break in period question
Results 1 to 25 of 28
    Apr 2020
    Does a bike's crankshaft and/or bearings have a break in period when new? I just took my new Giant road bike out for a first decent ride, and there is a clicking noise whenever I am pedaling. It's not at a regular cadence or frequency. Before I got this one, I also test rode two similar models at my LBS, and they were doing the same thing just riding up the street a few blocks.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by DanV View Post
    Nope
    I would say take it back to the LBS. They didn't put it together right. But given all their bikes do it, I'd go to a different LBS. They sound incompetent.
    Just an FYI, clicking while pedaling may not be from the crank. Lots of other things can click while pedaling. Stems, seatpost, wheels.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Possibly not enough carbon paste between frame and seatpost can cause creaking.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Feb 2002
    While it could easily be the bike itself, there are a huge number of possible sources other than the bottom bracket (what you call the crankshaft). It could also be something as simple as a shoe lace hitting the frame every time your foot goes around.
    Hard to believe three different bikes made the same noise. They may be crappy mechanics but to do that on purpose it would take a very good one.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Does this only happen when you're sitting on it and pedaling under real load, or does the sound also happen if you put the bike in a workstand or just lift the rear wheel up and pedal with your hand?
    Mar 2019
    This happened to me, although it wasn't a shoe lace it was my foot hitting the excess cable from the front derailleur that somehow managed to turn outward. Took two days to track it down and required a 6 second fix. UGH!
    Mar 2019
    Also check the pedals to make sure they are tightened properly.
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    At this point, it makes sense to shine the cxwrench beacon in the sky.
    Apr 2020
    Quote Originally Posted by jetdog9 View Post
    I checked with the rear wheel off the ground and it wasn't doing it. So now I narrowed it down to the seatpost creaking. With my hearing being less than stellar, it sounded like it was coming from near the pedals, but on a ride this morning I tested it by coming off the saddle and the noise stopped.
    Lombard mentioned earlier about not enough carbon paste between the frame and seatpost. I will look into that as well as any other suggestions. Thanks.
    Banned Sock Puppet
    May 2014
    Good or bad hearing is irrelevant. Bicycle creaks can be very elusive and for some odd reason, don't necessarily sound like they are coming in the direction you think. My 2014 Cannondale Synapse Carbon had these creaks when new until I figured out what was wrong. You especially want to get the torque right - tight enough hold the seatpost in place without creaking, but not too tight as to crack the frame. Mine is 5Nm. Not sure what yours is.
    "With
    -- DCGriz, RBR.
    Neophyte
    Jul 2007
    Quote Originally Posted by SPlKE View Post
    Ha! Can't rep, though.
    OP, word of caution... use torque wrench when playing with any bolts, but especially with seatpost binder. It's really easy to over-tighten those and damage seatpost, break the head off the bolt, etc.
    Banned Sock Puppet
    May 2014
    I would be much more concerned with cracking the frame.
    "With
    -- DCGriz, RBR.
    Sep 2007
    As we learned in another RBR thread, frames are easily repaired with some sandpaper and a can of spray paint.
    Reputation: velodog's Avatar
    Sep 2007
    Attachment 327593
    let's hope this works
    Too old to ride plastic
    Apr 2020
    Not sure either...the owners manual is for all Giant bikes, and has torque settings for M4, M6, and M8 seatpost bolts...no idea what this one is and can't find it anywhere on line. I ended up calling the store where the previous owner purchased it and the guy said 5-9 Nm. None of the ranges in the manual match that.
    tlg
    tlg is offline
    May 2011
    Did you look on the collar, they often have the torque printed on them. I seriously doubt your seatpost bolt uses an M4 or M8. Those are both way too small and way too big.
    Torque values aren't an exact science. Use 5-9 Nm and you'll be fine.
    Dec 2014
    This is a known problem.. mildly annoying that you get used to. My Giant Defy Advanced Pro 0 (it's about 4 or 5 years old now) with DI2 has the creak in it...
    Banned Sock Puppet
    May 2014
    Whaaaat??? 9Nm is way too high for a seatpost on a carbon frame. I would say go for the low end of that like around 5Nm and no higher than 6Nm. As TLG said, look at the collar, or if it doesn't have a collar, around the insert. If you're my age or older, you will most likely need a magnifying glass to find this number.
    "With
    -- DCGriz, RBR.
    Sep 2007
    Attachment 327593
    vBulletin Message
    Invalid Attachment specified. If you followed a valid link, please notify the administrator
    Confiscated by the "authorities" no doubt.
    tlg
    tlg is offline
    May 2011
    vBulletin Message
    That's what happens whey ya try and post porn.
    Apr 2020
    So the winner is....6Nm. There is no collar since this frame design has the bolt going down into the frame just next to the post, and covered with a rubber lid. But it does show the torque setting...should have looked there instead of owners manual and calling the LBS. Other than that, sounds like the creaking could stay.
    Sep 2007
    I thought bike porn was A-OK with The Authorities, in these uncertain times, as long as it doesn't contain a podium w/girls and/or girls w/o the podium.
    Banned Sock Puppet
    May 2014
    So the winner is....6Nm. There is no collar since this frame design has the bolt going down into the frame just next to the post, and covered with a rubberlid.
    Ahhh, just like my Synapse. Cannondale claimed this made the ride more complaint due to more seatpost being exposed and therefore more post flexing.
    Did you try more carbon paste?
    "With
    -- DCGriz, RBR.
    Sep 2007
    vBulletin Message
    Damn, I guess it didn't work.
  1. Event timing- after peak period or after first race period?
    By TDFbound in forum Racing, Training, Nutrition, Triathlons
    Last Post: 07-31-2017, 04:19 AM
  2. Wheel Break-In Period...
    By swerv512 in forum Wheels and Tires
    Last Post: 03-19-2008, 08:57 AM
  3. 700c Studded Tire Break In period
    By abiciriderback in forum General Cycling Discussion
    Last Post: 01-24-2008, 11:36 AM
  4. new chain break in period?
    By percy in forum Components, Wrenching
    Last Post: 08-25-2006, 12:09 PM
  5. Do hubs have a break-in period before they roll smooth?
    By mwilcko2 in forum Components, Wrenching
    Last Post: 01-20-2006, 05:50 AM
