tire pumping assistance needed
Results 1 to 10 of 10
    May 2009
    I own this bike: https://www.giant-bicycles.com/us/co...sl-1-disc-2018
    Factory tires on it, tubeless.
    They are a bit deflated after not having been on the bike in awhile.
    I've never had tubeless tires before, as I am a beginner.
    Can I pump up these tires with a regular old floor pump like I used to do on my old bike with tube tires? If so, do I need a special valve on the pump?
    Or, can I not do this, and if not, what do I need to do to get the tires back inflated fully?
    Thanks in advance.
    -Wolf
    'brifter' is f'ing stupid
    Can you pump them up w/ a regular pump?
    Maybe. Depends on a couple of things. Generally floor pumps don't put enough air volume into the tire quickly enough if the bead has come unseated. If the tubeless sealant has dried up inside the tire you'll have to add some. I'd just try inflating them and see what happens. If it doesn't work you know what to do. It's impossible to provide an answer that's 100% over the interwebs.
    #promechaniclife
    Russian Troll Farmer
    Sep 2016
    And if it doesn't work, just put a tube in it........
    "L'enfer, c'est les autres"
    Oct 2013
    ohhhhh .... the tyranny!
    BANNED
    gazing from the shadows
    Jan 2003
    Yep, mostly.
    I always have been able to. Sometimes with no issue (no air but bead still set or mostly set), sometimes with using my hands to get the bead as set as possible before using the pump (when the tire has been off the wheel, or when adding sealant). Pump really fast for a few pumps, then normally, that's worked for me.
    An air compressor does the trick. If you don't have one, you can take it to a gas station and give it a quick blast to get it started, then finish with a hand pump. Might require getting an adapter for the presta valve, which are cheap and good to have in any case.
    Sep 2016
    In the immortal words of Declan McManus:
    Pump it up, until you can feel it
    Pump it up, when you don't really need it
    Fred the Clydesdale
    Reputation: rider9's Avatar
    May 2011
    If you can't get them aired up with a pump you have choices. Take your bike to the local gas station that has air, your local bike shop or use a CO2 cartridge inflator. I bought an electric air inflator and it works fine.
    If you let it go until the tire is completely deflated, you'll need to replace your sealant.
    Member of Team Collin, a group of ordinary moreons going to extraordinary levels of awesome in the fight against cancer.
    Love conquers all. God is love. Jesus is love personified. Figure it out.
    Quote Originally Posted by rider9 View Post
    What? That is definitely not a must.
    #promechaniclife
    I love to climb!
    Reputation: Jwiffle's Avatar
    Mar 2005
    Only if the sealant leaked out or completely dried up. It is quite possible to completely deflate the tire and still have perfectly good sealant.
    Stop in at Element Sports. www.elementsport.com
    Get Out! Have Fun!
    May 2009
    Update. Was the sealant, had to refill that first. Thanks to all who responded.
  1. Positioning of valve when pumping your tire
    By BostonG in forum General Cycling Discussion
    Last Post: 12-05-2011, 03:59 PM
  2. Replies: 8
    Last Post: 04-09-2009, 08:18 AM
  3. assistance is needed in the cookie recipe aisle
    By kykr13 in forum The Lounge
    Last Post: 10-18-2008, 05:17 PM
  4. Assistance needed locating for for 27" wheel
    By big boy phil in forum Retro-Classic
    Last Post: 09-02-2005, 11:14 AM
  5. Tire pumping problem
    By azmadoc in forum General Cycling Discussion
    Last Post: 06-14-2005, 01:52 PM
