Chainstay length vs tire size
Results 1 to 12 of 12
    Erfahrener Radfahrer
    Reputation: IcemanYVR's Avatar
    Jul 2006
    With a chainstay length of 420mm, STA of 73 degrees and BB drop of 75mm, is it possible to run 700x38 tires?
    Are there clearance issues? What would be the minimum chainstay length required to run 38c tires?
    I like short chainstays, and would like to keep as much of the responsiveness of the bike that I can.
    Allan
    I SUPPORT DRUG FREE SPORT
    'brifter' is f'ing stupid
    Who knows? You're forgetting about some other rather important details.
    #promechaniclife
    Dec 2006
    No, it is not possible.
    Note that most cyclocross bikes have @43cm chainstays, and a 33-34mm tire limit.
    I suppose you could severely flatten the chainstays, but that would reduce lateral stiffness.
    Jul 2006
    Quote Originally Posted by Peter P. View Post
    Thank you, I just purchased rattlecad as well, so that is being helpful. Makes you wonder how companies like Mosaic and Argonaut can run 38c tires on 420mm stays. They must use custom tubes or something.
    Allan
    deleted
    Feb 2002
    Some? How about "nearly all" rather important details?
    Jul 2009
    Quote Originally Posted by IcemanYVR View Post
    Absolutely, The Trek Checkpoint ALR4 has a 425mm chainstay length and can handle up to 45c tires. The larger sizes have the STA and BB drop you specify.
    https://www.trekbikes.com/us/en_US/b...alr-4/p/22628/
    Dec 2006
    [QUOTE=M-theory;5348541]Absolutely, ... you specify.
    Those extra 5mm in the chainstay length are necessary, otherwise 38mm tires aren't going to fit.
    My road bike has 420mm chainstays. It will fit 32mm road tires, but anything larger will hit the back of my 73 degree seat tube.
    Feb 2002
    That is, with your dropout placement. A frame with different dropouts might actually have room.
    Dec 2006
    You lost me on this. Help me understand how dropout placement factors in to this.
    Reputation: velodog's Avatar
    Sep 2007
    Horizontal vs vertical.
    https://www.cycle-frames.com/bicycle...ctmpOMWzIS.png
    https://www.cycle-frames.com/bicycle...ctmpqsACnf.png
    Too old to ride plastic
    Dec 2006
    I didn't think anyone built with horizontal dropouts anymore, which is why I didn't consider them.
    But you're right; even some vertical dropout slots angle forward, and if your chainstay length vs. tire size are on the edge, you may have to deflate a tire for installation.
  1. Effects of chainstay length on bicycle performance?
    By mozami in forum Fixed/Single Speed
    Last Post: 03-06-2011, 05:36 PM
  2. Chainstay length and wheelbase
    By Vitamin G in forum Bikes, Frames and Forks
    Last Post: 09-20-2010, 04:47 PM
  3. Chainstay length
    By AlanS in forum Bikes, Frames and Forks
    Last Post: 05-04-2006, 10:27 AM
  4. Effect of chainstay length
    By Aspen in forum Bikes, Frames and Forks
    Last Post: 12-27-2005, 10:36 AM
  5. Racks, Panniers, and Chainstay Length
    By pjam in forum Commuting, Touring and Ride Reports
    Last Post: 06-18-2005, 09:25 AM
