk
Down towards the bottom you should see "Thread display options". You won't see it now, when in this thread, but when you first enter the branch and see the stickeys lined up.
This branch doesn't get much traffic so change it to look a year back or whatever. Your default probably doesn't go back far enough to capture a period when there were any questions.
It's a little vague, but what it means is the total pressure for both your wheels. You need to divide it proportionally by your weight distribution. Which is what the 2nd calculator does.
The 45%/55% distribution is pretty realistic. 40/60 gives you a large disparity between front and rear. I like running less in the front than rear, but not as wide a difference as the 40/60 gives me.
The beginner's corner is all but dead. Best to ask your questions in "Wheels & Tires", "Components & Wrenching", "Bikes, Frames & Forks" or "General" if it doesn't fit the previous three. The manufacturer forums are also next to dead.
OP - I'm about your weight and run 28s. I think my rims might be slightly wider than yours (Velocity A23s) and routinely run my tires between 50 and 60 psi with no issues at all. I do tend to ride "light", so YMMV.
Since this is the Beginner's Corner, and I just feel pedantic this evening....(I do intend this to be helpful, not snarky)
It isn't a "28c" tire. It is a 28mm tire. The letter C has no meaning when it comes to tire size, only the wheel size. The wheel size has the letter after it, 700c (or 650b, 650c, etc.).
Unfortunately, some tires are marked "700X28C" when they should be marked "700cX28".
Actually, if you want to be technical, it really should be marked "622 x 28". See below for the straight poop on bike wheel/tire sizes:
The Conti Ultra 2000 tires I'm running say, "25 x 622" right beside the "700 x 25C" on the label. The Gatorskins are marked "28 x 622" above the "700 x 28C." On other tires, this 622 figure is embossed on the sidewall.
I measured bead diameter as 622mm on both rims.
Also, one maker's 25mm might actually be fatter, "26C", or skinnier, "23C," than another's, so outer tire diameters wouldn't all conform to "700C" if that's supposed to identify outer tire diameter. 700mm is 8mm bigger than 622mm, so bead to outer tire diameter would vary from 4 mm around the rim.
The "700C" may be nonsensical, but it's there, regardless. We always thought of it as bead diameter slightly smaller than "27 inch."
^This, thank you!^
I work for some bike racers
and a bunch of skateboards
