Bump inside head tube?
Results 1 to 4 of 4
    Jun 2005
    I noticed that there is a bump inside of my head tube. Iím not sure if it is rubbing against the steering tube. Is this supposed to be there? The frame is a giant TCR.
    Jun 2005
    Under closer inspection, it is rubbing against the steerer tube And there is an abrasion on the steerer tube.. It looks like it may be a patch or repair or something. Should I sand it down a little bit?
    Oct 2013
    I would use a metal file, a lot easier to control. I would want it to clear the fork HT.
    BANNED
    Oct 2002
    There are usually local companies that can do ultrasonic scans of that area to see of that is a void or simply a double over that happens in some types of carbon fiber manufacturing processes. If you can't get a reference from a local shop, you should be able to find them in a phone book or on the net. If it is a void filing or sanding can break through and make that area weaker. If you bought the bike new and are still under warranty I would get it replaced.
  1. Fissure inside head tube
    By zeego in forum Components, Wrenching
    Last Post: 06-26-2014, 10:45 AM
  2. Head set1" steering tube with a 1 1/2 head tube?
    By hkpc20790 in forum Components, Wrenching
    Last Post: 11-15-2009, 07:10 PM
  3. 1" head tube to 1 1/8" head tube
    By nmadse1 in forum Components, Wrenching
    Last Post: 11-29-2008, 07:16 AM
  4. frame angles - seat tube and head tube ?
    By acid_rider in forum Bikes, Frames and Forks
    Last Post: 11-22-2006, 06:55 AM
  5. head tube angle and head tube height affect fit
    By fah35 in forum Bikes, Frames and Forks
    Last Post: 04-24-2005, 04:01 PM
