2017/2018 Supersix Owners: How much gap is there between fork and frame?
Results 1 to 4 of 4
    May 2012
    Is your gap completely flush? 1mm gap, or 2mm gap?
    Mar 2012
    2018 super six
    May 2012
    Keep in mind this is very close up... normal?
    Jan 2014
    I'm confused is the question purely aesthetic?
    Surely you would NOT want there to be NO gap ("completely flush") since at that point the fork and head tube would be rubbing.
    As for whether 1 or 2 or 3mm is "correct" I think you can only answer this by checking:
    1) is the fork race properly installed (all the way down) on the fork?
    2) is the lower headset bearing mating properly with the fork race?
    3) is the lower headset bearing fitting properly inside the "cup" of the bottom of the head tube?
    If the answers to all of those questions is "yes" then everything is great, regardless of how big or small the gap is. And if one of those answers is "no" then you have a problem, regardless of the size of the gap.
  1. Replies: 3
    Last Post: 09-10-2017, 07:09 PM
  2. Fill in the gap between fork and headtube
    By LC in forum Bikes, Frames and Forks
    Last Post: 02-21-2013, 02:58 PM
  3. Replies: 4
    Last Post: 02-03-2013, 10:55 AM
  4. Replies: 1
    Last Post: 06-22-2012, 10:57 AM
  5. Bush Email Gap = Nixon Tape Gap?
    By spyderman in forum Politics Only
    Last Post: 03-22-2007, 10:45 AM
