Basic Bike Maintenance
Results 1 to 7 of 7
    Apr 2005
    So I'm new to the sport and I just started riding a Specialized Allez 3ish weeks ago. I was wondering what are some basic maintenance things I should be doing after every ride, every week and every month to keep my bike in perfect shape. Also was wondering what air pressure should I put in my tires? I'm a medium size guy 5'7'' 160 if that makes any difference.
    Thanks,
    Aleks
    half-fast
    Reputation: 10ae1203's Avatar
    Jan 2007
    Pay attention to it. Listen to it, notice how it shifts, etc. These things will let you know when it is time to tighten a cable or some other thing.
    Look at your tires for cuts, nicks, etc.
    I'm not much for schedules.
    Reputation: AndyP.'s Avatar
    Mar 2006
    Also, buy a copy of "Zinn and the Art of Road Bike Maintenance". It is an easy to read book with great illustrations. Very helpful.
    scruffy nerf herder
    Reputation: funknuggets's Avatar
    Tire pressure.
    Eliminate creaks/pops/rattles.
    Do not overtighten.
    Periodically clean/lube chain... pivots, etc with something other than wd40 or triflow.
    Verify you dont have any lops in the wheels (true... side to side), or hops (up and down). And check spokes to make sure none are loose.
    so sayeth the funk....
    Chris
    "The RBR Lounge. You won't ever find a more wretched hive of scum and villany. We must be cautious."
    Reputation: Akirasho's Avatar
    ... modern machines are fairly easy to maintain and have a good many user servicable parts installed so it's possible and to a goodly extent, preferrable to do your own maintenance (the warning from your LBS aside (we fix it, $10... we fix it after you tried to fix it $90)). Understanding and becoming familiar with your bike can also be beneficial for those occasional mechanicals out on the road...
    visit http://www.parktool.com for a bit o info... along with Sheldon's (RIP) site http://www.sheldonbrown.com
    Beatchin' Technology
    Reputation: thegock's Avatar
    May 2006
    Two tips
    Run the tires at 120lbs if they are rated there.
    Lube and clean the drive train a bit more frequently than you think you should. I usually spray a tiny bit of lube on the chain before each ride.
    Have fun.
    U gne n'e' par niseun'
    CAAD 10 Black, Di2 Ultegra 10 speed, Ksyrium ES, two tail lights
    Colnago Superissimo steel 1992, 9 speed Chorus, Ksyrium Equipe, dented top tube
    Colnago C-50, 10 speed carbon Record compact, Reynolds MVC 32's, Salsa skewers, Acros headset, Dura Ace pedals, Conti 4000's, Barmac integrated bars, white, red, and green tape, LED on NiMh AAAs, Dorkly left barend convex mirror
    Fat'r + Slow'r than TMB
    Reputation: jupiterrn's Avatar
    Sep 2006
    I like to use the analogy of a road bike is like a Ferrari and a MTB is like a Jeep. Ferrari look better all nice and clean and Jeeps look sexy as he** covered in dirt and mud. While both require maintence I do tend to spend a little more time keeping my road bike "clean". Wipe it down the frame after a ride (pledge wipes do the job really well), keeping grime off my chain, wipe the braking surface with a clean rag to get any oils or dirt off of them. After a short time, these issues should only take about 5 minutes after each ride. As for tire pressure, there have been SOOOOOOOOO many threads about it and I think I can safely say that no one can agree on tire pressure. Most folks I have talked and ridden with keep their tires at somewhere between 100- 110 PSI. Check tire pressure before each ride.
    Just fast enough to know I am slow.
