Alpha-Q CS-20
Results 1 to 8 of 8
Thread: Alpha-Q CS-20
    Nov 2006
    Alpha-Q CS-20
    Anyone have experience with this fork. I'm replacing my Columbus Carve with this, courtesy of the Farmington School bus and my ditch diving. LBS found it on sale for me...anyone's opinions/thoughts/warnings?
    "It was a bio-mechanical" both legs went flat....
    kmc
    kmc is offline
    Oct 2002
    got one...
    I got one on my custom Curtlo. I like the look of straight forks, plus I like True Temper's approach to the steerer tube where you have to glue the aluminum insert and use a traditional starnut. This design does have its drawbacks...once the insert is set you can only cut an additional 10mm.
    Another thing...it has a matte finish instead of a gloss.
    I think I paid $215 for mine directly from Doug Curtiss...not too bad for a reasonably light (425 grams) fork. The fork seems plenty stiff for me.
    Any other questions, let me know.
    Nov 2006
    Thanks, any other takers, I know there's lots of opinions out there on this...
    monkey with flamethrower
    Reputation: Rubber Lizard's Avatar
    May 2007
    An excellent fork with no drawbacks other than the funny stem insert thing. But that has its advantages too. True Tempers compare with the best of them
    Chances are, I posted this drunk.
    Juanmoretime
    Reputation: Juanmoretime's Avatar
    Nov 2001
    I can't comment on the fork your looking at although I'm currently riding an Alpha Q GS-30 and find it to be the best fork I've ever ridden. Its very light while not being the lightest. The little bit of extra weight, it weighs 302 grams with the insert glued, seems to be carbon in the right places for stiffness that just shows up as a firm ride and instant response.
    For my next trick I will now set myself on fire!
    Reputation: AlexCad5's Avatar
    Jan 2005
    They are Sexay!
    or so I'm told. Sorry I couldn't resist.
    Aug 2004
    Years late to the party ... I just bought one of these forks off of eBay to replace the broken fork on my Fuji road bike. Really nice fork except that the bridge is significantly lower than on the original Fuji fork and the 28c tires I was running are now rubbing on the underside of the Alpha Q fork. I have another wheelset with 25c tires and they fit fine..
    'brifter' is a lame word.
    Quote Originally Posted by jkretsch View Post
    After 11 years I'm sure the world is a better now that you've posted this.
    I work for some bike racers
    and a bunch of skateboards
