Bent Dropout (Steel Frame)
Results 1 to 6 of 6
    Sep 2018
    I have a frame that was damaged in shipping due to improper packing. Can dropouts on a steel frame be straightened and realigned if slightly bent, and are they reliable once that is done?
    Is this something a local bike shop can do correctly, or do I need to find a framebuilder?
    At present, unable to get the rear wheel onto the bike...
    Thanks in advance for helpful replies.
    Dec 2006
    Yes; that's one of the benefits of steel frames.
    Any bike shop with the knowledge and tools should be able to do it. Heck; I have a pair of dropout tools!
    Depending on how much they are bent will determine if, after they are bent back, if they'll eventually fail. But don't worry; a broken dropout will not be catastrophic nor will it leave you stranded. You'll be able to ride it home. I speak from experience.
    Reputation: velodog's Avatar
    Sep 2007
    Like Peter P sez. They're made from soft steel so not brittle to have the ability to be straightened.
    Too old to ride plastic
    Nov 2014
    +1 on being able to ride it home. In my case I thought I had broken the rear axle, but it was the dropout. Guess the skewer held everything together and I made it the 20+ miles home.
    Easy job for most shops with the correct alignment tools.
    Reputation: DocRogers's Avatar
    Feb 2006
    One of the many advantages of a steel frame. The only drawback is you cant use it as an excuse to n + 1.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Is this a frame you bought and it was damaged? Whether it CAN or CANNOT be straightened, I would contact the vendor about exchange. Improper packaging is their fault. You didn't pay for a damaged frame, did you?
    Statistics are like bikinis. What they reveal is suggestive, but what they conceal is vital. -- Aaron Levenstein
  1. bent dropout - bend it back?
    By fjg246 in forum Components, Wrenching
    Last Post: 06-09-2008, 12:38 PM
  2. Std sliding dropout & hooded sliding dropout
    By lawrence in forum Bikes, Frames and Forks
    Last Post: 04-22-2008, 07:09 AM
  3. Bent Davis Phinney Bent Steel Dropout
    By powerdan5 in forum Serotta
    Last Post: 11-16-2006, 03:58 PM
  4. Bent Fork Dropout, What to Do?
    By mossy in forum General Cycling Discussion
    Last Post: 09-30-2004, 08:29 PM
  5. Bent Fork Dropout
    By lemond in forum General Cycling Discussion
    Last Post: 02-17-2004, 06:39 AM
